OCN Aquaero Owners Club - Page 1346 - Overclock.net - An Overclocking Community
post #13451 of 13494 (permalink) Old 03-25-2020, 05:17 AM
zGunBLADEz's Avatar
Rep: 103 (Unique: 76)
Quote: Originally Posted by Shoggy View Post
The official rating is 1A per channel.
what about the video of the 20x fans per channel tho>>?? I surely will blow that channel with one of my 6k delta fans no question asked when he wants to pull 60ws just because ...
Aquaero 6 XT
Four fan outputs with up to 30 Watt of power per channel
thats barely 3 amps 2.5 to be exactly...
@ 12v /30 watts
it should handle fine .3amp fans up to 6 x channel in the safe side.. at full speed. and it should be active cooled too..
more than that in the long run can be trouble in some setups..
what fans were those>>? .3a x 3 would be aroundish 1amp you can squeeze a 4th one there cutting short bit extra..
zGunBLADEz is offline
post #13452 of 13494 (permalink) Old 03-25-2020, 05:29 AM
GTXJackBauer's Avatar
Rep: 20 (Unique: 20)
I always thought each channel was 2.5 Amps (30 Watts) and slightly more if enough cooling is there.
ll Corsair 900D ll Intel Core i7-5930K @ 4500.0MHz on HWBOT ll EVGA X99 Classified ll Crucial Ballistix Sport 2400MHz 16GB ll Aquaero 6 XT ll EVGA GTX 780 Classified 3GB Hydro Copper (x2 in SLI) ll Samsung XP941 512GB PCI-E 2.0 x4 M.2 SSD ll WD VelociRaptor 10k RPM 300GB - x2 ll WD Black 1.5TB - x2 ll Toshiba 3TB ll Corsair AX1200i ll ASUS VS248H-P 24" 2ms LED - x3 - Nvidia Surround ll Bose Companion 5 ll
ll Custom Swiftech XL ll Black Ice SR-1 240mm+360mm+480mm ll Helix120 (PWM) ll Swiftech Maelstrom-35X2 ll Aqua Computer High Flow Sensor ll Phobya Temp Sensor Coupler ll Bitspower Compression Fittings (1/2 ID 3/4 OD) ll PrimoChill Advanced LRT 1/2 ID 3/4 OD (Bloodshed Red) ll
GTXJackBauer is offline
post #13453 of 13494 (permalink) Old 03-25-2020, 06:09 AM
Aqua Computer Staff
Shoggy's Avatar
Rep: 129 (Unique: 98)
@zGunBLADEz and @GTXJackBauer
You guys are talking about the fan outputs but the initial question was about the two 2-pin PWM outputs and they are rated for 1A.
Got a question or having trouble with your Aqua Computer product?
Contact us via PM or E-Mail.
Shoggy is offline
post #13454 of 13494 (permalink) Old 03-25-2020, 06:33 AM
post #13455 of 13494 (permalink) Old 03-25-2020, 09:21 AM
tistou77's Avatar
Rep: 19 (Unique: 16)
So, only 12W ? Not 30W ?
Oh ok, it's for 2pin
The remote will already speed up things but the software is still much easier and faster to set up the device.
Ok thanks
Sorry for my english
tistou's config
(19 items)
i9 7980x
Asus Rampage VI Extreme
EVGA RTX 2080ti XC Ultra
G.Skill Trident Z Royal @4000 C16
Intel Optane 905P PCIe (with WB)
Samsung 970 EVO Plus
Seasonic Prime Ultra Titanium 1000W
Alphacool VPP755 x2
Mod Pump Bitspower
Mod Pump Ek Waterblock
Ek Velocity
Waterblock EVGA Hydro Copper XC
MORA 3 9x120 (x2)
Lian Li A77FA
Operating System
Windows 10 Pro x64
Dell U2417H
Keyboard
Logitech Illuminated K740
Mouse
Logitech MX Revolution
Audio
Asus Xonar Phoebus
tistou77 is offline
post #13456 of 13494 (permalink) Old 03-25-2020, 11:28 AM
ManniX-ITA's Avatar
Rep: 3 (Unique: 3)
Yes I found it in the manual with a carrier frequency of 15 kHz. But what is the duty cycle?
AFAIK if the duty cycle is 50% then the maximum power output per port is 6W, while at 75% would be 9W.
Maybe there's a standard duty cycle value in these cases and I don't know it?
Pandorum
(12 items)
Ryzen 3800x
GigaByte X570 AORUS Master
MSI GTX 1070 Armor OC
G.Skill DDR4 F4-3600C16-GTZNC 16-18-19-32-48-1T
Samsung M.2 970 PRO 1TB
EVGA SuperNova 1300 G2
beQuiet Dark Rock Pro 4
Corsair 750D Airflow
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
Logitech G502 Lightspeed
ManniX-ITA is online now
post #13457 of 13494 (permalink) Old 03-25-2020, 11:35 AM
u broke 666 rep :(
skupples's Avatar
Rep: 676 (Unique: 359)
i mean, yeah, you can "use" the remote.
awesome remote, tbh.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
KAIHL Switches < CHERRY Switches, 10/10, blind taste test @ work.
skupples is offline
post #13458 of 13494 (permalink) Old 03-25-2020, 01:31 PM
Manual breath enabled
Streetdragon's Avatar
Rep: 26 (Unique: 22)
i have the problem with and without the software fuse thingy.
i have 12x Scythe Grand Flex PWM 2400rpm
6 on header 1. 6 on header 2
Header 3 has one 200mm fan
header 4 has two or three fans.
When i only one header to pwm, all header go into overcurrent. For example i enable it on header 4(all pwm fans) it triggers 1+2+3+4.
Well xD
when i push over 80% fanspeed on header 1 or 2 it draws like 2,2A from the header and jumps to protection
After 10-15seconds the overcurrent kicks in^^ Bought it on the 25.10.2017
Gameingcube
(18 items)
Ryzen 3900X
Aorus X570 Master
1080 TI Founders Edition
F4-3600C16Q-32GTZR
2000GB Seagate Barracuda Compute ST2000DM008 256MB
samsung m2 970 evo
Leadex 80 Plus Platinum Netzteil, schwarz - 1200 Watt
heatkiller IV pro
EK-FC1080 GTX Ti - Nickel
Alphacool Eisbecher D5 250mm Plexi
Alphacool NexXxoS XT45 Full Copper 480mm
XSPC Multiport Radiator EX240
Scythe Grand Flex 4Pin PWM
thermaltake core x9
Operating System
Windows 10
Streetdragon is offline
post #13459 of 13494 (permalink) Old 03-25-2020, 03:07 PM
u broke 666 rep :(
skupples's Avatar
^^ is why i've always offloaded power, and only take tach/rpm from the aquaero.
yes, it can handle some fans... but i like making my stuff last for as long as possible.
skupples is offline
post #13460 of 13494 (permalink) Old 03-25-2020, 09:22 PM
sultanofswing's Avatar
Rep: 1 (Unique: 1)
I'm running a total of 17 fans (3 NF-A12x25PWM and 14 Artic P12PWM_PST)on channels 1,3 and 4.
I run those channels at 95% at idle without any issues.
Those 3 channels sit at 31-32c.
Maybe I got lucky?
sultanofswing is offline
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
IT Diva
