DIY Voltage Controlled Scalable PWM Controller - Overclock.net - An Overclocking Community
post #1 of 76 (permalink) Old 05-27-2013, 04:44 PM - Thread Starter
Old, Senile, and Happy
IT Diva's Avatar
Rep: 678 (Unique: 347)
Hey gang,
I was hoping for a section for DIY electronics, but couldn't find anything like that.
So since this project is for aimed at being able to control PWM pumps like the 35X or new PWM version of the D5 from a normal variable voltage fan controller I figured the Water Cooling section was the best place for this thread.
As many of you know, a lot of my builds feature some custom electronics that make them unique and special.
All of my builds with PWM pumps have custom PWM controllers to set the pump speed manually, or be able to switch it to mobo control.
I got some PM's recently asking about being able to control a PWM pump from a fan controller, and one suggested a circuit that's been around for a while, that after giving it some thought, seemed adaptable as a base to work from.
Here's the link, the second one down is the one of interest:
http://www.overclockers.com/forums/showpost.php?p=6473318&postcount=25
I was already planning to use the new Lamptron CW611 controller in the "Mix 'n Match" NZXT 630's builds, so being able to use a pair of 35X's in a setup where I could switch control between manual or mobo speed control and control by the CW611 seemed like a cool idea.
One thing I've learned from building several iterations of DIY PWM controllers, is that you have to build them so that you have a fair amount of trim control for the minimum % and the max % points.
You typically don't want to run a pump down below 15 to 20% or so, and most are at max speed by 70% to 75%.
It's nice to have trim pots set up so that the main speed control runs the pump from the minimum desired speed to the max speed over all of its range, not just a small portion somewhere near the middle of its range. . . ..
And to make it more fun, not all pumps, D5 / 35X are the same, and PWM fans are different yet, as to how they react to the PWM %.
The key part of the circuit that makes it adaptable to voltage control, is the voltage divider network R3, P1, R4, which controls the trip point of the LM311 comparator.
With the circuit set up, it was easy enough to measure what voltage was needed to reach 100% duty cycle, and what voltage threshold was required to rise above 0%.
Knowing what the 0 to 100% duty cycle voltage span is, allowed me to set up a finely adjustable voltage divider network to convert the variable voltage from the fan controller down to a range equal to that span.
The small problem is that the fan controller output starts at 0V, while the 0% duty cycle voltage is about 2.2V.
To solve that problem, I made a finely adjustable voltage divider network and a non-inverting summing amplifier to add the first 2.2V, so that the swing of the fan controller output can swing the PWM from 0 to 100%
In the pic below, the smaller rear protoboard has the fan controller output voltage divider network on the far right, with the "base level" voltage divider network just to its left.
The IC to the left of the dividers is a dual unity gain buffer that feeds the summing amp in the IC to its left. Also in that IC is the unity gain buffer for the manual speed control circuit's voltage output.
The larger front protoboard, is essentially the circuit in the schematic pic, with a LM339 quad comparator IC in place of the single LM311, as the output of the right NE55 IC needs additional conditioning.
The trim pots at the far left are for the 0% and 100% adjustments.
The trim pot on the lower board is the frequency trimmer.
This pic shows the speed control and the switch for fan controller or manual speed control operation.
Here it is set up on my electronics bench: . . .It's in manual mode and set at about 12% as a minimum:
Here's ~95%, and you can see that the frequency is right at 25KHz:
Here's 50%, notice the frequency stays right at the 25KHz mark:
Close up of what I have set as the minimum %:
Here's some pics with the PWM being controlled by the Aerocool X-Vision (display position 4)
Here's 100% . . . full speed on that fan of 1100 rpm 11.9 volts out from the X-Vision:
~70% . . . 11.0V out from the X-Vision . . ..1000 rpm:
~40% . . . .5.6V out from the X-Vision 600rpm
~20% . . . 3.9V out from the X-Vision . . . . . 600rpm
Next phase is to solder it up on some perfboard.
Not sure yet whether I want to go to the trouble to design a pcb for it yet.
Hope you like my project,
Darlene
IT Diva is offline
post #2 of 76 (permalink) Old 05-27-2013, 04:50 PM
givmedew's Avatar
Rep: 193 (Unique: 149)
Well if you end up designing a PCB that I can just drop the parts onto and solder I would be interested in it. This is great and def something I would love to have.
Reverse Chronological Order (Bold is currently in use)Overclocked Intel CPU History (Click to show)
i7-5820k 4.6GHz i5-4670k 4.8GHz, Xeon W5580 4GHz, Xeon X5690 6 core 4.2GHz, i5-3570k 4.7GHz, i5-2500k 4.8GHz, i5-2500k 4.4GHz, i5-2500k 4.6GHz, i7-960T 4.2GHz (first overclocked Intel CPU traded for my 960T)
Overclocked AMD CPU History (Click to show)
PHII x4 960T @x6 3.9Ghz 4.1GHz Turbo, PHII x2 555 @x4 4.0GHz
GPU History (Click to show)
GTX 970, Crossfire R9 290x, SLI GTX 580, GTX 690, GTX 670, GTX 680, HD7950, HD6950, HD5850, SLI 7800GTX, All-in-wonder, 3DFX Fusion 16mb AGP, SLI 3DFX Voodoo2 12mb PCI
givmedew is offline
post #3 of 76 (permalink) Old 05-27-2013, 10:52 PM
sadeter's Avatar
Rep: 28 (Unique: 24)
I think I'm lost somewhere between "Wow . . ." and "What . . ?"
sadeter is offline
post #4 of 76 (permalink) Old 05-28-2013, 01:21 AM
WaterCooler
SortOfGrim's Avatar
Rep: 75 (Unique: 53)
I really like this idea, at least what I understood biggrin.gif I want to control my second pump too (mcp35x) as it will only cool my graphics card. But currently I'm forced to hook it up to the mobo.
So does it matter that the mcp35x has a 4 pin control cable and the Lamptron CW611 controller only has 3 pin?
Main rig: Merc
VR gaming rig: Nemesis
DIY Bench: Frankenstein
Merc
(19 items)
Nemesis
(16 items)
Frankenstein
(4 items)
Intel Core i5-8600K
MSI Z370 Gaming Pro Carbon
MSI GTX 1080Ti
Corsair Vengeance LPX
Samsung 970 EVO 500GB (OS)
Cruxial MX500 m.2 1TB
Corsair AX760
9x Scythe GT AP-15
EKWB blocks, Alphacool UT60 rads, Bitspower fittings
CaseLabs Mercury S8
Operating System
Windows 10
Acer Predator XB271HU
Keyboard
Logitech G Pro
Mouse
Logitech G502
Mouse
Logitech MX Ergo
Audio
Logitech Z906
Audio
Sennheiser HD6 Mix
Audio
Asus Xonar Essence STX
Other
Lamptron FC-5 V3
Intel Core i7-4790K
MSI Z97I Gaming ACK
MSI Geforce GTX 1080 Gaming X 8GB
G.Skill TridentX 2x 4GB 2400MHz
Samsung 840 EVO 250GB
Crucial MX500 500GB
Corsair SF600
Noctua NH-U12S (w/ GT fans)
4x Scythe Gentle Typhoon AP-15
CaseLabs Mercury S3
Operating System
Microsoft Windows 10
Samsung UE40H6400AWXXN 40" TV
Keyboard
Logitech K830
Mouse
Logitech MX Ergo trackball
Audio
Logitech Speaker System Z906
Other
Oculus Rift
Samsung 840 EVO 250GB ssd
Seasonic M12II EVO Bronze 520 Watt
Corsair H100i
Various; Caselabs, Lian Li
SortOfGrim is offline
post #5 of 76 (permalink) Old 05-28-2013, 01:40 AM - Thread Starter
IT Diva's Avatar
I'll put it on perfboard first, and probably use a piggybacked dual board configuration. Makes for a more compact setup, and it's easier to work up one board at a time.
When I built the first tach signal translation board for FC9 controlled fans, I did it on perfboard, never figuring I'd need more than that one . . . then I needed another, and then when I needed a third one I facepalmed and realized I shoulda done a pcb from the get - go.
Hopefully, I've learned from that experience and I'll just do a pcb for this once the first perfboard one is working.
Understanding how it works isn't all that important as just seeing that it does and recognizing its usefulness.
PWM controlled fans and pumps are becoming more mainstream as people come to see the advantages of PWM.
There's a wider range of control where the slower rpm range can be extended downwards for quieter operation without loosing the ability of the fan or pump to start from stopped/off while at that slow setting.
Thanks for looking,
Darlene
IT Diva is offline
post #6 of 76 (permalink) Old 05-28-2013, 01:41 AM
Artikbot's Avatar
Rep: 611 (Unique: 407)
Artikbot is offline
post #7 of 76 (permalink) Old 05-28-2013, 01:57 AM - Thread Starter
IT Diva's Avatar
You'd need to make up some adapter cables.
The 35X's connector needs 12V from a molex to its power pins.
A wire from the ground and tach signal pins needs to go to the CW611, as it has to have a tach signal to output some controlled voltage level.
You'd then need wires from the +V and ground pins of the CW611 output to the PWM converter and wires from the converter output to the ground and PWM pin on the 35X's connector.
I have two CW611s coming this week, as well as a pair of 35X's and other stuff.
The 611 is so new that there's not much info on it yet, so I'll have to figure out all the details once it's here to work with.
Will be updating frequently with how it's all progressing,
Darlene
IT Diva is offline
post #8 of 76 (permalink) Old 05-28-2013, 03:15 AM
TATH's Avatar
Rep: 25 (Unique: 23)
Darlene
Ha ha Like your brains "and your electronic skills" Subscribed
facebook: henry.Tates
Member Scratch build Case Club Link
TATH is offline
post #9 of 76 (permalink) Old 05-28-2013, 05:59 AM
Jetskyer's Avatar
Rep: 20 (Unique: 18)
I wonder...
Would it be possible to hook up a temperature sensor instead of a fancontroller to control the PWM setting?
Genius design and thanks for sharing, +rep!
Jetskyer is offline
post #10 of 76 (permalink) Old 05-28-2013, 06:03 AM
If you go to production on the boards (from a house like PCB123), count me in. I think this would be slick.
47 Knucklehead is offline
