OCN Aquaero Owners Club - Page 1348 - Overclock.net - An Overclocking Community
post #13471 of 13950 (permalink) Old 03-27-2020, 06:22 AM
Old crazy guy
ManniX-ITA's Avatar
Rep: 8 (Unique: 8)
Quote: Originally Posted by war4peace View Post
The Eisbaer LT is a VERY slow pump. It has a rated flow of 100L/min when running solo, without a loop. It also has a head pressure of 0.6m which is VERY low.
Tech specs.
Yeah I know it's very slow; it's also ultra low noise, main requirement
But I have no reference to judge if it's working as expected.
In the manual it's actually rated as 70 liter per hour.
I'd wish that someone could confirm the values are in the correct range.
BTW The DDC-1T Plus at 33% is less noisy and almost double the flow.
It's bigger yes, but not that much; wouldn't say the 2600 it's a great pump at all, thumbs down.
Pandorum
(12 items)
Ryzen 3800x
GigaByte X570 AORUS Master
MSI GTX 1070 Armor OC
G.Skill DDR4 F4-3600C16-GTZNC 16-18-19-32-48-1T
Samsung M.2 970 PRO 1TB
EVGA SuperNova 1300 G2
beQuiet Dark Rock Pro 4
Corsair 750D Airflow
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
Logitech G502 Lightspeed
ManniX-ITA is offline
post #13472 of 13950 (permalink) Old 03-27-2020, 06:49 AM
Food Editor
skupples's Avatar
Rep: 720 (Unique: 378)
i think you might also distort results due to having two different speed pumps running at the same time. are you shuttering one when testing the other?
draw a mental image of a faster pump pushing water into a slower pump, etc. i think the slower pump would just add restriction and not benefit flow much (yes, we know. redundancy!)
Add me on Steam, same name
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #13473 of 13950 (permalink) Old 03-27-2020, 06:52 AM
indyjones's Avatar
Rep: 0
Bit of a random question, but has anybody tried or known of anyone who has run their Aquaero screen via a wired extension from the main unit please? Where I am thinking of mounting the screen, it does not have the clearance for the assembled unit, and where it's a standard 24pin connector I was thinking of wiring an extension lead on my 6 XT. It does not need to very long.
indyjones is offline
post #13474 of 13950 (permalink) Old 03-27-2020, 07:07 AM
Food Editor
skupples's Avatar
its come up a few times. people have adapted ribbon cables (not sure if Aqua makes one these days) and I believe they found the range of said cable is quite limited.
skupples is offline
post #13475 of 13950 (permalink) Old 03-27-2020, 07:07 AM
Big Radiators!
war4peace's Avatar
Rep: 32 (Unique: 26)
I have dual-D5 pumps in a volute and I can barely hear them. The 4x 230mm fans running at 400 RPM, those I can barely hear, but I can't hear the pumps (at 100%). BTW my flow rate is 313 L/h with the above setup.
Getting a weak pump because "others are noisy" is not backed up by actual facts, just saying.
My Rig Temps in Real Time
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
Gigabyte 1080 Ti Waterforce Extreme Edition 11Gbps
Kingston HyperX 2x 16GB DDR4 3000MHz
SSD Samsung 850 EVO 1TB
SSD ADATA 512 GB
Patriot Hellfire 240 GB M.2 SSD nVME
Super Flower Leadex Gold 750W
Corsair AX860
Custom Loop, EKWB, CPU+GPU, soft tubing
Thermaltake Core X5
Operating System
Windows 10 Professional X64
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
war4peace is offline
post #13476 of 13950 (permalink) Old 03-27-2020, 07:08 AM
Food Editor
skupples's Avatar
the only noisy pumps are DDCs on high speed. Specially if you fail to prevent your pumps from resonating your case.
CLCs don't count, almost all of them use absolute garbage bottom barrel $1 a piece in bulk pumps.
skupples is offline
post #13477 of 13950 (permalink) Old 03-27-2020, 07:42 AM
indyjones's Avatar
Rep: 0
Thank i shall give it a try It does not need to be that long maybe 15-20cm
post #13478 of 13950 (permalink) Old 03-27-2020, 11:42 AM
Old crazy guy
ManniX-ITA's Avatar
Rep: 8 (Unique: 8)
Yep, those numbers are one pump at the time.
I did run briefly both together with the DDC at lowest speed and the 2600 adds max 10 l/h.
Indeed I guess it's not the best running 2 very different pumps at the same time.
It's on my list the D5, thanks for the feedback
I'm doing prototyping now and the Eisbaer LT just fits the task.
The DDC is indeed very noisy at full speed, it starts being noticeable at 2500 rpm and annoying at 3200 rpm; at full speed it's quite terrible.
And it's not even yet inside the case. The D5 seems vastly superior in every aspect.
Pandorum
(12 items)
Ryzen 3800x
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
post #13479 of 13950 (permalink) Old 03-27-2020, 12:18 PM
jura11's Avatar
Rep: 104 (Unique: 68)
Running 2*Laing DDC 3.25 18W pump with Aquacomputer Dual DDC pump top and they're mounted on Aquacomputer Shoggy sandwich and no issues with noise plus running XSPC D5 Vario pump at full speed and both DDC are running at full speed and absolutely no issues with noise
Hope this helps
Thanks, Jura
jura11 is offline
post #13480 of 13950 (permalink) Old 03-27-2020, 01:27 PM
Big Radiators!
war4peace's Avatar
Not necessarily. I have a DDC 3.25 from EKWB running in my wife's mITX build and it sits on a modified Shoggy Sandwich, you can't hear it unless you are very close to the case, listen intently and manage to ignore the awful mini-fan on the X570 motherboard's chipset.
The way you install it is indeed more important than in case of a D5 pump, but as far as noise goes, it can be pretty quiet.
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
SSD ADATA 512 GB
Corsair AX860
Thermaltake Core X5
Operating System
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
