OCN Aquaero Owners Club - Page 1280 - Overclock.net - An Overclocking Community
post #12791 of 14063 (permalink) Old 06-17-2019, 04:44 AM
rolandos582's Avatar
Rep: 1 (Unique: 1)
Quote: Originally Posted by GTXJackBauer View Post
The Cali temp is a premium sensor for accuracy. It's a bit more and needs a X4 adapter to be installed on the back of the AQ6.
Ah right, I just ordered the normal ones then. It's not that bad, i just want to have a rough idea on what the water temps are compared to the ambient temps etc.
rolandos582 is offline
post #12792 of 14063 (permalink) Old 06-17-2019, 05:34 AM
Shawnb99's Avatar
Rep: 60 (Unique: 41)
The calitemps are said to be more accurate but I have both those and the normal ones and rarely see much of a difference. Is at most a few percentage points off
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #12793 of 14063 (permalink) Old 06-17-2019, 05:53 AM
NewUser16's Avatar
Rep: 56 (Unique: 37)
Quote: Originally Posted by war4peace View Post
Yes, with the mention that each device hub uses up one available port (kind of like a car's driver uses up a place in the car), so for example if you have 50 hubs in a PC, you will be able to connect 77 devices maximum.
Thanks
NewUser16 is offline
post #12794 of 14063 (permalink) Old 06-17-2019, 06:58 PM
Rep: 1 (Unique: 1)
Im gonna do some sleeving on my aquacomputer d5 pwn. For the pwm signal, would it be best to go for a 2pin or 4pin connector when youre connecting them to a quadro?
post #12795 of 14063 (permalink) Old 06-17-2019, 09:05 PM
Shawnb99's Avatar
PWM Signal needs a 4 pin cable. 2 pin is for temp sensors
My Baby
(23 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
Shawnb99 is offline
post #12796 of 14063 (permalink) Old 06-18-2019, 08:16 AM
WaterCooler & Overclocker
Barefooter's Avatar
Rep: 125 (Unique: 102)
Use a 4 pin connector, and if you put terminals in the two blank cavities of the connector body it helps keep the connector plugged in more firmly
Devastator
(14 items)
Secondary Rig
i9-7900X
Asus Rampage Extreme VI
2x EVGA 2080Ti XC Gaming
G.Skill TridentZ Royal 32GB 3600 16-16-16-36
Intel Optane SSD 480GB
Samsung 850 EVO 2TB
2x Seagate Iron Wolf Pro 12TB
EVGA SuperNOVA 1600 T2
Hardware Labs Black Ice SR2 Radiators 4x 560mm + 2x 280mm
Aquacomputer Aquaero XT + Aquaero LT
2x Aquacomputer D5s with custom chrome plated Bitspower mod kits
2x Aquacomputer Aqualis 880ml Reservoirs with Nano Coating & Aquabus Interface
CaseLabs THW10 with Custom Powder Coating
Operating System
Windows 10 Pro
Intel Core i7-4790K
Asus Maximus Extreme VI
EVGA GTX 980 ti Classified
G.SKILL Trident X Series 32GB (4 x 8GB) DDR3 2400
Samsung 850 Pro 500GB
Seagate Desktop HDD 4TB
EVGA SuperNOVA 1300 G2
EK 420 Rad + EK 280 Rad
Corsair 750D
Operating System
Microsoft Windows 10 Pro 64-bit
Acer XB271HU
Keyboard
Microsofte Natural Ergonomic 4000
Mouse
Logitech G502
Barefooter is offline
post #12797 of 14063 (permalink) Old 06-18-2019, 11:53 AM
Rep: 1 (Unique: 1)
Use a 4 pin connector, and if you put terminals in the two blank cavities of the connector body it helps keep the connector plugged in more firmly [IMG class=inlineimg]/forum/images/smilies/thumb.gif[/IMG]
Makes sense! Thanks boys!
Is there any limitations that the quadro cant do but the aquaero can? Thought i heard something about that but i cant find it
post #12798 of 14063 (permalink) Old 06-18-2019, 01:07 PM
Moose-Tech's Avatar
Rep: 9 (Unique: 9)
That is very cool and creative!
Gave you your first Rep+ for that
Thanks!
Build: Z390 ACE
Core i9-9900K OC 5 GHz, MSI Z390 ACE Mobo, AMD Radeon VII GPU OC 2K MHz
Corsair Vengeance RGB 32GB 3200 RAM, Phanteks Enthoo Pro M SE.
EKWB Z390 ACE Monoblock, Bykski Radeon VII GPU w/b, 2x EKWB 140 Revo D5 Pump & Res.
Aquacomputer Aquaero 6 LT USB Fan-Controller, Quadro, Vision Touch and 'High Flow' Sensor.
(2x) HWL Black Ice Nemesis 280 GTS XFLOW and (1x) Alphacool XT45 X-Flow 280 radiators.
Moose-Tech is offline
post #12799 of 14063 (permalink) Old 06-18-2019, 01:45 PM
Moose-Tech's Avatar
Rep: 9 (Unique: 9)
I see, ideally you want 4 water temp sensors? in and outtake for both radiators?
And then you have a few normal tempetature sensors, do you just use those for ambient, intake and outtake air tempetature?
Sorry for all these questions boys! I've been watercooling for about 2.5 years now but so many things are still new to me!
EDIT : nvm, you just use the sensors ofcourse.
I was lucky in that my loop worked out so that my flow goes through both of my crossflow radiators before going to my CPU and then GPU.
LOOP TEMP SENSORS: I was able to put one sensor before the rads and one after. I think they were Barrow G1/4 cap sensors that I mounted into a 3 way connector. (RAD IN and RAD OUT)
AMBIENT TEMP SENSOR (Flat K2 sensor): I originally mounted one in front of my intake fans in the front of the case. This worked great until the radiator got hot and the sensor picked up the radiant heat and went up about 3 degrees C. (AMBIENT INTAKE)
I was hoping for a little more accuracy. I already had a Vision touch and ordered the 5cm ambient sensor for that. Since this is mounted outside my case it displays true room ambient. This is the temp I wanted to use. (AMBIENT ROOM)
VIRTUAL SENSORS: I created one to average out my RAD IN and RAD OUT sensors to calculate my average LOOP TEMP.
Then I created one that calculates the difference between AMBIENT ROOM and LOOP TEMP. This one is LOOP DELTA_T.
Then I created one to calculate the difference between my RAD IN and RAD OUT sensors to get an idea how much heat I was removing. This one is RAD DELTA_T. BTW - Biggest diff I seen here was about 1.8 degrees C before the loop stabilized. Then it typically runs about 1 degree C.
I may add one more ambient sensor to the interior of my case just to see what the air temp is like inside.
LOOP DELTA_T is what I am currently using to run my fan curves.
The biggest Temp difference I seen on the loop was 16.2 degrees C while I was running Furmark 3D at 4K and also running Heavy Load at the same time. In 30 degree C Ambient.
My curves (and my Vision RGB Ball) are based on that max difference.
Good Luck!
Build: Z390 ACE
post #12800 of 14063 (permalink) Old 06-18-2019, 11:10 PM
Big Radiators!
war4peace's Avatar
Rep: 33 (Unique: 27)
Some advice...
1. Setting up fan curves according to various temperatures is always a subjective choice, however choosing the delta T between ambient and average between RAD IN and RAD OUT is a bit strange. That is because both the average between values and the ambient temperature are variable therefore you won't ensure component cooling is consistent. I'm not saying it won't work, but it would not give consistent results unless you have AC on and it controls room ambient very well. Otherwise when your room temperature increases, the components will get hotter because the liquid will get hotter as well. Instead, I would advice you to set up a set point controller which has RAD IN as input and fan speed as output with target value at 40 degrees Celsius.
2. If you have a flow meter you can have Aquasuite calculate radiator power dissipation, handy to determine how well do your radiators dissipate heat.
My Rig Temps in Real Time
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
Gigabyte 1080 Ti Waterforce Extreme Edition 11Gbps
Kingston HyperX 2x 16GB DDR4 3000MHz
SSD Samsung 850 EVO 1TB
SSD ADATA 512 GB
Patriot Hellfire 240 GB M.2 SSD nVME
Super Flower Leadex Gold 750W
Corsair AX860
Custom Loop, EKWB, CPU+GPU, soft tubing
Thermaltake Core X5
Operating System
Windows 10 Professional X64
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
war4peace is offline
