OCN Aquaero Owners Club - Page 1349 - Overclock.net - An Overclocking Community
post #13481 of 13947 (permalink) Old 03-27-2020, 06:40 PM
GTXJackBauer's Avatar
Rep: 22 (Unique: 21)
DDCs were always known to be more audible than D5s. I've had both and it's a night and day difference. I can barely hear my D5s atm @ 90% PWM while the DDCs were surely audible @ 40% PWM, let alone 100%.
Also, you have to be careful with some of these 'lite' pumps. They could be equivalent to AIO pumps which are very weak compared to premium pumps.
ll Corsair 900D ll Intel Core i7-5930K @ 4500.0MHz on HWBOT ll EVGA X99 Classified ll Crucial Ballistix Sport 2400MHz 16GB ll Aquaero 6 XT ll EVGA GTX 780 Classified 3GB Hydro Copper (x2 in SLI) ll Samsung XP941 512GB PCI-E 2.0 x4 M.2 SSD ll WD VelociRaptor 10k RPM 300GB - x2 ll WD Black 1.5TB - x2 ll Toshiba 3TB ll Corsair AX1200i ll ASUS VS248H-P 24" 2ms LED - x3 - Nvidia Surround ll Bose Companion 5 ll
ll Custom Swiftech XL ll Black Ice SR-1 240mm+360mm+480mm ll Helix120 (PWM) ll Swiftech Maelstrom-35X2 ll Aqua Computer High Flow Sensor ll Phobya Temp Sensor Coupler ll Bitspower Compression Fittings (1/2 ID 3/4 OD) ll PrimoChill Advanced LRT 1/2 ID 3/4 OD (Bloodshed Red) ll
GTXJackBauer is online now
post #13482 of 13947 (permalink) Old 03-27-2020, 11:46 PM
Old crazy guy
ManniX-ITA's Avatar
Rep: 8 (Unique: 8)
I guess we are talking about different models, this is the one I got:
https://www.alphacool.com/shop/pumps...us-pwm?c=20561
And there's no way that this one could be quiet even with a perfect mounting.
In comparison the Phobya DC2-400 PWM, the half an hour which lasted, was almost inaudible at full speed.
Shaking like a kitchen mixer but very quiet.
Pandorum
(12 items)
Ryzen 3800x
GigaByte X570 AORUS Master
MSI GTX 1070 Armor OC
G.Skill DDR4 F4-3600C16-GTZNC 16-18-19-32-48-1T
Samsung M.2 970 PRO 1TB
EVGA SuperNova 1300 G2
beQuiet Dark Rock Pro 4
Corsair 750D Airflow
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
Logitech G502 Lightspeed
ManniX-ITA is offline
post #13483 of 13947 (permalink) Old 03-28-2020, 10:36 AM
Food Editor
skupples's Avatar
Rep: 720 (Unique: 378)
well, that top doesn't help things one bit. whatever the output is, it'll be better with a good top.
Add me on Steam, same name
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #13484 of 13947 (permalink) Old 03-28-2020, 06:21 PM
zGunBLADEz's Avatar
Rep: 103 (Unique: 76)
its easy to add external source of power if needed with a split +/- straight from psu
zGunBLADEz is offline
post #13485 of 13947 (permalink) Old 03-28-2020, 11:29 PM
Old crazy guy
ManniX-ITA's Avatar
Rep: 8 (Unique: 8)
I don't think I can change the top, it's fitted on this 5,25" reservoir bay:
https://www.alphacool.com/shop/reser...tation?c=20615
PS: 5,25" bay slots forever
Pandorum
(12 items)
Ryzen 3800x
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
post #13486 of 13947 (permalink) Old 03-29-2020, 08:25 AM
Food Editor
skupples's Avatar
classic! yeah, the top is integrated into the reservoir somehow.
there's actually good news here - your pump is so weak it'll likely never cause gulping or vortexing in that res
skupples is offline
post #13487 of 13947 (permalink) Old 03-29-2020, 08:35 AM
Old crazy guy
ManniX-ITA's Avatar
Rep: 8 (Unique: 8)
eheheh very likely! seems even at the lowest speed is already doing well enough so shouldn't be an issue
Pandorum
(12 items)
Ryzen 3800x
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
post #13488 of 13947 (permalink) Old 03-29-2020, 09:03 AM
Aqua Computer Staff
Shoggy's Avatar
Rep: 133 (Unique: 100)
Quote: Originally Posted by Streetdragon View Post
When i only one header to pwm, all header go into overcurrent. For example i enable it on header 4(all pwm fans) it triggers 1+2+3+4.
I will have to talk to our electronic technician but I already assume that the voltage/current monitoring chip on your aquaero is damaged. If you have some good soldering skills or know someone, you could replace it yourself. Otherwise you would have to send in the device.
Quote: Originally Posted by zGunBLADEz View Post
Still my question remains the 20x fans per channel video specs. Kind of missleading for [email protected] x channel..
No good on the long run to run constant max amp or above even if is active cooled.
Not sure what you are asking for. The aquaero 6 can handle 2.5A per fan output and can do 3.0A per fan output when using the passive heatsink.
The fans in the video were our airstream fans that are not available anymore since quite a long time now. Their official rating was 0.18A.
Quote: Originally Posted by jura11 View Post
Its started to happening after updating to new Aquasuite, been for while using Aquasuite 2016 or 2018 and no issues but after updating to X, Aquasuite is crashing etc and now this issue
When you came from a very old firmware version it could explain your problem. Old versions were not monitoring huge loads correctly and were way too tolerant. It was fixed a while ago and when you updated lately your aquaero also has this fix now. So the problem was very likely already there before but the older firmware interpreted it as OK while it was supposed to be not OK.
Quote: Originally Posted by ManniX-ITA View Post
Also I wonder if it's normal the flow meter, the Aqua n. 53061, does not report anything at 8V with the DC-LT 2600.
I don't know the flow rate of this pump at low voltage but the flow meter with the smaller diameter is pretty accurate even at low flow rates. It should easily work with flow rates of only 20 l/h.
Quote: Originally Posted by indyjones View Post
Bit of a random question, but has anybody tried or known of anyone who has run their Aquaero screen via a wired extension from the main unit please? Where I am thinking of mounting the screen, it does not have the clearance for the assembled unit, and where it's a standard 24pin connector I was thinking of wiring an extension lead on my 6 XT. It does not need to very long.
It is possible but not recommend. We use an extension cable in the GIGANT radiator since there is not enough space available to install a completely assembled aquaero. The cable is something about 20 cm and should not be much longer because otherwise the communication between the controller and display will fail.
The extension is no regular article for sale but you can get a quotation for it on request.
Got a question or having trouble with your Aqua Computer product?
Contact us via PM or E-Mail.
Shoggy is offline
post #13489 of 13947 (permalink) Old 03-29-2020, 09:55 AM
Manual breath enabled
Streetdragon's Avatar
Rep: 27 (Unique: 22)
a damaged chip. Can you provide some screens wich chip is the problem?
Its now running for 875Days. And without a controller i cant use my rig^^
Gameingcube
(18 items)
Ryzen 3900X
Aorus X570 Master
1080 TI Founders Edition
F4-3600C16Q-32GTZR
2000GB Seagate Barracuda Compute ST2000DM008 256MB
samsung m2 970 evo
Leadex 80 Plus Platinum Netzteil, schwarz - 1200 Watt
heatkiller IV pro
EK-FC1080 GTX Ti - Nickel
Alphacool Eisbecher D5 250mm Plexi
Alphacool NexXxoS XT45 Full Copper 480mm
XSPC Multiport Radiator EX240
Scythe Grand Flex 4Pin PWM
thermaltake core x9
Operating System
Windows 10
Streetdragon is offline
post #13490 of 13947 (permalink) Old 03-29-2020, 12:22 PM
Big Radiators!
war4peace's Avatar
Rep: 32 (Unique: 26)
BTW... do you still make the GIGANT?
My Rig Temps in Real Time
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
Gigabyte 1080 Ti Waterforce Extreme Edition 11Gbps
Kingston HyperX 2x 16GB DDR4 3000MHz
SSD Samsung 850 EVO 1TB
SSD ADATA 512 GB
Patriot Hellfire 240 GB M.2 SSD nVME
Super Flower Leadex Gold 750W
Corsair AX860
Custom Loop, EKWB, CPU+GPU, soft tubing
Thermaltake Core X5
Operating System
Windows 10 Professional X64
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
war4peace is offline
