[Build Log] monsterITX v2.0 - now with improved secret sauce! - Overclock.net - An Overclocking Community
post #1 of 468 (permalink) Old 04-23-2013, 03:12 PM - Thread Starter
***der
longroadtrip's Avatar
Rep: 181 (Unique: 139)
There won't be a lot of modding done on this case as to be honest, it is almost perfect for me...That being said, I've been wanting to do a monster mITX build for a while. Recently, Case Labs released the Mercury S3 case. Perfect for what I wanted to do! biggrin.gif
Hardware Specs:
Case Labs Mercury S3 case
EVGA Stinger motherboard
Intel 3770k I-7 CPU
Corsair Dominator Platinum 2 x 8GB 1600 mHz RAM (subject to change if I decide to w/c the RAM)
MSI 6970 GPU (may be changing it out)
Silverstone Strider 750w PSU
Dual Samsung 840 Pro 256 GB SSDs
Watercooling Specs:
Dual Alphacool XT 45 240mm rads
Noiseblocker eLoop fans
Aquacomputer Aquaero XT control
Aquacomputer Poweradjust Ultra
MCP35x (possibly changing out to a D5 variant)
EK blocks for CPU and GPU
Mayhems Pastel White fluid
Koolance DDC top and mounting kit
Log Updates:
S3 unboxing
Rad and Aquaero Mounting
Fan/Lighting Control
Wiring/Cabling
Fillport and Temperature LED
Sleeving
Cabling Continued
Pump Assembly
Current Photo:
longroadtrip is offline
post #2 of 468 (permalink) Old 04-23-2013, 03:13 PM - Thread Starter
***der
S3 unboxing...
I was actually surprised at the packaging of the case, it was really packed very well!
Box:
Open it up and to has foam corners and a really thick plastic wrap...
Out of the box...
Plastic wrapping...
The windows are covered on both the outside and the inside...along with a lot of packing inside!
The hardware kit is pretty well done and each bag is labeled...
Holes for the feet...
Simply screw them on...(although these will probably get changed out)
Panels removed...
I like that it has room for a triple slot GPU and the watercooling holes have caps (grommets are included to change out)
HDD side...I like how easy the access is to the front panel wiring...
Drop in rad mount for a 240 or 280 mm rad
2 USB 3.0 and typical antivandal switches...
Front 240 mm rad mount...
This case is really not going to see much in the way of modding...When CL was designing it, I spent a lot of time offering up suggestions based on what I saw as shortcomings with the design of the Prodigy. Jim took it all into consideration and this is almost like getting a custom built case for me. It has almost everything I want, where I want it.
post #3 of 468 (permalink) Old 04-23-2013, 03:19 PM
WHOOP
TB13's Avatar
Rep: 59 (Unique: 52)
This makes me want to build an ITX system really bad...
Want to breathe some life into that old LGA775 system you have? Don't want to spend the money on an expensive Core 2 Quad? Check out this simple mod to get the most out of your system with an LGA771 Xeon CPU
TB13 is offline
post #4 of 468 (permalink) Old 04-23-2013, 03:23 PM
socketus's Avatar
Rep: 112 (Unique: 84)
Subbed dorido ! I've been waiting to see what you can do with a CL case since I watched your Yin & Yang prodigy builds. It will be epic, I know, coz your pix are already vibrating my buyer's trigger finger; they show off the S3's impeccable design. CL is unlike any other case maker in terms of packing - seems like a minor detail, but when you open up your CL box, and see the level of detail that CL puts into packing the case ! You know you're in for a game changer when you build into the case. I'm not gonna say flawless, but awe inspiring - the materials, design - all of it, are accomodating to a type of enthusiast who WANTS TO FILL IT UP ! biggrin.gif
Btw, I kinda miss old double tongued Alfred as your avatar, but its all relative wink.gif
socketus is offline
post #5 of 468 (permalink) Old 04-23-2013, 03:26 PM
Computer Art
Jameswalt1's Avatar
Rep: 305 (Unique: 207)
Dito. I'm between one of these or a 350D.
post-flame-small.gifTEARS IN RAIN A Blade Runner inspired build (2017)post-flame-small.gif
post-flame-small.gifPARVUM WARFARE An Advanced Warfare themed build (2014)post-flame-small.gif
post-flame-small.gifPARVUM TITANFALL A Titanfall themed build (2014)post-flame-small.gif
post-flame-small.gifROBOCOP A Robocop themed 900D build (2013/14)post-flame-small.gif
Jameswalt1 is offline
post #6 of 468 (permalink) Old 04-23-2013, 03:55 PM
Retired Staff
dman811's Avatar
Location: [email protected] Section - Man Cave - North Carolina
Rep: 120 (Unique: 92)
Subbed like Subway sandwiches!!! COMPUTER PR0NZ FTW!!!
Still In Beta Folding Team Captain
post-flame-small.gifProudly Folding For Still In Betapost-flame-small.gifHFM Live Stats
Steam: ctxdemon | Origin: DerickM
Signature Worthy Quotes (Click to show)
I romanced Liara in ME 1.
I last minute romanced Garrus in ME 2.
Then in ME 3 I told Liara we were still together right after telling Garrus the same thing. Progressed on with Liara then (unintentionally) had a shower with Traynor and (intentionally) led on Allers.
So am I a bad person or is my female Shepard just easy?
They didn't get kinky no matter what I did. Disappointment.
dman811 is offline
post #7 of 468 (permalink) Old 04-23-2013, 04:18 PM - Thread Starter
***der
Yeah..The M8 I had was a brilliant case...You can really see the design evolution with the S3.
I'm on so many forums now, I decided to put up a common avatar amongst them all. Picture was taken from my better side...Dontcha think? biggrin.gif
Radiator and Aquaero mounting
Like a kid in a candy store...went crazy this afternoon and started working on the rad assemblies and the Aquaero mounting...
Not much to show with the Aquaero, just 2 short brackets, but it really looks great in place!
After the Aquaero, it was time to do the front rad assembly...pretty simple really...a two part bracket that is disassembled, the fans are then sandwiched between the front flex bays and the rad mount.
Installed...
Here is the top drop in mount...pretty straight forward really....
Both rads installed...
Even have a little room for the Aquaero!
post #8 of 468 (permalink) Old 04-23-2013, 04:34 PM
Retired Staff
Shadow_Foxx's Avatar
Rep: 76 (Unique: 58)
Subbed! I love those eloop fans, little on the pricey side for me though sad-smiley-002.gif Looking great so far! Still waiting for someone to put a monsta in this case tongue.gif
Shadow_Foxx is offline
post #9 of 468 (permalink) Old 04-23-2013, 06:46 PM
Did you say Abe Lincoln?
.theMetal's Avatar
Rep: 89 (Unique: 74)
Spitting in the Stream of Consciousness
Colorado Overclockers
[Official] Fractal Design Node 304 Owners Club
The Donbot
(12 items)
Crushinator
(10 items)
i7 3770 @ (4.2~4.4)
ASUS P8Z77-I Deluxe
MSI 1070 Gaming X
16gig Crucial Tactical LP (@2000)
Crucial BX100 500gb
3TB hard drive
Silverstone ST55F-G
Phanteks PH-TC14PE
Phanteks Evlov ITX
BenQ 27inch IPS (2560x1440)
Keyboard
Blackwidow Tournament
Mouse
Logitech G203 Prodigy
i5 2320
Asrock H61M-VG4
EVGA GTX 970
8gig Samsung LowPro
Samsung 840 Evo 250gb/WD Black 640gb
Rosewill Hive 550
Apevia X-ENERQ Pink
Asus 24 inch (1080p)
Keyboard
Sades Mechanical w/blues
Mouse
Razer Abyssus 2014
.theMetal is offline
post #10 of 468 (permalink) Old 04-23-2013, 09:16 PM
Linux Lobbyist
Apocalypse Maow's Avatar
Rep: 15 (Unique: 13)
Looking good so far. Those fans are gorgeous!
Sub'd
Apocalypse Maow is offline
