Best Brands for Water Cooling - Overclock.net - An Overclocking Community
post #1 of 16 (permalink) Old 06-25-2013, 11:40 AM - Thread Starter
TheOCNoob's Avatar
Rep: 9 (Unique: 7)
So I'm going to do a custom loop ! I have an H60 but I have always wanted to do a custom loop for my FX-8320 and my NB, I have a ga-970a-ud3 motherboard.
So if you would post the best brands and materials I could use smile.gif! I have a $250 budget
Case: nzxt phantom full tower
What I need listed:
Coolant
Radiator (prefer x2 120mm)
Water block (am3+ and nb)
Pump
Connectors
Tube
Resovour
Thanks for the opinions!
Retired AMD User
TheOCNoob is offline
post #2 of 16 (permalink) Old 06-25-2013, 11:46 AM
Rep: 142 (Unique: 125)
For $250 you "might" be able to put together a custom loop only for your cpu. Your other option is a water cooling kit.
huhh is offline
post #3 of 16 (permalink) Old 06-25-2013, 11:46 AM - Thread Starter
TheOCNoob's Avatar
Rep: 9 (Unique: 7)
Hmm what about $300
Retired AMD User
post #4 of 16 (permalink) Old 06-25-2013, 11:50 AM
YouGotJaked's Avatar
Rep: 31 (Unique: 30)
Good brands are XSPC, EK, Koolance, Alphacool, Bitspower, Swiftech, Watercool/Heatkiller, and Phobya
But with a $250, I'd go with this: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_202_972&products_id=33588 but since you can spend a bit more, this is a bit better: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_202_972&products_id=33550
However, you could probably do a real "custom" loop if you bought all used parts.
Guide(s): How to remove G. Skill Ripjaws heatspreader
Build Log: High Roller
Funny Quotes (Click to show)
It had better be overclocked, modern video cards are no where near the performance of console graphics.
yesterday i was thinking w*f am i running a 7970 on a $19, mATX mobo?
They don't care about that, they just want your porn collection. That's the goal here, to make the worlds biggest porno collection, Obama just wants to be able to rub it into Putin's face. (That's probably not the best choice of words...)
Mine's under my butt. I sit on the top 200mm exhaust fan sometimes to get rid of buttsweat.
BACKUP, BACKUP, BACKUP! As someone who's learned the hard way, please backup your data!
YouGotJaked is offline
post #5 of 16 (permalink) Old 06-25-2013, 12:05 PM - Thread Starter
TheOCNoob's Avatar
Rep: 9 (Unique: 7)
Do you think used parts should be reliable ?
Retired AMD User
post #6 of 16 (permalink) Old 06-25-2013, 12:18 PM
They should be. It just depends on who you're buying them from and what their condition is. I bought a few parts used and haven't had any issues so far. Try looking on the marketplace here. Most people here selling (at least from what I've seen) take pretty good care of their stuff.
post #7 of 16 (permalink) Old 06-25-2013, 12:35 PM - Thread Starter
TheOCNoob's Avatar
Rep: 9 (Unique: 7)
I will look into that I'm probably going to buy these piece by piece so I can get better quality parts smile.gif
Retired AMD User
post #8 of 16 (permalink) Old 06-25-2013, 09:18 PM
I'd rather buy used parts from a reputable person on OCN than buy a xspc kit. You'd get a much better system that way.
huhh is offline
post #9 of 16 (permalink) Old 06-26-2013, 10:23 PM - Thread Starter
TheOCNoob's Avatar
Rep: 9 (Unique: 7)
Okay so I just want to water cool my 8320 forget Chipset why is the one $80 less and comes with a complete everything while the other doens't come with everything like what are the specific differences and why it is "so much" better.
XSPC Raystorm #1
and
XSPX Raystorm #2 (Cheaper)
Sorry i am new to the 'custom' liquid cooling world.
Retired AMD User
post #10 of 16 (permalink) Old 06-26-2013, 11:41 PM
XSPC Raystorm #1
and
The cheaper one has a XSPC X20 pump and the other a D5 variable speed pump which is significantly better especially if you plan on adding more blocks to your loop
huhh is offline
