[Build Log] SM8 Watercooled ROG (EK, Bitspower, Aquacomputer, SLI Strix 980 Ti's,....) - Overclock.net - An Overclocking Community
post #1 of 53 (permalink) Old 06-17-2013, 02:32 PM - Thread Starter
Linux Lobbyist
skruffs01's Avatar
Rep: 14 (Unique: 13)
Introduction
This is my first build log on OCN, but also my first WC build. I originally started with a Fractal R4 but decided to move to a Case Labs SM8. There is not too much modding since this case is exactly what I was looking for. Build started in Dec 2012 and my target for completion is July 2013. The name is still TBD (harder than I thought it would be biggrin.gif )
Hardware Specs
CPU - i7 3770k
Board - ASUS MF5
Ram - G.Skill Sniper 4x4Gb 1866Mhz
GPU - 2x GTX 780 SC ACX ordered delivered 2x Strix 980 Ti
SSD - 2x Samsung 840 Pro 256Gb – RAID 0
PSU - Seasonic Platinum 860W
Case - Case labs SM8 - 2 tone (Black inside/white outside)
Hard Drive - 2x WD 3TB Red
Water Cooling Specs
Blocks - EK CSQ nickel (Mobo, pump, GPU, CPU)
Radiator - 2x Alphacool 360 (UT60) White Edition
Tubing - Primochill Advanced LRT - 10/16mm tubing
Fans - 14x NB eLoop B12-P
Pump - Laning DDC 3.25 18W pump
Fittings - Bitspower Compression – Black Sparkle
Fluid - Mayhems Coolant - Pastel White
Koolance INS-FM17N Flow Meter
Aquacomputer Components
450ml Aqualis XT Res w/nano coating
Aquaero 5 XT
3x Poweradjust Ultras (1 pump, 2 for the fans if the PWM signal from the Aquaero doesn’t work out for 12 fans) thinking.gif
2x Inline G1/4 temp sensors
Misc
MDPC Sleeve - White, Black, Color-x (matches ROG red better than the standard Red color)
3x Phobya 30cm RGB LED strips
White LED's -> CPU, Pump top, and Aqualis Res, GPU blocks, EK FC Bridge
Latest Photo's
skruffs01 is offline
post #2 of 53 (permalink) Old 06-17-2013, 02:33 PM - Thread Starter
Linux Lobbyist
skruffs01's Avatar
Case Arrived!!! Excellent packaging, no scratches on any of the components.
Jumped right in after the case was built up. I really like the slide out mobo tray, so much easier to install components.
MDPC Sleeving - I am happy with the result, but I need to add some white since I don't like how they ended up looking with only blk/red.
Just couldn't wait to test fit some components after the case was assembled. biggrin.gif
I am still on the fence between pastel white or blood red....
post #3 of 53 (permalink) Old 06-17-2013, 02:34 PM - Thread Starter
Linux Lobbyist
skruffs01's Avatar
post #4 of 53 (permalink) Old 06-17-2013, 11:55 PM
Jakusonfire's Avatar
Rep: 552 (Unique: 388)
Looks great. Very nice hardware.
Top rad as intake will give you better water temps though in my experience.
Jakusonfire is offline
post #5 of 53 (permalink) Old 06-18-2013, 12:09 AM - Thread Starter
Linux Lobbyist
skruffs01's Avatar
Thanks! Interesting thought on the upper rad as an intake. Currently I will continue with it as an exhaust, but with the drop in mount from case labs it will be really easy to change. biggrin.gif
post #6 of 53 (permalink) Old 06-18-2013, 12:25 AM
Yeah that is a great luxury to have. To change airflow in my case is a massive ordeal, lol.
With only an Ivy bridge and a single GPU with those beautiful rads it is not hugely important but even so good airflow also influences how quiet your system can run. Better cooling = lower fan speeds needed at idle and at load.
This testing here;
http://www.overclockers.com/forums/showpost.php?p=7111920&postcount=5
shows how when loaded the Air/Water delta dropped 50% with top rad as intake ... 15C to 10C
edit; actually it shows the air/water delta increased 50% as exhaust but you know what I mean.
Also; how do you like your eloops? and do you get the full top speed out of them?
I am currently trying out some b12-3's on a UT60 480 and they don't quite make their rated top speed. They look and sound great doing it though smile.gif
They do use a ton more power than my SP120's too which makes using them on the Aquaero difficult. I think I should have gone with the PWM's too.
post #7 of 53 (permalink) Old 06-18-2013, 01:10 AM - Thread Starter
Linux Lobbyist
skruffs01's Avatar
I really like the eLoop's. I tested two of them and I see a max mobo RPM reading of 1850ish (about 150-200 rpm below advertised). Sound subjectively was better compared to my fractal and bitfenix spectre pro's.
I am still not sure if the PWM output on the Aquaero will be enough for 12 eLoop's, so as a backup I have two poweradjust ultra's "on standby" biggrin.gif
I rigged up a PWM splitter with 2 swiftec 8 way PWM fan splitters to test the Aquaero
Pic of the setup for testing the PWM signal on the Aquaero XT. I will split the PWM signal to both of the splitters. Only one rad fan will indicate RPM, but since I will run all fans that are on the rads at the same speed its no issue.
I will post my result (if the PWM signal on the Aquaero is strong enough for 12 fans) since I could not find any results.
post #8 of 53 (permalink) Old 06-18-2013, 01:24 AM
JAM3S121's Avatar
Rep: 59 (Unique: 52)
nice build! The cost of 14x of those fans is not cheap!
JAM3S121 is offline
post #9 of 53 (permalink) Old 06-18-2013, 04:54 AM
freitz's Avatar
Rep: 48 (Unique: 35)
Subbed Like the build so far. Nice work I say pastel blood red!
EVODOT SM8 Build Log // Synology Owners Club // *Official* CaseLabs Owners Club! // CaseLabs MERLIN Owners Club //Corsair Graphite Club // OCN Water Cooling Club // EK Club
PC: I7 7700k // EVGA GTX TITAN X (pascal) // 32GB Dominators 2400 // ASUS 270G // CaseLabs BH4
Mac: Macbook 2015 Space Gray// Core M 1.3ghz // 512GB SSD // 8GB
CAMERA: Leica M240 // 35mm Summilux F1.4 FLE // 50 APO // Sony A7II
SYNOLOGY: DS1516+ // 2x 4TB WD RED NAS
freitz is offline
post #10 of 53 (permalink) Old 06-18-2013, 05:27 AM
Dwalmsley76's Avatar
Rep: 0
Dwalmsley76 is offline
