OCN Aquaero Owners Club - Page 1249 - Overclock.net - An Overclocking Community
post #12481 of 12489 (permalink) Old 03-08-2019, 05:42 AM
Tetrapyloctomist
Aenra's Avatar
Rep: 17 (Unique: 16)
Have you tried what dundys' suggested to you in the AC's forums?
It's good advice and you should follow it for everything Aquabus-aware. Aquasuite should be last, after each component has been set up on its own (as in separately, standalone; not Aquaero integrated)
Pride, honour and purity.
Aenra is offline
post #12482 of 12489 (permalink) Old 03-08-2019, 07:37 AM
Syberon's Avatar
Rep: 0
Thanks. I doesn't saw second answer in AC forum. Now i tried that dundy suggest and it helped.
Syberon is offline
post #12483 of 12489 (permalink) Old 03-08-2019, 10:53 PM
Big Radiators!
war4peace's Avatar
Rep: 16 (Unique: 15)
I have a question regarding Aquaero's relay function, which I never used yet.
Recently bought a slow-rotating 12VDC motor which I will use for my future steampunk project. I have connected it directly to a PSU for testing purpose ad it works, however when I shut down my PSU, the motor continues drawing current from the 12VDC rail until the PSU capacitors empty, and then the PSU won't start anymore unless unplugged from power for a long time (I had to leave it unplugged overnight).
So I am hoping to use Aquaero's relay function to cut the power from the motor as soon as the PC is shutdown. How could I achieve that?
My Rig Temps in Real Time
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
Gigabyte 1080 Ti Waterforce Extreme Edition 11Gbps
Kingston HyperX 2x 16GB DDR4 3000MHz
SSD Samsung 850 EVO 1TB
SSD ADATA 512 GB
Patriot Hellfire 240 GB M.2 SSD nVME
Super Flower Leadex Gold 750W
Corsair AX860
Custom Loop, EKWB, CPU+GPU, soft tubing
Thermaltake Core X5
Operating System
Windows 10 Professional X64
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
war4peace is offline
post #12484 of 12489 (permalink) Old 03-10-2019, 03:14 PM
Shawnb99's Avatar
Rep: 5 (Unique: 4)
The Pressure equalisation membrane makes leak testing by air impossible?
Shawnb99 is offline
post #12485 of 12489 (permalink) Old 03-11-2019, 10:13 AM
WaterCooler & Overclocker
Barefooter's Avatar
Rep: 104 (Unique: 88)
Take it out and put a stop plug there until your testing is done.
Barefooter is offline
post #12486 of 12489 (permalink) Old 03-11-2019, 10:24 AM
Shawnb99's Avatar
Rep: 5 (Unique: 4)
Thanks. That’s what I’m going to do.
Shawnb99 is offline
post #12487 of 12489 (permalink) Old 03-14-2019, 12:53 PM
Tetrapyloctomist
Aenra's Avatar
Probably a dumb question, but.. is there any way to check when your AQ was manufactured?
Aenra is offline
post #12488 of 12489 (permalink) Unread 03-14-2019, 05:27 PM
skupples's Avatar
Rep: 508 (Unique: 283)
pretty sure I saw that info when I was renewing my license on their site.
skupples is offline
post #12489 of 12489 (permalink) Unread 03-14-2019, 08:52 PM
Umm, How Bout Noooooo.
Cyber Locc's Avatar
Rep: 107 (Unique: 75)
Hey guys anyone have an idea how to semi easily do something like this? Or someone that can make it?
https://scontent-ort2-2.cdninstagram...ninstagram.com
I would prefer Aluminum, but settle for acrylic if there is something like this already sold.
Or if anyone has devised a way to remotely locate the Screen that would be even better. Doesn't have to be much, but a few inches would be amazing.
Edit: I found this, https://m.imgur.com/gallery/nUxV2
Down in the log, there is pics. He soldered a ribbon cable from the Board to the Screen. I suck at soldering, I can't see the pin setup in there, but any chance of anyone knowing anyone how could make a cable like that? I'll pay 🙂.
Favorite OCN Quotes (Click to show)
You are just talking more and more nonsense now. It's time to take this back to whatever noob forum it came from.
____________________________________________________________________________________________________________________
Cyber Locc is offline
