OCN Aquaero Owners Club - Page 1335 - Overclock.net - An Overclocking Community
post #13341 of 13349 (permalink) Old 02-10-2020, 01:30 AM
Tech Enthusiast
oreonutz's Avatar
Rep: 66 (Unique: 45)
Quote: Originally Posted by sakete View Post
Very cool! Thanks for the detailed explanation. I just created that virtual software sensor. Couldn't figure out how to add it to the controller section, but then after playing around I saw that I needed to link it to a Software Sensor in the Sensors section, and then I could add that sensor to the controller.
Very powerful feature, will come in handy once I've done my first watercooling build. I like that I can create a rules-based sensor.
NP! Glad to help! I know its insane what you can do with the Aquaero and Aquasuite. It still blows my mind! Sorry, I forgot to detail the part about adding it to a software sensor before importing it, but I am glad you figured it out. How is the curve working for you? Not ramping up so sudden any more?
-MattTheTech
Offical Ryzen 9 3900x Owner!
Offical Ryzen 9 3950x Owner!
DodekaZen3000
(34 items)
Ryzen 9 3950x
ASUS Crosshair VII Hero
EVGA 1080ti FTW3 Hybrid
G.SKILL Flare X Series 32GB (4 x 8GB) 3200Mhz (PC4 25600) - F4-3200C14D-16GFX (x2 Kits)
Samsung 970 Pro 512GB
Samsung 970 Evo 1TB
Samsung 850/860 Evo (x3 Raid 0 Game Drive)
WD Black 4TB (x2 Raid 0 Storage Drive)
860 Evo
Optical Drive
LG Blu-Ray Burner (Model BH16NS40)
Optical Drive
5.25" to One 3.5" and One 2.25" Bay (Model Syba SY-MRA55006)
Corsair RM1000i
EKWB Phoenix 360mm Modular Cooler
280mm Alphacool UT60
280mm EKWB Coolstream CE
Optimus Foundation AM4 CPU Block
x2 Corsair Pump/Res Combo
EKWB Acrylic 1080ti FTW Block
Aquaero 6xt
Old Jonesbo Case
Operating System
Windows 10 Enterprise
Samsung NU8000 55Inch TV (Its a 4k TV But I run in it 1440p 120hz)
LG 1080p 34 Inch Diplay
Keyboard
Corsair k70 RGB Lux Mk2
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Custom Built 7.1 Surround System
Audio
HT-Omega eClaro 7.1 Sound Card
Audio
Focusrite Scarlett 18i20
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
10 ML120 + 6 ML140 Corsair Maglev Fans
Other
Phanteks Halo aRGB LUX x5
oreonutz is offline
post #13342 of 13349 (permalink) Old 02-10-2020, 07:45 AM
sakete's Avatar
Rep: 7 (Unique: 6)
Yeah, it's much more gentle. I mainly wanted to eliminate the fans from spinning up when there's a 2 second temperature spike, so I'm averaging the temp over 30 seconds and then averaging again with the real-time temperature, which works well so far. Will probably end up tweaking it a little.
So, are all these settings now stored in the actual Aquaero in hardware, or will Aquasuite always need to be running in the background to get this to work correctly?
i7-4790K @ 4.6GHz | Noctua NH-D15 | Asus Z97-Pro | G.Skill Ares 2x8GB DDR3-2400 | EVGA GS 1050W | EVGA GTX 980Ti SC+ with Kraken G10 + Kraken X31 | 480GB SanDisk Extreme Pro | 2x 4TB HGST Deskstar NAS RAID 1 | Corsair 750D | Corsair K70 MX-Brown | Logitech G502 | Acer XB270HU
sakete is online now
post #13343 of 13349 (permalink) Old 02-10-2020, 09:01 AM
GTXJackBauer's Avatar
Rep: 20 (Unique: 20)
If this is under the Aquaero tab, a little symbol shows up next to the text. If you click on it, it will save it to the controller's memory.
Also, make sure to save the profiles and possibly make a backup on another drive.
ll Corsair 900D ll Intel Core i7-5930K @ 4500.0MHz on HWBOT ll EVGA X99 Classified ll Crucial Ballistix Sport 2400MHz 16GB ll Aquaero 6 XT ll EVGA GTX 780 Classified 3GB Hydro Copper (x2 in SLI) ll Samsung XP941 512GB PCI-E 2.0 x4 M.2 SSD ll WD VelociRaptor 10k RPM 300GB - x2 ll WD Black 1.5TB - x2 ll Toshiba 3TB ll Corsair AX1200i ll ASUS VS248H-P 24" 2ms LED - x3 - Nvidia Surround ll Bose Companion 5 ll
ll Custom Swiftech XL ll Black Ice SR-1 240mm+360mm+480mm ll Helix120 (PWM) ll Swiftech Maelstrom-35X2 ll Aqua Computer High Flow Sensor ll Phobya Temp Sensor Coupler ll Bitspower Compression Fittings (1/2 ID 3/4 OD) ll PrimoChill Advanced LRT 1/2 ID 3/4 OD (Bloodshed Red) ll
GTXJackBauer is offline
post #13344 of 13349 (permalink) Old 02-11-2020, 06:29 PM
sakete's Avatar
Rep: 7 (Unique: 6)
I'm not seeing any symbols showing up next to any text that will allow me to save these settings onto the controller's memory. I'm on the Aquaero > Controllers tab where I have a set a couple of fan curves.
post #13345 of 13349 (permalink) Old 02-11-2020, 08:52 PM
sultanofswing's Avatar
Rep: 0
When you make a change if you pay attention to the tab of your Aquaero you will see a Little Save Icon show up. I've clicked it a few times but personally I was under the assumption that it automatically saves it anyway.
sultanofswing is offline
post #13346 of 13349 (permalink) Old 02-11-2020, 11:09 PM
Tech Enthusiast
oreonutz's Avatar
So In this case, one of the numbers you used in your calculations, is likely not a number derived from the Aquaero itself, and instead is likely imported from either the Mobo or HWinfo, depending on which Core Temperature you used in your equation. In this event, while Aquasuite itself would not need to be open, the Aquasuite Service would need to be run in the background, and the USB Cable will need to be plugged into the board, with Windows Booted, in order for that Average Calculation to be run, simply because the Temperature you imported to derive your Average from, is a "Software Temp" which is not something native to the Aquaero.
So in this case, for instance if you were to boot into Linux, your fan curve would not work, because you would not have access to the CPU Temp for the calculation to proceed.
You can however get around this, simply by placing your own Temperature probes in the system, Maybe one at Intake and another at Exhaust, and then run your Curve based on that differential. In that case all Information is Native to the Aquaero, it does not need any Third Party service to input a Temperature from, and in that case your Curve will work after programmed, even if you unplugged the USB from the Unit, and booted to Linux.
I hope this helps.
-MattTheTech
DodekaZen3000
(34 items)
Ryzen 9 3950x
Samsung 970 Evo 1TB
860 Evo
Optical Drive
Optical Drive
Corsair RM1000i
Aquaero 6xt
Old Jonesbo Case
Operating System
Keyboard
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Audio
Audio
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
Other
oreonutz is offline
post #13347 of 13349 (permalink) Old 02-12-2020, 07:44 AM
sakete's Avatar
Rep: 7 (Unique: 6)
I hope this helps.
That makes perfect sense. Thanks. I don't run a dual-boot config with Linux on my desktop, only on my laptop, so overall not really an issue.
post #13348 of 13349 (permalink) Old 02-23-2020, 03:51 PM
mgoldb2's Avatar
Rep: 0
I just want to confirm that there should be no issues with my planned setup using a Aquaero 6 XT
Relevant equipment
Case THW10 with pedestal
Top of Case 8 140 mm fans connected to a SilverStone Technology Silverstone 8-Port PWM Fan hub
Pedestal 8 140 mm fans connected to a SilverStone Technology Silverstone 8-Port PWM Fan hub
Front of case 4 140 mm fans connected to a SilverStone Technology Silverstone 8-Port PWM Fan hub
Aquacomputer aquaero 6 XT
Aquacomputer aquabus Y-cable 4-Pin
Aquacomputer aquabus cable 4-Pin x2
Separate GPU and CPU loop
CPU Loop
Aquacomputer temperature sensor inline G1/4 X2
Aquacomputer flow rate sensor "high flow USB" G1/4
GPU Loop
My Planned setup
The 3 Fan hubs connected to Fans 1-3 on the Aquacomputer aquaero 6 XT
4 temperature sensor connected to the Aquacomputer aquaero 6 XT
Finally this the part I want to make sure i get the process right
1. I connected both my Flow Controller through USB to change there ID's to be different
2. At this point I can disconnect the USB and no longer need to connect the Flow Controller to motherboard but instead use the high Aquabus on the Aquacomputer aquaero 6 XT
3. Connect aquabus Y-cable 4-Pin to Aquacomputer aquaero 6 XT then use the aquabus cable 4-Pin to connect both the flow sensors to the Y-cable.
Anything that wont work with this setup?
mgoldb2 is offline
post #13349 of 13349 (permalink) Old 02-24-2020, 03:49 AM
JasonMorris's Avatar
Rep: 1 (Unique: 1)
if you can leave the usb connectors as i think you need them when flashing the hardware at a later date.
JasonMorris is offline
