Bitspower Owners gallery - Page 4 - Overclock.net - An Overclocking Community
post #31 of 852 (permalink) Old 02-20-2014, 07:27 AM
Rep: 231 (Unique: 165)
Completed Bitspower Build ....well plumbing anyway.
Can anyone tell me ..... (vendor and Bitspower didn't answer)
1. There are multiple inserts for the Bitspower flow meters in the pic there..... they come with various inserts for different tube sizes but no indication as to when to use either or none at all.
2. How you convert rpm to gpm with each alternative.....just math but need the fudge factor.
JackNaylorPE is offline
post #32 of 852 (permalink) Old 02-20-2014, 08:35 AM
Rep: 22 (Unique: 21)
Originally Posted by Etaloche View Post
Could you explain to me how to use the fitting that is on the second picture bottom left.
I've seen it when I was shopping for fittings and searched it up but not much info on it... I think it has something with letting air out from your loop?
Exactly, you push the top and the air comes out.
Juthos is offline
post #33 of 852 (permalink) Old 02-20-2014, 08:52 AM
Etaloche's Avatar
Rep: 15 (Unique: 10)
Where would you install this kinda fitting and why would you need one?
Etaloche is offline
post #34 of 852 (permalink) Old 02-20-2014, 10:18 AM
You can put it on the exhuast port of the radiator, or on the top of the res like this:
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=40097
instead of a regular stop fitting.
Juthos is offline
post #35 of 852 (permalink) Old 02-20-2014, 10:26 AM
Etaloche's Avatar
What benefits does this fitting offer? Why would I need one or want one
Etaloche is offline
post #36 of 852 (permalink) Old 02-20-2014, 12:43 PM
Product description:
"The Bitspower G1/4 Thread Pressure Equalizer Stop Plug is designed to be used on top of your reservoir or another high point in your system to allow excess air / pressure build up to exhaust through the fitting. This makes priming your system easier and helps eliminate air locks in your pump"
Juthos is offline
post #37 of 852 (permalink) Old 02-20-2014, 04:17 PM
Etaloche's Avatar
Would I be achieving the same thing if my res had 3 ports at the top, 1 inlet and 2 stop plugs, and I simply unplugged one of the stop fittings
Etaloche is offline
post #38 of 852 (permalink) Old 02-24-2014, 12:48 PM
I think the idea is you can vent while pumps running .... wouldn't try removing the plug and doing that .... I used a mini valve and plug .... loosen the plug, crack the valve / close valve secure plug
post #39 of 852 (permalink) Old 02-24-2014, 02:16 PM
Etaloche's Avatar
Why? What would happen if I tried to undo one of my stop plugs on the top of my res while the pump is running?
Etaloche is offline
post #40 of 852 (permalink) Old 02-24-2014, 02:57 PM
Rep: 5 (Unique: 5)
Anyone know where I can find some 3/8x5/8 compression fittings? They're out of stock at the usual haunts... (Frozen, and Perf-PCs)... HALP! I want to build!
SeanEboy is offline
