[Build Log] Crowbar - WC Fractal Arc Midi R2 - Overclock.net - An Overclocking Community
post #1 of 236 (permalink) Old 08-11-2013, 09:49 AM - Thread Starter
Linux Lobbyist
cyphon's Avatar
Rep: 110 (Unique: 83)
I am typically an Intel/nVidia user, but wanted to switch it up a bit so we are going with a pure AMD build. I also want a challenge and to work on some case modding, so I am going to try to 'overstuff' a Fractal Arc Midi R2.
Since Valve looks to be releasing Source Engine 2 pretty soon [looks pretty promising, but it is Valve so I won't be surprised if it doesn't happen]....I am going to apply a Half-Life theme in hopes of getting Half-Life 3 sometime in the lifetime of this machine. Expect orange and lambdas wink.gif Also the name
The plan:
CPU: AMD FX-8350 [Received]
MB: ASUS Crosshair V Formula-Z [Received]
RAM: 16GB of Corsair Dominator [Received]
GPU: 3 HIS IceQ Boost Clock Radeon HD 7950 [Received]
PSU: Cooler Master 1000W Silent Pro [Received]
Storage: 2 SAMSUNG 840 EVO 120GB [Received]
Case: Fractal Arc Midi R2 [Received]
OS: Windows 8 Professional (with free 8.1 upgrade and will get the start menu back smile.gif ) [Received]
Cooling:
  • Radiators:
    • BlackIce X-Flow Stealth 240 [Received]
    • BlackIce Stealth 240 [Received]
    • AquaComputer 240 [Receieved]
    • BlackIce 120 Stealth [Recieved]
  • Pumps: 2 Swiftect MCP350 [Received]
  • Reservoir: XSPC dual bay two DDC pump and two res unit [Received]
  • Blocks:
    • EK-Supremacy Clean CSQ - Nickel [Received]
    • EK-FB ASUS C5F-Z - Acetal+Nickel [Received]
    • EK-RAM Monarch X4 - Nickel CSQ [Received]
    • 3 EK-FC7950 - EN (Nickel) [Received]
  • Fluid:
    • Mayhems Pastel Orange [Received]
    • Mayhems Pastel White [Received]
    • Mayhems Deep Red Dye [Received]
  • Fans:
    • 6 Scythe Gentle Typhoon AP-15 [Received]
    • 1 Scythe Strip Stream Slim 12M[Received]
  • Tubing: Primochill rigid acrylic tubing [Received]
  • Fittings:
    • 4 Bitspower C47 [Received]
    • 20 Primochill Ghost - black [Received]
    • 2 Bitspower T-Type Rotary [Received]
    • 9 Bitspower 90 Degree Rotary [Received]
    • 1 Bitspower 90 Degree [Received]
  • Other:
    • Custom rad grills [Received],
    • 3 EK-FC7950 Backplate - Black [Received]
    • 3 EK-VGA I/O bracket HD7970 [Received]
    • 2 Phobya fillport [Received]
    • Custom Trifire cover [Received]
    • Custom Res faceplate [Planning]
    • Custom PSU/Cable cover [Constructed]
    • Single sleeving[Done]
Lighting:
  • 6ft Orange EL Wire [Received]
  • Probably some cold cathodes
  • Probably some LEDs
Loops:
Loop 1: Res -> pump -> 240 rad ->120 rad -> mobo -> cpu -> ram -> res
Loop 2: Res -> pump -> 240 rad -> gpu -> gpu -> gpu -> 240 rad -> res
Layout:
Final Pic {more in gallery, see link below)
Table of Contents
8/11 - Back panel rad mod
8/13 - Hardware
8/17 - Fill port mod
8/24 - GPU Blocks
8/28 - Custom Rad Grills Arrived
8/29 - CPU Block
8/30 - MB Block
8/30 - Polished RAM Block
8/31 - Acrylic Tube and Fittings
9/3 - GPU Backplate
9/21 - Angled Fittings and SSDs
9/21 - Custom Trifire Cover
9/24 - Custom Rad Grill w/ EL Wire
9/28 - Single Sleeving and SSD Mod
10/6 - Redone Single Sleeving
10/8 - PCI Express Sleeving
10/12 - Custom PSU Cover R1
10/13 - Painted AP-15 Test
10/14 - PSU Cover R2 is Done
10/15 - Main Case Lighting
11/4 - Performance Benchmarks and Temps
11/4 - Final Image Gallery
cyphon is offline
post #2 of 236 (permalink) Old 08-11-2013, 10:02 AM
Rep: 81 (Unique: 67)
subscribed!
GaMbi2004 is offline
post #3 of 236 (permalink) Old 08-11-2013, 10:02 AM
my first dubble post -_-
post #4 of 236 (permalink) Old 08-11-2013, 10:03 AM
LordOfTots's Avatar
Rep: 60 (Unique: 48)
Subbed biggrin.gif why not a 8350?
LordOfTots is offline
post #5 of 236 (permalink) Old 08-11-2013, 10:09 AM - Thread Starter
Linux Lobbyist
cyphon's Avatar
Wanted that, but got a deal on the 8150 for like $125 locally....may return and get the 8350 still, but wanted to jump on it while I could, lol
cyphon is offline
post #6 of 236 (permalink) Old 08-11-2013, 10:11 AM
LordOfTots's Avatar
Originally Posted by cyphon View Post
Wanted that, but got a deal on the 8150 for like $125....may return and get the 8350 still, but wanted to jump on it while I could, lol
Good deal thumb.gif still would go 8350 if possible though, it will handle those 7950s much better
post #7 of 236 (permalink) Old 08-11-2013, 03:39 PM - Thread Starter
Linux Lobbyist
cyphon's Avatar
Alright guys, I got the rear case mod done today!!! Well, mostly. I will be adding some U-Channel and some custom fan grills (I am drawing them up in CAD right now).
I messed up the screw holes a little bit, but it should still work smile.gif
Got the drawing done
What it will look like inside the case
Holes cut...screw holes are slightly off...but oh well :/
Checking the cut
Installed!
Close up
Inside case view
Let me know what you guys think...I will post the custom fan grill drawings when they are finished. I am thinking they will be chromed out smile.gif
cyphon is offline
post #8 of 236 (permalink) Old 08-11-2013, 04:00 PM
LordOfTots's Avatar
post #9 of 236 (permalink) Old 08-12-2013, 07:55 AM - Thread Starter
Linux Lobbyist
cyphon's Avatar
Now that I look at it......I might replace that front rad with an X-Flow version.
Looks like there is about 25mm space between the bottom of the rad and the bottom of the case and about 30mm between the top of the rad and top of the case. The X-Flow is only 15mm longer, so I think this should fit no problem
The swap out will ensure that there are no issues with the connectors on the rads being too close, as well as give a nice low point return from the GPU blocks.
cyphon is offline
post #10 of 236 (permalink) Old 08-12-2013, 08:17 AM - Thread Starter
Linux Lobbyist
cyphon's Avatar
Also, since I am using a bay res, I am thinking of adding some fillports in the top, so I do not have to deal with pulling the bay res out to fill. This also should allow for me to turn upside down to drain easily. The top cover of the Arc Midi R2 will hide them nicely as well smile.gif
Proposed fillport locations.
Just drop it down to a T-connection right before the inlet to the res/pump and I think I am in business
cyphon is offline
