Need advice! Lapping apogee HD or not? - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 08-22-2013, 08:33 AM - Thread Starter
Rep: 81 (Unique: 67)
Im about to do my first lapping on my delidded 4670K and was thinking of lapping the water block too..
I read some places that some water blocks is bad to lap, that they have their shape for a reason..
Anyone knows about lapping of this block? Swiftech Apogee HD
any complications related to this block and lapping?
I would also like to know what temps I can achieve with lapping CPU and the block.
Thanks ^^
GaMbi2004 is offline
post #2 of 7 (permalink) Old 08-22-2013, 08:38 AM
xxRemnantxx's Avatar
Rep: 37 (Unique: 33)
You can use a caliper or a ruler to see if it has a domed shape in the center of the block/ if yours does it may be beneficial to lapp your block to have even seat pressure across the block. Seat pressure is another thing that will greatly help your temps... If you cannot change out springs then it would help if you can influence the bracket to bend and cause greater seat pressure- can you tag a link to your bracket and mounting hardware?
I prescribe another dose of benching. It should get rid of that pesty disease known as prime95 biggrin.gif
OCN #1 1090T SUB 6.772GHZ! Ivy at 6.2ghz! How to remove Nvidia drivers correctly- How to remove Ati/Amd drivers correctly- How to overclock AMD- How to overclock Sandy or Ivy-
xxRemnantxx is offline
post #3 of 7 (permalink) Old 08-22-2013, 08:40 AM
Better seat pressure can drop it 3-5c under full load with same paste assuming you have decent seat pressure to start.. If its already flat then its not worth doing - except to get mirrored finish
post #4 of 7 (permalink) Old 08-22-2013, 08:41 AM
salamachaa's Avatar
Rep: 79 (Unique: 63)
My eyes skipped apogee and just saw lapping HD(D). I was confused and terrified at why someone would do such a thing to a hard drive.
salamachaa is offline
post #5 of 7 (permalink) Old 08-22-2013, 09:13 AM - Thread Starter
Something like this? the screws goes all the way down and springs takes care of the rest.. im guessing stiffer springs would give more pressure..
I get 70C peaks with 20 runs of IBT/ 1hour OCCT with AVX, 4.5ghz @ 1.27V (not the best of chips)
So.. when I get my lapping kit, I should check the bow of the block, lap the CPU IHS and leave the block unless it is bowed a lot?
after that I can try adding spacers to the backplate to increase the pressure (dont like the idea of bending the bracket)
post #6 of 7 (permalink) Old 08-22-2013, 09:18 AM
MrNishi's Avatar
Rep: 11 (Unique: 10)
If you doing the processor I would do the water block, or check it with a straight edge. Heat sink manufactures will concave or convex their bases in instances to match a CPU IHS, if you lap it flat, which some are far from I would do the heat sink to match. as far as contact pressure you should only need to remove a few thousandths which shouldn't change pressure at all. you can check with a straight edge or just lap the heat sink a few times and see how it wears.
MrNishi is offline
post #7 of 7 (permalink) Old 08-22-2013, 09:24 AM - Thread Starter
yes.. I think the pressure suggestion was another way to bring down temps, and not something I have to do because of lapping smile.gif
