Another planned build list looking for input - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 10-16-2013, 05:22 PM - Thread Starter
exyia's Avatar
Rep: 21 (Unique: 18)
Case: Thermaltake Level 10 GT
CPU: 3930k - cooled by a Cooler Master Eisberg 240L (which means I also got a 240rad already)
GPU: Three GTX Titans
planned water loop and flow path
http://i81.photobucket.com/albums/j221/XG08Zero/13485816255oKwGOKCrM_5_6_zpsc172c06f.jpg
*I'm thinking I might be short on radiator, maybe I'll add another at the 140mm exhaust? I'm not after the maximum overclock though, just silence - so maybe this is enough
parts on my list
http://www.frozencpu.com/products/18974/ex-blc-1422/EK_Terminal_Block_-_Triple_Parallel_-_Black_Acetal_EK-FC_Terminal_TRIPLE_Parallel.html?tl=g57c593s1895#blank
http://www.frozencpu.com/products/20586/ex-blc-1474/EK_Geforce_GTX_Titan_SE_VGA_Liquid_Cooling_Block_-_Nickel_Acetal_EK-FC_Titan_SE_-_AcetalNickel.html?tl=g57c613s1928
http://www.frozencpu.com/products/20588/ex-blc-1476/EK_Geforce_GTX_Titan_SE_VGA_Liquid_Cooling_RAM_Backplate_-_Black_EK-FC_Titan_SE_Backplate_-_Black.html?tl=g57c613s1928
http://www.frozencpu.com/products/21020/ex-pmp-249/EK_Single_525_Bay_Reservoir_w_Dual_Serial_DDC_325_Pumps_Installed_EK-BAY_RES_Dual_DDC_325_Serial_incl_pump.html
http://www.frozencpu.com/products/4085/ex-rad-86/Black_Ice_GT_Stealth_240_X-Flow_Radiator_-_Black.html?tl=g30c95s160
http://www.frozencpu.com/products/9430/ex-rad-161/Black_Ice_SR1_Low_Air_Flow_Optimized_-_120_Radiator_-_Black.html?tl=g30c95s159
and fittings/barbs/tubing
http://www.frozencpu.com/products/8442/ex-tub-447/EK_G14_Thread_High_Flow_Barb_-_10mm_38.html?tl=g57c593s1893
http://www.frozencpu.com/products/17831/ex-tub-1595/EK_CSQ_G14_Thread_90_Fitting_Adapter_-_Black_EK-CSQ_Adapter_90_G14_Black.html?tl=g57c593s1894
http://www.frozencpu.com/products/17833/ex-tub-1597/EK_CSQ_G14_Thread_45_Fitting_Adapter_-_Black_EK-CSQ_Adapter_45_G14_Black.html?tl=g57c593s1894
http://www.frozencpu.com/products/21226/ex-tub-1995/EK_G14_Thread_Perfect_Seal_Compression_Fitting_-_10mm_ID_x_16mm_OD_38_x_58_-_Black_.html?tl=g57c593s1952
http://www.frozencpu.com/products/17887/ex-tub-1620/PrimoChill_PrimoFlex_Advanced_LRT_Tubing_38ID_x_58_OD_-_10ft_Retail_Pack_-_Bloodshed_Red_PFLEXA10-58-R_w_Free_Sys_Prep.html?tl=g30c99s1615
haven't counted how many yet, will do that when I get home
this will be my first water cooling adventure with computers, but I work with high-pressure/high-flow systems at work on a much larger scale than this, so I think I'll manage just fine. also means you can use technical flow terms without confusing me
I'm waiting on my motherboard RMA so if the budget allows, I'm considering ordering the parts and making the jump (no better time I say)
thank you even more if you provide input
exyia is offline
post #2 of 6 (permalink) Old 10-18-2013, 01:08 PM - Thread Starter
exyia's Avatar
exyia is offline
post #3 of 6 (permalink) Old 10-18-2013, 01:15 PM
zemco999's Avatar
Rep: 94 (Unique: 83)
I can't really comment as I have never done watercooling... BUT I want to see a build log biggrin.gif
zemco999 is offline
post #4 of 6 (permalink) Old 10-18-2013, 10:26 PM
Rep: 231 (Unique: 165)
Links are great if someone needs to check something but adding component names would save potential participants from RSI and get ya more answers I think.
I had a dual pump bay res in my original plan but was concerned about the noise.
What RPMs ya fans at .....Look at the bar charts here regarding Rad choices. Sr1 looks good at 600 rpm.....but drops off as rpm's climb
http://martinsliquidlab.org/2012/05/01/alphacool-nexxxos-st30-360-radiator/4/
JackNaylorPE is offline
post #5 of 6 (permalink) Old 10-19-2013, 06:48 PM
opforce's Avatar
Rep: 1 (Unique: 1)
The general guide for rads is one 120mm rad for every component then plus one. From what I see in your links you have only three rad "space". I would recommend at least 6 since its all crazy high end and it accounts for any overclock you do.
You don't need to spend that much on a pump/bay combo. If you want the redundancy of a second pump I'm sure you could find something else. No one needs two pumps unless you want to do an external rad and have the tubing go in the next room to be quite.
On a side note I'm happy to see your an evo fan. So am I, I just don't have one yet.
opforce is offline
post #6 of 6 (permalink) Old 10-20-2013, 05:07 PM - Thread Starter
exyia's Avatar
haha thanks! you can see my car here if interested/bored!
2012
http://www.evoxforums.com/forums/showthread.php?t=57947
2013
http://www.evoxforums.com/forums/showthread.php?t=76378
I'm just leaning towards the 5.25" pump/res combo for space savings, though now that you point it out, maybe 3 pumps is a bit overkill. I'll keep looking for options, but I'm conscious about space since I'm already a bit short on radiator space (and want to avoid dealing with buying another case)
exyia is offline
