OCN Aquaero Owners Club - Page 1261 - Overclock.net - An Overclocking Community
post #12601 of 14069 (permalink) Old 05-22-2019, 04:09 AM
Shawnb99's Avatar
Rep: 60 (Unique: 41)
Lol I’m not trying to. I’m just to strong for my own good.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #12602 of 14069 (permalink) Old 05-22-2019, 06:41 AM
Big Radiators!
war4peace's Avatar
Rep: 33 (Unique: 27)
Quote: Originally Posted by jsutter71 View Post
Interesting. I've never tried that before. My only issue would be adding addition tubing in tight spots.
Use extensions such as this one. Of course, this solution only works if the build allows it, I have tried it, worked very well, but I had both radiators next to each other in a Thermaltake Core X5.
My Rig Temps in Real Time
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
Gigabyte 1080 Ti Waterforce Extreme Edition 11Gbps
Kingston HyperX 2x 16GB DDR4 3000MHz
SSD Samsung 850 EVO 1TB
SSD ADATA 512 GB
Patriot Hellfire 240 GB M.2 SSD nVME
Super Flower Leadex Gold 750W
Corsair AX860
Custom Loop, EKWB, CPU+GPU, soft tubing
Thermaltake Core X5
Operating System
Windows 10 Professional X64
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
war4peace is offline
post #12603 of 14069 (permalink) Old 05-22-2019, 08:28 AM
Shawnb99's Avatar
I think two of my Quadros are now dead. Can’t get either to register the fans or anything connected to it. Nothing shows up in Aquasuite.
I’m so frustrated with these things never working right, damn cables break so easily.
I thinks it time to find another fan controller and give up on all AQ gear. So frustrating
My Baby
(23 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
Shawnb99 is offline
post #12604 of 14069 (permalink) Old 05-22-2019, 12:04 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 734 (Unique: 386)
sli extenders + what's linked above are great for cross connecting rads in tight spaces.
Add me on Steam, same name
skupples is offline
post #12605 of 14069 (permalink) Old 05-22-2019, 02:21 PM
Big Radiators!
war4peace's Avatar
Yup, I use them all the time.
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
SSD ADATA 512 GB
Corsair AX860
Thermaltake Core X5
Operating System
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
post #12606 of 14069 (permalink) Old 05-25-2019, 12:46 AM
Vlada011's Avatar
Rep: 39 (Unique: 29)
I have question about Aqua Computer D5 Next.
I saw that flow sensor should be calibrated before start to work.
How? to install him on reservoir out of PC and connect outlet with inlet port and start him?
That part is little confused I see some people didn't even tried to calibrate him.
And what happen if you success to calibrate him out of loop? You need again to calibrate when you install loop and enable system to work?
Because I follow experience of D5 Next owners. Mostly because fit on Heatkiller Tube D5 and because no Power Cables.
I'm not sure only is it possible Aqua Computer 120mm Mounting Bracket who hold D5 Next to hold and Heatkiller 100 reservoir full of liquid, risky?
Vlada011 is offline
post #12607 of 14069 (permalink) Old 05-25-2019, 03:58 AM
GAN77's Avatar
Rep: 2 (Unique: 2)
How?
Calibration process:
1. The system has to be perfectly deaerated, no bubbles or foam visible in the
coolant.
2. Coolant temperature should be between 25 °C and 35 °C.
3. Ensure that the computer is currently idle and no high-load background
tasks are currently active. During calibration, no coolant is pumped through
the system!
4. Block coolant flow by kinking a hose or closing a stop valve in the coolant
loop.
5. Start the calibration process either using the aquasuite or the device menu.
6. Wait for the calibration process to complete. The process takes approximately 30 seconds. If errors occur or if the calibration process has not finished after 60 seconds, immediately proceed to the next step.
7. Restore coolant flow. Ensure no hoses are kinked and stop valves if present
are fully opened.
Limitations: Flow rate can not be calculated if a second pump is present in the
cooling circuit! Flow rate calculation is calibrated for DP Ultra viscosity and will
deviate when using other coolants ore pure water!
GAN77 is offline
post #12608 of 14069 (permalink) Old 05-25-2019, 06:47 AM
Vlada011's Avatar
Wow, that's not process I would like to do.
But keeping empty field Flow as I saw in software it's BAD.
Is it possible to calibrate out of PC ant than to install inside loop and to work?
Because installation of Ball Valve in loop need completely different configuration and later drain and remove Ball Valve on proper place where no influence on flow and only serve as drain port.
Vlada011 is offline
post #12609 of 14069 (permalink) Old 05-25-2019, 09:34 AM
Big Radiators!
war4peace's Avatar
Just get a mechanical flow meter and be done with it.
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
SSD ADATA 512 GB
Corsair AX860
Thermaltake Core X5
Operating System
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
post #12610 of 14069 (permalink) Old 05-25-2019, 12:53 PM
Shawnb99's Avatar
No need to add a ball valve, a QDC should have the same effect. Disconnecting the QDC should work.
Main issue with the non MPS sensors is you can only install them horizontal or they can rattle.
My Baby
(23 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
Shawnb99 is offline
