Cooler Master / Alphacool Eisberg Owners Club - Page 2 - Overclock.net - An Overclocking Community
post #11 of 780 (permalink) Old 09-05-2013, 10:12 AM
rasa92re's Avatar
Rep: 1 (Unique: 1)
@Lucky23, Thanks!thumb.gif Is that third cable on the adapter a 9V? It didn't have a label. Also, is there software that would let me change the voltage output of a CPU Fan header on the motherboard so that I can control the pump speed/sound through software instead of having to manually switch cables.
@francisco9751, I personally don't see a need for the sound unless I have all my case fans at full speed because it has a noticeably, distinct sound. I don't want it to be the only sound that is strikingly audible so I keep the motor at 7V. 12V isn't awful but I just prefer a quiet case when the CPU and GPU are at stock clocks.
My passion was just monster fish tanks and then I met all of you. Dare I say, my social life is gone and my curiosity has reached an all time high!
rasa92re is offline
post #12 of 780 (permalink) Old 09-05-2013, 08:37 PM - Thread Starter
Lucky 23's Avatar
Rep: 85 (Unique: 69)
I believe the outside cables are the 5v and 9v and the middle is the 7v IIRC. You might be able to adjust it in bios similar to adjusting your fans RPM. I dont think there is any software to do this though
Lucky 23 is offline
post #13 of 780 (permalink) Old 09-06-2013, 03:46 PM
Rep: 3 (Unique: 3)
more photos. I'm from Paraguay. South America
Caos is offline
post #14 of 780 (permalink) Old 09-06-2013, 08:43 PM - Thread Starter
Lucky 23's Avatar
Lucky 23 is offline
post #15 of 780 (permalink) Old 09-07-2013, 01:45 PM
Rep: 3 (Unique: 3)
Originally Posted by Lucky 23 View Post
Looks good. thumb.gif Are you using the Excalibur fans?
if I use two excalibur fanes. now doing 34 degrees here. I get the most you went to 70 degrees hotter core. you think? BF3 playing for two hours or so.
Caos is offline
post #16 of 780 (permalink) Old 09-07-2013, 02:47 PM - Thread Starter
Lucky 23's Avatar
Max temp is 70c during gaming or Prime95? What CPU are you using? You should fill out your Sig with your system specs.
Lucky 23 is offline
post #17 of 780 (permalink) Old 09-07-2013, 03:00 PM
Rep: 3 (Unique: 3)
BF3 for two hours. I have an i5 3570K to 4.3. it's hot here in Paraguay. temperature is now 34 ° C, later complete the specification of my PC.
Caos is offline
post #18 of 780 (permalink) Old 09-07-2013, 05:50 PM - Thread Starter
Lucky 23's Avatar
Lucky 23 is offline
post #19 of 780 (permalink) Old 09-09-2013, 10:47 PM
Skylark71's Avatar
Rep: 4 (Unique: 3)
Hello and greetings from Finland!
You can count me in, here is my Eisberg and gaming rig...
Sorry for bad photo..
Skylark71 is offline
post #20 of 780 (permalink) Old 09-10-2013, 06:50 AM - Thread Starter
Lucky 23's Avatar
Wow looks great thumb.gif What brand tubing did you use? I used red Masterkleer 8mm/10mm on mine.
Lucky 23 is offline
