OCN Aquaero Owners Club - Page 1298 - Overclock.net - An Overclocking Community
post #12971 of 13002 (permalink) Old 08-24-2019, 09:02 AM
WaterCooler & Overclocker
Barefooter's Avatar
Rep: 117 (Unique: 98)
Quote: Originally Posted by Moose-Tech View Post
I think I remembered reading this in a forum somewhere (but can't remember where now).
If the Splitty9 needs more amps than you want to pull from the AQ6, You can always mod a standard fan extension cable by removing the 12v power wires.
Then get a molex or sata power splitter that has fan headers. Carefully remove the pins from the fan headers from their sockets and then re-insert them (in the proper order) to the fan extension cables.
This will alow you to power the Spltty9 from your 12v rails but use the RPM signal from the PWM header on the AQ6. Just like you do with your water pump.
BTW - This will also allow your AQ6 to run a little cooler without all that fan wattage being run through it.
Got some Splitty9's for my next build and was going to mod this cable up myself.
That is what I did I made custom cables where I used two PCI ports off of the power supply, each powering two Splitty9s. The red and black cables are the power and ground respectively. I put both the RPM and PWM wires into one grey sleeve and ran those over to the Aquaeros.
Devastator
(14 items)
Secondary Rig
i9-7900X
Asus Rampage Extreme VI
2x EVGA 2080Ti XC Gaming
G.Skill TridentZ Royal 32GB 3600 16-16-16-36
Intel Optane SSD 480GB
Samsung 850 EVO 2TB
2x Seagate Iron Wolf Pro 12TB
EVGA SuperNOVA 1600 T2
Hardware Labs Black Ice SR2 Radiators 4x 560mm + 2x 280mm
Aquacomputer Aquaero XT + Aquaero LT
2x Aquacomputer D5s with custom chrome plated Bitspower mod kits
2x Aquacomputer Aqualis 880ml Reservoirs with Nano Coating & Aquabus Interface
CaseLabs THW10 with Custom Powder Coating
Operating System
Windows 10 Pro
Intel Core i7-4790K
Asus Maximus Extreme VI
EVGA GTX 980 ti Classified
G.SKILL Trident X Series 32GB (4 x 8GB) DDR3 2400
Samsung 850 Pro 500GB
Seagate Desktop HDD 4TB
EVGA SuperNOVA 1300 G2
EK 420 Rad + EK 280 Rad
Corsair 750D
Operating System
Microsoft Windows 10 Pro 64-bit
Acer XB271HU
Keyboard
Microsofte Natural Ergonomic 4000
Mouse
Logitech G502
Barefooter is offline
post #12972 of 13002 (permalink) Old 08-24-2019, 08:26 PM
InfoSeeker's Avatar
Rep: 39 (Unique: 31)
Quote: Originally Posted by Jubijub View Post
[snip]
In your case, what is the link between the two ? USB or Aquabus ?
[snip]
In this build I used NO aquabus, all communications are USB. Primarily because I believe you loose the fan & RGBpx controllers on the quadro with the aquabus connected.
Quote: Originally Posted by VeritronX View Post
There's an aquasuite service running in the background passing info through the pc.
This is the kicker... I believe this is a Windows service that aquasuite uses, if Linux emulates it, then you may be OK, if not, ???.
It may be worth your effort to shoot an email to support at aquacomputer.de
InfoSeeker is offline
post #12973 of 13002 (permalink) Old 08-25-2019, 08:30 PM
skupples's Avatar
Rep: 544 (Unique: 309)
that's not a bad idea...
I think I'll stick to molex going forward. These BP SATA + PWM/tach hub is always pegged @ 100% no matter what i do.
skupples is online now
post #12974 of 13002 (permalink) Old 08-26-2019, 11:03 PM
Moose-Tech's Avatar
Rep: 4 (Unique: 4)
I use HWiNFO64 v6.10-3880
Set to run at startup and display sensors in minimized mode. Always running.
It's nice because it starts up and syncs up with Aquasuite very quickly.
Build: msi C8r (Carbon8r)
Core i7-9700K OC 5 GHz, MSI Z390 GAMING PRO CARBON Mobo, AMD Radeon VII GPU OC 2K MHz, Corsair Vengeance RGB 32GB DDR4-3200 RAM, Phanteks Enthoo Pro M SE ATX Case.
XSPC RayStorm Pro CPU w/b, Bykski Radeon VII GPU w/b, EKWB 140 Revo D5 Pump & Res.
Aquacomputer Aquaero 6 LT USB Fan-Controller, Vision Touch and 'High Flow' Sensor.
(2x) Hardware Labs Black ice Nemesis 280GTS XFLOW radiators and (1x) Alphacool NexXxoS XT45X-Flow 140 in full push/pull.
Moose-Tech is offline
post #12975 of 13002 (permalink) Old 09-09-2019, 07:06 AM
GAN77's Avatar
Rep: 2 (Unique: 2)
Good day! Can I rotate the black ring in the Calitemp digital temperature sensor to position the connector?
Name:	Снимок экрана (1274).jpg
GAN77 is online now
post #12976 of 13002 (permalink) Old 09-09-2019, 08:19 AM
Shawnb99's Avatar
Rep: 22 (Unique: 14)
Yep you can rotate it as much as you like. As long as it sits flat when done you should be able to move it as needed. Be careful with the cables though, they are very very thin and break easily. I'd suggest not connecting the cables till you have everything set up.
My Baby
(24 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
2x Swiftech MCP35X2 with MCP35X2 Heat Sink
2x Hardware Labs Black Ice Nemesis 360GTR
2x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
2x Noctua NA-A15 PWM
24x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Shawnb99 is offline
post #12977 of 13002 (permalink) Old 09-09-2019, 09:19 AM
GTXJackBauer's Avatar
Rep: 20 (Unique: 20)
+1
ll Corsair 900D ll Intel Core i7-5930K @ 4500.0MHz on HWBOT ll EVGA X99 Classified ll Crucial Ballistix Sport 2400MHz 16GB ll Aquaero 6 XT ll EVGA GTX 780 Classified 3GB Hydro Copper (x2 in SLI) ll Samsung XP941 512GB PCI-E 2.0 x4 M.2 SSD ll WD VelociRaptor 10k RPM 300GB - x2 ll WD Black 1.5TB - x2 ll Toshiba 3TB ll Corsair AX1200i ll ASUS VS248H-P 24" 2ms LED - x3 - Nvidia Surround ll Bose Companion 5 ll
ll Custom Swiftech XL ll Black Ice SR-1 240mm+360mm+480mm ll Helix120 (PWM) ll Swiftech Maelstrom-35X2 ll Aqua Computer High Flow Sensor ll Phobya Temp Sensor Coupler ll Bitspower Compression Fittings (1/2 ID 3/4 OD) ll PrimoChill Advanced LRT 1/2 ID 3/4 OD (Bloodshed Red) ll
GTXJackBauer is offline
post #12978 of 13002 (permalink) Old 09-09-2019, 09:46 AM
GAN77's Avatar
Rep: 2 (Unique: 2)
Guys, thanks for the answers!
When I turned it, I did not like the sound. I thought I tore off the thermal sensor soldered to the fitting)
But the sensor is working)
Who has two such sensors in the system, what is the difference in temperature between them the first time they were connected without a callibro?
GAN77 is online now
post #12979 of 13002 (permalink) Old 09-09-2019, 10:12 AM
Shawnb99's Avatar
I have 4 Calitemp and 7 AQ Inline sensors in my loop. Temp difference between them is at most a degree if not less.
My Baby
(24 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
Shawnb99 is offline
post #12980 of 13002 (permalink) Old 09-09-2019, 11:32 AM
I use 2 calitemp sensors, one in the IN and the other on the OUT of my top radiator. Both less than a degree difference as well.
Don't worry about the noise because I almost had a heartache thinking I just destroyed two pricey temp probes. I spoke to AC and they told me it's fine. I thought I cracked a capacitor of some sort as there was liquid leaking from them with a crushing sound. It's normal they told me and turn it to your liking and plug the wiring after you're set as stated prior.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
GAN77
