[Build Log] Water cooled Corsair Carbide Series Air 540 - Overclock.net - An Overclocking Community
post #1 of 292 (permalink) Old 06-18-2013, 09:52 PM - Thread Starter
Watercooler
Gleniu's Avatar
Rep: 42 (Unique: 39)
The project was completed in June and July 2013, it was one of the first builds in the world (not counting factory/demo builds) with custom water cooling loop in Corsair Carbide Series Air 540.
At some point I was planing to change a few things (cable sleeving, the color of the case), but as I became a father smile.gif I had to slow down on my PC/modding hobby. I will be back, but most probably it will be completely new build.
Currently I have my HW in Fractal Design R4 case (all air cooled), water cooling parts waiting patiently for comeback wink.gif
UPDATES:
PICTURES OF FINISHED BUILD
HW LIST:
Case:
  • Corsair Carbide Series Air 540, modded front and bottom
Core HW:
  • Good old i5-750 OC-ed to 4.2Ghz 1.36V
  • ASUS P7P55D-E Deluxe
  • Kingston Genesis 4 x 4Gb @1600
  • GTX 670 Asus Direct CU II 2GB @ stock
  • SAMSUNG 830 Series 128GB x 2
  • Seagate Barracuda 3TB 7200 RPM
  • ASUS Xonar DX
Water cooling:
  • Koolance CPU-380I Water Block
  • EK-FC670 GTX DCII - Acetal+Nickel + EK-FC680 GTX DCII Backplate - Black
  • 3 x Alphacool NexXxoS ST30 Full Copper 240mm
  • Swiftech MCP655-PWM-DRIVE
  • XSPC Tank Reservoir - Laing D5 / MCP655 w/ Blue LED Light - Acrylic
  • Bitspower black matte fittings 16/10mm (3/8 5/8")
  • Masterkleer 16/10mm (3/8 5/8") UV blue
  • Deionized water plus Mayhem's biocide
Fans:
  • Corsair SP120 x 12
  • Corsair AF140 x 1
Misc:
  • Phobya 4Pin Molex to 6x 3Pin Fan Splitter PCB x 3
  • Bitfenix Alchemy led strip white 60cm x 2
The rest:
  • Dell 2209WA monitor 22 inches, 1680 x 1050 (16:10)
  • SteelSeries Xai Laser mouse
  • SteelSeries 6GV2 keyboard
  • Sennheiser HD 380 Pro
Gleniu is offline
post #2 of 292 (permalink) Old 06-18-2013, 09:53 PM - Thread Starter
Watercooler
Gleniu's Avatar
Gleniu is offline
post #3 of 292 (permalink) Old 06-18-2013, 10:08 PM
AstralReaper's Avatar
Rep: 16 (Unique: 14)
Subbed. I want to see what this case can do before I get one. Good Luck.
AstralReaper is offline
post #4 of 292 (permalink) Old 06-18-2013, 10:16 PM
Linux Lobbyist
newone757's Avatar
Rep: 13 (Unique: 11)
My 540 coming friday. Subbed
newone757 is offline
post #5 of 292 (permalink) Old 06-18-2013, 11:21 PM
v1ral's Avatar
Rep: 67 (Unique: 65)
This!!!!!!!
v1ral is offline
post #6 of 292 (permalink) Old 06-19-2013, 01:23 AM
STUNT1990's Avatar
Rep: 37 (Unique: 33)
Mine also is comming Friday ^^
STUNT1990 is offline
post #7 of 292 (permalink) Old 06-19-2013, 03:34 AM
pc-illiterate's Avatar
Rep: 359 (Unique: 284)
/subbed.
happy modding.
pc-illiterate is offline
post #8 of 292 (permalink) Old 06-19-2013, 06:36 AM
Tw1stedDNA's Avatar
Rep: 0
Lucky guys! Mine won't be here till atleast Monday cause I live in MA.
Tw1stedDNA is offline
post #9 of 292 (permalink) Old 06-19-2013, 06:57 AM - Thread Starter
Gleniu is offline
post #10 of 292 (permalink) Old 06-19-2013, 07:06 AM
Tw1stedDNA's Avatar
Rep: 0
Damn...the box looks damaged! Hope the case is in pristine condition.
