OCN Aquaero Owners Club - Page 1259 - Overclock.net - An Overclocking Community
post #12581 of 14072 (permalink) Old 05-16-2019, 12:01 AM
professional curmudgeon
looniam's Avatar
Rep: 836 (Unique: 465)
Quote: Originally Posted by iamjanco View Post
Couldn't you make your own cables? This thread (RGBpx wiring Diagram) at AC might help. It has links in it to the correct Molex parts (1.25mm Pitch PicoBlade Wire-to-Wire and Wire-to-Board Housing, Female, 4 Circuits) you would need, as well as pre-built cables that might work.
Also, if you're going to go diy and make your own, the hand crimp tool for 1.25mm Pitch PicoBlade Female Crimp Terminals, 26-32 AWG looks like the correct one to use. Like other Molex crimp tools, it is expensive though (~$350 or so, give or take)
Not sure how well other crimp tools might work.
just a thought after following that hand crimp tool link . .
https://www.molex.com/molex/products...ble_assemblies
lead to both (through digi key)
https://www.digikey.com/products/en?...ords=797580014
https://www.digikey.com/products/en?...ords=797580006
could some thing like those work (depending on length?)
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
If you need help:
Upload the computer to Dropbox and provide a link to it so others may download it to examine and give advice for repairs.
*this post has been sponsored by Pabst Blue Ribbon.*
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is offline
post #12582 of 14072 (permalink) Old 05-16-2019, 11:37 AM
Taking a break
iamjanco's Avatar
Rep: 145 (Unique: 66)
Yes, there's a fairly strong possibility of that as long as the terminals used in the wider connector housing are also picoblades.
For reference purposes:
Molex 63827-1400 Crimper Application Tooling Specification
Pre-made Cable drawing (multiple cable options shown)
Picoblade pre-made cables; 152mm and 304mm (150/300) lengths
Muffler Bearings
(24 items)
i9-7900X, i9-10940x
Asus Rampage VI Extreme
EVGA X299 DARK
EVGA GeForce RTX 2080 Ti XC
(2 ea) EVGA GTX 1080 Ti FTW3
G.SKILL F4-3200C14Q2-64GTZ
(2ea) Intel Optane 900P (480GB)
(2ea) Samsung 850 Pro 1TB
(2ea) Samsung 850 Pro 256GB
(2ea) Samsung 970 Pro 512GB
(1ea) Samsung 950 Pro 256GB
EVGA SuperNOVA 1600 T2
Custom water
Custom, 8020x3060 and x2020
Operating System
Win 10 Pro/Ubuntu
NEC PA272W-BK-SV
Eizo ColorEdge CE240W
Alienware AW3418DW
Keyboard
Ergodox EZ with Kailh Thick Gold (Bronze) and Copper switches
Audio
Bottlehead Mainline Amp
Audio
RME ADI-2 Pro FS 2-in/4-out AD/DA Converter
Audio
FOCAL Clear Professional Headphones
Audio
Mr. Schpeakers ETHER C Flow 1.1 Headphones
Other
Protectli Firewall Micro Appliance With 6x Intel Gigabit Ports, Intel i5 7200U, AES-NI
Other
Misc. see build description for details
iamjanco is offline
post #12583 of 14072 (permalink) Old 05-17-2019, 06:22 AM
Big Radiators!
war4peace's Avatar
Rep: 33 (Unique: 27)
Quote: Originally Posted by skupples View Post
flow weak with 4 pumps?
I'd definitely split your loop up, & try to remove as many 90s as humanly possible.
At one point I had 4 60mm 480s, 3 gpu, cpu, memory, chipset, & still maintained 200lp/h cuz I used next to no 90s.
I have the same question. I have a friend who uses one pump in a GPU+CPU setup with externally-located MoRa 420 and he doesn't have a flow issue, even with QDCs an several 90 degrees. Another friend has a setup with CPU+GPU and two EKWB XE360 radiators, all in series, and his flow is 240 l/minute. My setup, with 2x 1080 Tis in SLI and a monoblock, with 2x EKWB D5 pumps in a volute (in series) has more than enough flow, as you can see in my sig (cca 330 L/h).
My Rig Temps in Real Time
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
Gigabyte 1080 Ti Waterforce Extreme Edition 11Gbps
Kingston HyperX 2x 16GB DDR4 3000MHz
SSD Samsung 850 EVO 1TB
SSD ADATA 512 GB
Patriot Hellfire 240 GB M.2 SSD nVME
Super Flower Leadex Gold 750W
Corsair AX860
Custom Loop, EKWB, CPU+GPU, soft tubing
Thermaltake Core X5
Operating System
Windows 10 Professional X64
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
war4peace is offline
post #12584 of 14072 (permalink) Old 05-17-2019, 06:58 AM
Shawnb99's Avatar
Rep: 60 (Unique: 41)
I also have flow issues.
When I was able to check my flow I was only getting 1.1GPM with both pairs of pumps at 100%. I have at most 4-6 90 degree bends and 3 QDC4’s yet I still have flow.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #12585 of 14072 (permalink) Old 05-17-2019, 11:56 AM
Big Radiators!
war4peace's Avatar
You should check your radiators for blockages. This happens more often than thought, I encountered a couple cases myself.
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
SSD ADATA 512 GB
Corsair AX860
Thermaltake Core X5
Operating System
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
post #12586 of 14072 (permalink) Old 05-17-2019, 03:39 PM
Shawnb99's Avatar
My Radiators are brand new so no blockages, I think my issues it from the 90 degree bends and the QDC’s. I’ll have to get more creative with my tube routing.
My Baby
(23 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
post #12587 of 14072 (permalink) Old 05-17-2019, 03:48 PM
GTXJackBauer's Avatar
Rep: 22 (Unique: 21)
Could be radiators if they weren't cleaned prior to installation or buildup over time. Other than that, I agree that the bends actually add up.
I personally witnessed it myself the last few months since I upgraded my DDC's since one of them died of age and had them replaced with two EK D5 G2s in serial. My DDC's needed 40% PWM to flow @ 1.0 GPM. My D5s atm need 90-95%+ to be around 1.0 GPM and I only max out at 1.1 GPM @ 100% when my DDCs went even further than that. Here's the thing though. I went from dual GPUs in SLI to a new single GPU during the new pump installation. You would think my loop should be less restrictive right? What happened you asked? I added another 3-4 90 degree bends. From a total of 14 fittings, I use 4 straights (2 straight barbs for flow meter) and the rest are bends and to be exact, 7 are 90 degrees.
My High Flow meter used to lay flat but now it's facing horizontal upward or vertical instead of it's bottom or back so I'm not sure if that's the cause of the readings I'm getting but the addition bends I had added to the loop and repositioning of the flow meter is when I noticed the flow change knowing the DDCs (35X) have great head pressure compared to the D5s.
ll Corsair 900D ll Intel Core i7-5930K @ 4500.0MHz on HWBOT ll EVGA X99 Classified ll Crucial Ballistix Sport 2400MHz 16GB ll Aquaero 6 XT ll EVGA GTX 780 Classified 3GB Hydro Copper (x2 in SLI) ll Samsung XP941 512GB PCI-E 2.0 x4 M.2 SSD ll WD VelociRaptor 10k RPM 300GB - x2 ll WD Black 1.5TB - x2 ll Toshiba 3TB ll Corsair AX1200i ll ASUS VS248H-P 24" 2ms LED - x3 - Nvidia Surround ll Bose Companion 5 ll
ll Custom Swiftech XL ll Black Ice SR-1 240mm+360mm+480mm ll Helix120 (PWM) ll Swiftech Maelstrom-35X2 ll Aqua Computer High Flow Sensor ll Phobya Temp Sensor Coupler ll Bitspower Compression Fittings (1/2 ID 3/4 OD) ll PrimoChill Advanced LRT 1/2 ID 3/4 OD (Bloodshed Red) ll
GTXJackBauer is offline
post #12588 of 14072 (permalink) Old 05-17-2019, 03:57 PM
Shawnb99's Avatar
Yeah it’s likely all the 90 degree bends and all the other assorted bends. I may have gone a little overboard stuffing 4 rads, and cooling the GPU, CPU and MB, the CPU to MB is just a PIA to connect without bends. By not cutting the case I’ve limited myself. I’ll do another tear down at a later date and see if I can route a bit better. I’m happy with the flow at 100% for now.
My Baby
(23 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
post #12589 of 14072 (permalink) Old 05-18-2019, 12:59 AM
Big Radiators!
war4peace's Avatar
The 90 degrees don't add as much restriction as generally believed. The heaviest restriction is in the waterblocks and radiators. Especially if the whole circuit is in series.
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
SSD ADATA 512 GB
Corsair AX860
Thermaltake Core X5
Operating System
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
post #12590 of 14072 (permalink) Old 05-18-2019, 04:49 AM
InfoSeeker's Avatar
Rep: 46 (Unique: 38)
New aquasuite update:
Changelog
Download
InfoSeeker is offline
