? Wall mounted, Water cooled PC (The RecoilMachine) - Overclock.net - An Overclocking Community
post #1 of 65 (permalink) Old 02-14-2014, 12:07 PM - Thread Starter
Recoil P's Avatar
Rep: 5 (Unique: 5)
Hi all,
Having been inspired by a few other wall mounted PCs, I decided to build my own.
I used my existing hardware, but separated each component out and mounted them on a Perspex/Plexiglass plate. Each plate is backlit with LED's and mounted on a piece of framed and vinyl-clad hardboard.
2 months, around 20 individual shipments of components from three different continents, and countless hours of hard work later, 'The RecoilMachine' is ready and hanging on my wall. thumb.gif
I have also uploaded a video of the rig onYouTube: http://www.youtube.com/watch?v=EXiyYCbPrt0
The water-cooling system is a simple loop that covers both GPUs and the CPU, and bleeds the heat through one 360mm radiator wih three 120mm fans running at 1200 rpm. The pump is running at its lowest setting, which is still easily enough to keep temperatures down. Consequently, the whole system is very quiet.
Idle temps for CPU and GPUs are 38 C, and 32 C respectively.
Load temps for CPU and GPUs are 63 C, and 68 C respectively.
The temperature of the water in the loop never exceeds 30 C.
◄ Main System specs ►
Gigabyte EX58-UDP5 (Rev 1.0)
Intel Core i7 920, 2.66 GHz
Asus GTX 590 1.5GB
Samsung 250GB SSD 840 EVO SSD
Western Digital 1TB Caviar Black Hard Drive
Seagate 1TB Hard drive
◄ Water cooling specs ►
Aquacomputer Cuplex Kryos Delrin CPU water block
Alphacool Laing D5 Vario Pump
Monsoon Series Two Dual 5.25in Reservoir
Alphacool NexXxoS NVXP NV 590 Series GPU water block
Phobya G-Silent 12 1200rpm Fans, Black Silent Edition
Black Ice GTS-Lite 360 Radiator
Masterkleer Tubing PVC 19/13mm
19/13mm Compression Fitting 45° Rotary G1/4
19/13mm Compression Fitting 90° Rotary G1/4
The system is overclocked around 30% using a simple BCLK and voltage buff in the BIOS.
Recoil P is offline
post #2 of 65 (permalink) Old 02-14-2014, 12:08 PM
Rep: 365 (Unique: 250)
stainless steel tubing! lol
jk
looks awesome.
Master__Shake is offline
post #3 of 65 (permalink) Old 02-14-2014, 12:09 PM
Linux Lobbyist
skruffs01's Avatar
Rep: 14 (Unique: 13)
skruffs01 is offline
post #4 of 65 (permalink) Old 02-14-2014, 12:35 PM
SlvrDragon50's Avatar
Rep: 58 (Unique: 43)
Wow, pretty good temps for only a 360mm rad.
Looks beautiful.
SlvrDragon50 is offline
post #5 of 65 (permalink) Old 02-14-2014, 12:36 PM - Thread Starter
Recoil P's Avatar
Rep: 5 (Unique: 5)
Recoil P is offline
post #6 of 65 (permalink) Old 02-14-2014, 12:38 PM
RushiMP's Avatar
Rep: 37 (Unique: 32)
Very nice.
Why build one when you can have two at twice the price?
-S.R. Hadden
RushiMP is offline
post #7 of 65 (permalink) Old 02-14-2014, 12:40 PM
Twitch Streamer
Aesthethc's Avatar
Rep: 104 (Unique: 79)
i7-3930k 4.5GHz | EVGA GTX 1080Ti | 1440p 144hz IPS | Cooled by EKWB
PU:BG & Twitch - FarmerMeoow
Aesthethc is offline
post #8 of 65 (permalink) Old 02-14-2014, 12:58 PM
Ghost12's Avatar
Rep: 131 (Unique: 79)
Awesome, looks great.
4770K - Asus Maximus Gene Z87 - Patriot Black Mamba 2133 8Gb - Ocz Fatality 750w - Coollaboratory Liquid Alpheos Cpu Block - Xspc Rx 360 Radiator- Hardware Labs Black Ice Radiator 240 - XSPC D5 Vario - Aqua Computer Glass Tube Res - Mayhems Tharsis red - 6 Corsair SP120 - 2 Corsair AF120 Air Series - 1 140mm Enemax Everest - Nzxt H440 - Intel 330 120Gb - Ocz agilty 3 120Gb - 1Tb Toshiba 7200 64mb Hdd.
Gtx Titan X
Ducky Shine 3 Tkl - Cherry Black - Zowie Fk1 - Steel Series Qck Heavy
Asus Rog Swift X 3 , 7680 X 1440 p @144hz - 7" Samsung usb monitor.
FiiO E17 Dac - Audio Technica AD700X - Audio Technica M50 - Edifier R1600T Studio Monitors
Rseat Rs1 Custom - Srh Tach Dash - Accuforce pro - Momo mod 30 - He pedals pro - Fanaec sq 1.5 - Srh g-force display - He sequential. Earth magnet snap action shifters
Ghost12 is offline
post #9 of 65 (permalink) Old 02-14-2014, 01:33 PM
Citna's Avatar
Rep: 0
Wow, that looks great nice work.
Citna is offline
post #10 of 65 (permalink) Old 02-14-2014, 01:37 PM
Aint da way it used to be
Jolly Roger's Avatar
Rep: 172 (Unique: 147)
Its my dream to someday do something like that. Ultimate way to display a PC.
Jolly Roger is offline
