OCN Aquaero Owners Club - Page 1347 - Overclock.net - An Overclocking Community
post #13461 of 13511 (permalink) Old 03-26-2020, 03:04 AM
zGunBLADEz's Avatar
Rep: 103 (Unique: 76)
Quote: Originally Posted by Shoggy View Post
@zGunBLADEz and @GTXJackBauer
You guys are talking about the fan outputs but the initial question was about the two 2-pin PWM outputs and they are rated for 1A.
Still my question remains the 20x fans per channel video specs. Kind of missleading for [email protected] x channel..
No good on the long run to run constant max amp or above even if is active cooled.
zGunBLADEz is offline
post #13462 of 13511 (permalink) Old 03-26-2020, 06:31 AM
u broke 666 rep :(
skupples's Avatar
Rep: 677 (Unique: 360)
would depend on the fan I think.
trying to see if I still have documentation of how i set it up before I split the power off.
pretty sure I dropped 10-15 AP15s per channel on 1, 2, & 3, n combined my dual pump to #4 hub. dual pump has always been wired for external power.
my Aquaero 6 is @ 2129 days of up time. woot.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
KAIHL Switches < CHERRY Switches, 10/10, blind taste test @ work.
skupples is offline
post #13463 of 13511 (permalink) Old 03-26-2020, 08:24 AM
Shawnb99's Avatar
Rep: 50 (Unique: 32)
I'm running 16 Notcua NFA12's on a single channel, though that's off a Quadro. Only 287 days of uptime for me
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #13464 of 13511 (permalink) Old 03-26-2020, 10:30 AM
jura11's Avatar
Rep: 103 (Unique: 67)
Quote: Originally Posted by sultanofswing View Post
I'm running a total of 17 fans (3 NF-A12x25PWM and 14 Artic P12PWM_PST)on channels 1,3 and 4.
I run those channels at 95% at idle without any issues.
Those 3 channels sit at 31-32c.
Maybe I got lucky?
You mean 17 fans on channel or are you running total 17 fans on 1,2 and 4
I'm running in total 38 fans I think on all 4 channels(in previous reply I said I'm running 36 fans in total but forgot on 2 140mm fans hahaha)
Fan header 1: 9* Phanteks PH-F120MP
Fan header 2: 6* Corsair ML120 with 3*Noiseblocker eLoop
Fan header 3: 9* Arctic Cooling P12 PWM
Fan header 4: 9* Arctic Cooling P12 PWM plus 2* Arctic Cooling P14 PWM or Phanteks PH-F140MP
Channel 1 is set to PWM, Channel 2 is PWM, Channel 3 is set to PWM and Channel 4 is set to PWM
At 99% power I think I have seen max amp 1.40A on channel 1 or 2, these fans do have highest power draw or amperage at max speed
Channel 2 have amperage I think something like 0.65A,Channel 4 have amperage 0.88A
If you are lucky, hard to say there
My Aquacomputer Aquaero 6XT have uptime 1133 days
Hope this helps
Thanks, Jura
jura11 is offline
post #13465 of 13511 (permalink) Old 03-26-2020, 10:41 AM
u broke 666 rep :(
skupples's Avatar
all about the total amperage per header, right?
skupples is offline
post #13466 of 13511 (permalink) Old 03-26-2020, 10:57 AM
jura11's Avatar
The official rating is 1A per channel.
Which fans do you use? How many of them are connected to a channel? Do you use the software fuse? - If so, please disable it. It is nonsense for regular operation because there is an overload protection that is always working. Using the software fuse will only cause to disable the dynamic overload protection so it is a hard cut at the set value while the dynamic variant takes the load and time into account. This is useful for fans or pumps with a very high starting current.
The remote will already speed up things but the software is still much easier and faster to set up the device.
Have you already tried to move this group of fans to one of the other outputs? If a different output comes up with the same problem you can be quite sure that the fans indeed draw too much power for some reason.
Otherwise, same as mentioned above: disable the software fuse if it is enabled.
I am not Sebastian.
Hi @Shoggy
Thanks for reply
No fuse or anything like that have enabled in Aquasuite or Aquaero what I remember
In watts that's something like 12w per channel maybe less don't remember now, temperatures of channels are quite low 25-30°C as max
Uptime of my Aquaero 6XT is 1133 days which 3 years plus some weeks on top of that
Usually when I'm trying to run on these 2 channels(1 and 2) fans in higher speeds usually its triggers overpowerprotection and it will disable fan output and therefore fans will stop, happen to me few times when I rendered or when I used [email protected]
Strange is usually voltage on PWM voltage fluctuating in 10.8-11.6V, currently running Aquaero 6XT from separate Molex, previously on same Molex I have connected 2 DDC 3.2 PWM 18W pumps and 5.25 USB 3.0 external bay, now power doesn't fluctuating, stays at 11.8V under load or at 99%
Power supply is Superflower 8pack 2000w abd I don't think its problem with that, powering 4 GPUs and 5960x with 4.7GHz and 10 SATA drives(4*3TB,1*4TB,1*6TB,1*8TB and 2*2TB Samsung SSD, 1*TB another SSD Crucial)
Uptime of Aquaero 6XT is 1133 days
Swapped fan headers few times, I thought so one of the headers or output are getting wonky but happened on all 4 outputs
Yesterday I put fans which are drawing most of the current on powered fan splitters and seems no issues now running fans at 99% but didn't tested that with SPLITTY9 and separate Molex power for Aquaero, will do tests later on again
And sorry for mistaken yours name there
Hope this helps
Thanks, Jura
jura11 is offline
post #13467 of 13511 (permalink) Old 03-26-2020, 11:07 AM
jura11's Avatar
Yes in my case there, highest amperage per header or output in my case what I'm seeing
Channel 1 max amperage/current at 99% fans speed 1.40A
Channel 2 max amperage/current at 99% fans speed 1.40A
Channel 3 max amperage/current at 99% fans spreed 0.65A
Channel 4 max amperage/current at 99% fans speed 0.88A
Max rating for max current should be in 2.5A I think or 30W per channel or output and I don't think I'm hitting such current on my outputs or headers
Its strange issue there
Its started to happening after updating to new Aquasuite, been for while using Aquasuite 2016 or 2018 and no issues but after updating to X, Aquasuite is crashing etc and now this issue
Hope this helps
Thanks, Jura
jura11 is offline
post #13468 of 13511 (permalink) Old 03-27-2020, 12:00 AM
Big Radiators!
war4peace's Avatar
Rep: 25 (Unique: 23)
Only 929 days here... I bought mine less than 3 years ago, so there's that.
My Rig Temps in Real Time
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
Gigabyte 1080 Ti Waterforce Extreme Edition 11Gbps
Kingston HyperX 2x 16GB DDR4 3000MHz
SSD Samsung 850 EVO 1TB
SSD ADATA 512 GB
Patriot Hellfire 240 GB M.2 SSD nVME
Super Flower Leadex Gold 750W
Corsair AX860
Custom Loop, EKWB, CPU+GPU, soft tubing
Thermaltake Core X5
Operating System
Windows 10 Professional X64
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
war4peace is offline
post #13469 of 13511 (permalink) Old 03-27-2020, 03:34 AM
ManniX-ITA's Avatar
Rep: 3 (Unique: 3)
I've got the new pumps finally but I'm a bit puzzled.
The new Eisbaer LT has a reported speed at 12V of 2757 rpm; the previous LT pump was reporting over 5000 rpm, once I realized it was faulty over 9000 rpm.
I guess this value is in line; the problem is the flow, lower than I expected.
12V - 17,1 l/h
10V - 13,4 l/h
8V - no flow reported
This while having in the same loop the other pump; it's a Laing DDC-1T Plus PWM.
The Laing reports these flow rate with the following PWM values:
28% - 18 l/h
33% - 27,1 l/h
45% - 59 l/h
66% - 103,4 l/h
Inside the Eisbaer LT there' s DC-LT 2600 pump.
Do you think it's normal that at full speed it can only move a fifth of the DDC-1T?
Also I wonder if it's normal the flow meter, the Aqua n. 53061, does not report anything at 8V with the DC-LT 2600.
Is there a lower margin below which it's not able to report flow at all?
Pandorum
(12 items)
Ryzen 3800x
GigaByte X570 AORUS Master
MSI GTX 1070 Armor OC
G.Skill DDR4 F4-3600C16-GTZNC 16-18-19-32-48-1T
Samsung M.2 970 PRO 1TB
EVGA SuperNova 1300 G2
beQuiet Dark Rock Pro 4
Corsair 750D Airflow
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
Logitech G502 Lightspeed
ManniX-ITA is offline
post #13470 of 13511 (permalink) Old 03-27-2020, 04:26 AM
Big Radiators!
war4peace's Avatar
The Eisbaer LT is a VERY slow pump. It has a rated flow of 100L/min when running solo, without a loop. It also has a head pressure of 0.6m which is VERY low.
Tech specs.
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
SSD ADATA 512 GB
Corsair AX860
Thermaltake Core X5
Operating System
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
