OCN Aquaero Owners Club - Page 1342 - Overclock.net - An Overclocking Community
post #13411 of 14104 (permalink) Old 03-19-2020, 01:25 PM
Booo
sakete's Avatar
Rep: 13 (Unique: 12)
Quote: Originally Posted by Shoggy View Post
PSUs from Mean Well are usually good and not so much more expensive.
You need a y-cable. The aqbaus low is not used for aquabus anymore since a long time (acts as second flow sensor port now) nor would it have been compatible.
You can use any y-cable that has all wires on both plugs connected. A y-cable for fans will not work because the wire for the RPM is cut on the second plug.
Danke!
Main
(23 items)
AMD Ryzen 9 3900X
Asus X570 ROG Crosshair VIII Formula
EVGA GTX 980Ti SC+
2x 16GB G.Skill Ripjaws DDR4-3600 C16
1TB Samsung 970 EVO+ NVMe
1TB Samsung 850 EVO SSD
480GB SanDisk Extreme Pro
3x 4TB HGST Deskstar NAS (2 in RAID 1)
Seasonic Prime PX-1000
Optimus Foundation AM4
HWLabs GTS 360 XFLOW
Alphacool Nexxos 480
Watercool Heatkiller 980ti Waterblock
2x D5 Pump
Phanteks Enthoo 719/Luxe 2
Acer XB270HU
Keyboard
Corsair K70
Mouse
Logitech G502
Audio
Motu M4
Audio
JBL LSR305
Other
Aquacomputer Aqualis 450ml reservoir
Other
Aquacomputer Aquaero 6 LT
Other
Aquacomputer OCTO
sakete is offline
post #13412 of 14104 (permalink) Old 03-19-2020, 02:39 PM
Old crazy guy
ManniX-ITA's Avatar
Rep: 24 (Unique: 15)
I can't get to work the flow sensor with 5.6 mm nozzle, art. 53061.
Got the right cable and connected it to the aquaero but I don't get a reading, either on Flow 1 or Flow 2.
Is there something I'm missing?
Pandorum
(12 items)
Ryzen 3800x
GigaByte X570 AORUS Master
MSI GTX 1070 Armor OC
G.Skill DDR4 F4-3600C16-GTZNC 16-18-19-32-48-1T
Samsung M.2 970 PRO 1TB
EVGA SuperNova 1300 G2
beQuiet Dark Rock Pro 4
Corsair 750D Airflow
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
Logitech G502 Lightspeed
ManniX-ITA is offline
post #13413 of 14104 (permalink) Old 03-19-2020, 02:58 PM
Aqua Computer Staff
Shoggy's Avatar
Rep: 133 (Unique: 100)
You can connect the 3-pin female to female cable (comes with the aquaero) between the flow port and tacho port for a test. Make sure that level 0 (normal operation) in the alarm action tab has the tacho output enabled as action, otherwise there will be no tacho output to fake a signal for the flow port.
If that works and you see a flow value, it means the sensor is very likely not OK.
Got a question or having trouble with your Aqua Computer product?
Contact us via PM or E-Mail.
Shoggy is offline
post #13414 of 14104 (permalink) Old 03-19-2020, 03:25 PM
tistou77's Avatar
Rep: 21 (Unique: 17)
Hello
I'm looking for a "fan controler" and I like the Aquaero 6 (especially since I'm looking for a silver one), and I have a few questions
1) I saw that it was better to take version 6, heat less than version 5 if we want to use the fan or other with less tension
That's right ?
2) Can the 4pin (PWM) be used with a fan (or other) 3pin and use the variation ?
And lower the tension ? and RPMs ?
3) The only difference between the Pro and XT version is the remote control ?
But on the XT version, there are also the 3 buttons (like the Pro version) to be able to use it directly from the "screen" (I just saw the 3 LEDs) ?
Thanks for your help
Sorry for my english
tistou's config
(19 items)
i9 10980XE
Asus Rampage VI Extreme Encore
EVGA RTX 2080ti XC Ultra
G.Skill Trident Z Royal @4000 C16
Intel Optane 905P PCIe (with WB)
Samsung 970 EVO Plus
Seasonic Prime Ultra Titanium 1000W
Alphacool VPP755 x2
Mod Pump Bitspower
Mod Pump Ek Waterblock
Ek Magnitude
Waterblock EVGA Hydro Copper XC
MORA 3 9x120 (x2)
Lian Li A77FA
Operating System
Windows 10 Pro x64
Dell U2417H
Keyboard
Logitech Illuminated K740
Mouse
Logitech MX Revolution
Audio
Asus Xonar Phoebus
tistou77 is offline
post #13415 of 14104 (permalink) Old 03-19-2020, 03:59 PM
Aqua Computer Staff
Shoggy's Avatar
1.) Yes, aquaero 6 works as a switched-mode power supply for the fan outputs which has a high efficiency and therefor does not cause much heat. The aquaero 5 on the other hand uses a classic voltage control which especially becomes quite warm/hot when connecting a lot of stuff and lowering the output voltage.
2.) The aquaero 6 can use voltage or PWM control on all four fan outputs. You can configure that in anyway you want. For example use output 1+4 with voltage control and 2+3 with PWM control. Each channel can have individual controller settings. Or in other words: whatever you want to do: it is possible.
3.) XT uses touch control, has four more buttons that make navigation a bit easier and can be programmed as short cuts to jump to specific menus point, the three main buttons are illuminated with LEDs, the display and touch buttons are covered by a glass so the whole front is even, the remote control is included and the runtime for free updates of the aquasuite software is 12 months longer.
Shoggy is offline
post #13416 of 14104 (permalink) Old 03-20-2020, 03:27 AM
Old crazy guy
ManniX-ITA's Avatar
Thanks for the tip. But against all odds I got not one, but two brand new pumps failing. Made my day.
The sensor is working fine, I can get the flow reading from the other pump; it's erratic but didn't stop working completely.
Pandorum
(12 items)
Ryzen 3800x
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
post #13417 of 14104 (permalink) Old 03-20-2020, 05:28 AM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
the screen is helpful during build out. otherwise, it just sits there looking meh.
needs an OLED update
Add me on Steam, same name
skupples is offline
post #13418 of 14104 (permalink) Old 03-20-2020, 05:36 AM
Old crazy guy
ManniX-ITA's Avatar
I agree, needs an OLED update. From my sitting position it's unreadable, I have to duck down
Pandorum
(12 items)
Ryzen 3800x
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
post #13419 of 14104 (permalink) Old 03-20-2020, 08:01 AM
tistou77's Avatar
Thanks so much for your reply and the details
2) If I remember correctly, there are 4 x 4pin and 2 x 4pin (PWM)
So I can use these 6 "outputs" in 3pin and use the voltage control ?
3) I do not wish to use the software and if I understood correctly, everything can be adjusted from the Aquaero 6 screen
I have one last question, is it possible to turn off the screen but without turning off the Aquaero ?
Thanks
tistou's config
(19 items)
i9 10980XE
Alphacool VPP755 x2
Mod Pump Bitspower
Ek Magnitude
MORA 3 9x120 (x2)
Lian Li A77FA
Operating System
Windows 10 Pro x64
Dell U2417H
Keyboard
Mouse
Audio
Asus Xonar Phoebus
tistou77 is offline
post #13420 of 14104 (permalink) Old 03-20-2020, 10:33 AM
Aqua Computer Staff
Shoggy's Avatar
You can also use the two 12V 2-pin PWM outputs in the controller settings etc. but they are not meant for fans nor can you adjust their voltage. They provide a pulsed 12V power output which can be used for LED strips for example.
3.) You can configure most stuff directly from the onboard menu and screen but be warned: it will be painful and frustrating Things that only take a few mouse clicks in the software will become an adventure in the onboard menu. I highly recommend to do the initial setup with a PC.
The screen can not be completely turned off. There are workarounds to make it look like being turned off by adding a black screen as custom graphics for the standby screen and setting the backlight brightness to 0%. Technically it is still turned on.
Shoggy is offline
