OCN Aquaero Owners Club - Page 1394 - Overclock.net - An Overclocking Community
post #13931 of 14078 (permalink) Old 05-23-2020, 10:44 PM
Moose-Tech's Avatar
Rep: 9 (Unique: 9)
Quote: Originally Posted by war4peace View Post
I finished design and print for both, they work very well. I will use them for my next (re)build. Planning on switching to hard tubing, been holding off for tube illumination.
In the meantime I will try a method to hide the LED Strips under a layer of material, making the LED lights less sharp and more diffuse.
I used this and cut out strips to diffuse both my RGB and White LED lighting strips. I Hate seeing naked LED's.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Build: Z390 ACE
Core i9-9900K OC 5 GHz, MSI Z390 ACE Mobo, AMD Radeon VII GPU OC 2K MHz
Corsair Vengeance RGB 32GB 3200 RAM, Phanteks Enthoo Pro M SE.
EKWB Z390 ACE Monoblock, Bykski Radeon VII GPU w/b, 2x EKWB 140 Revo D5 Pump & Res.
Aquacomputer Aquaero 6 LT USB Fan-Controller, Quadro, Vision Touch and 'High Flow' Sensor.
(2x) HWL Black Ice Nemesis 280 GTS XFLOW and (1x) Alphacool XT45 X-Flow 280 radiators.
Moose-Tech is offline
post #13932 of 14078 (permalink) Old 05-23-2020, 11:05 PM
Tech Enthusiast
oreonutz's Avatar
Rep: 99 (Unique: 65)
Same here! Huge Pet Peave! Nice solution to diffusing the light, I never thought about using Acrylic. I bet that works well!
-MattTheTech
Offical Ryzen 9 3900x Owner!
Offical Ryzen 9 3950x Owner!
DodekaZen3000
(34 items)
Ryzen 9 3950x
ASUS Crosshair VII Hero
EVGA 1080ti FTW3 Hybrid
G.SKILL Flare X Series 32GB (4 x 8GB) 3200Mhz (PC4 25600) - F4-3200C14D-16GFX (x2 Kits)
Samsung 970 Pro 512GB
Samsung 970 Evo 1TB
Samsung 850/860 Evo (x3 Raid 0 Game Drive)
WD Black 4TB (x2 Raid 0 Storage Drive)
860 Evo
Optical Drive
LG Blu-Ray Burner (Model BH16NS40)
Optical Drive
5.25" to One 3.5" and One 2.25" Bay (Model Syba SY-MRA55006)
Corsair RM1000i
EKWB Phoenix 360mm Modular Cooler
280mm Alphacool UT60
280mm EKWB Coolstream CE
Optimus Foundation AM4 CPU Block
x2 Corsair Pump/Res Combo
EKWB Acrylic 1080ti FTW Block
Aquaero 6xt
Old Jonesbo Case
Operating System
Windows 10 Enterprise
Samsung NU8000 55Inch TV (Its a 4k TV But I run in it 1440p 120hz)
LG 1080p 34 Inch Diplay
Keyboard
Corsair k70 RGB Lux Mk2
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Custom Built 7.1 Surround System
Audio
HT-Omega eClaro 7.1 Sound Card
Audio
Focusrite Scarlett 18i20
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
10 ML120 + 6 ML140 Corsair Maglev Fans
Other
Phanteks Halo aRGB LUX x5
oreonutz is offline
post #13933 of 14078 (permalink) Old 05-24-2020, 03:02 AM
Big Radiators!
war4peace's Avatar
Rep: 33 (Unique: 27)
I believe it would work very well putting the LED strip under a thin layer of white or transparent (which becomes translucent while 3D Printing) PLA.
There are several advantages of 3D Printing tubing:
- Exact dimensions, no need to cut tubing
- Much sharper cornering without kinking
- Can be pre-bent by design at any angle
- No need to use splitters, can print the tube directly in T, Y or F form and so only use fittings at the end of the tube.
- Can print in any color or style (stone, wood, copper, silver, bronze...)
- Embedded LED Strip channels
- Automatic diffusing of light (wall between LED Strip and tube interior/exterior)
There are disadvantages as well:
- Long printing time, expect days to finish all tubing
- There's a chance for tubes to leak if printed incorrectly
- If you measured wrong (especially printing a smaller length than required) you gotta print again
- Light might be too diffuse, depending on material.
(big image)
(Big image)
My Rig Temps in Real Time
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
Gigabyte 1080 Ti Waterforce Extreme Edition 11Gbps
Kingston HyperX 2x 16GB DDR4 3000MHz
SSD Samsung 850 EVO 1TB
SSD ADATA 512 GB
Patriot Hellfire 240 GB M.2 SSD nVME
Super Flower Leadex Gold 750W
Corsair AX860
Custom Loop, EKWB, CPU+GPU, soft tubing
Thermaltake Core X5
Operating System
Windows 10 Professional X64
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
war4peace is offline
post #13934 of 14078 (permalink) Old 05-24-2020, 01:20 PM
Moose-Tech's Avatar
Rep: 9 (Unique: 9)
I see where Aquasuite version x.17 is out. If I upgrade, will I need to recreate all my sensors and profiles again? When I upgraded to x.11 I had to manually reset all my sensors and profiles.
I had back-up profiles saved but they would not recognize any HWiNFO64 sensors, which I utilize heavily for my Aquaero profile.
I managed to save my overview page, but all the sensors had to be re-sourced to get everything working again.
Before I upgrade to this new version, I need to know if this will be a quick upgrade or one where I will have to do a significant amount of re-alignment. I just got everything working the way I want to.
Build: Z390 ACE
post #13935 of 14078 (permalink) Old 05-24-2020, 01:50 PM
Tech Enthusiast
oreonutz's Avatar
I don't know, I couldn't tell you either. I had the same exact thing happen to me when I jumped to x12 from whatever was before x10, and everyone said it shouldn't have happened if I saved backup profiles, which I had, but as you said my HWInfo Sensors all had to be resourced, they didn't pull back in automatically. It was a bit of a pain. I mean really its just like 30 to 40 mins depending on the amount of Sensors and Logging you are doing, but still a Pain in the butt. I haven't upgraded since. Hopefully someone else will have the answer on this.
-MattTheTech
DodekaZen3000
(34 items)
Ryzen 9 3950x
Samsung 970 Evo 1TB
860 Evo
Optical Drive
Optical Drive
Corsair RM1000i
Aquaero 6xt
Old Jonesbo Case
Operating System
Keyboard
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Audio
Audio
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
Other
oreonutz is offline
post #13936 of 14078 (permalink) Old 05-24-2020, 03:41 PM
Old crazy guy
ManniX-ITA's Avatar
Rep: 22 (Unique: 14)
I've updated from the previous version and it was smooth.
But I think the OCTO firmware is bugged so I'd avoid it if you have one.
Pandorum
(12 items)
Ryzen 3800x
GigaByte X570 AORUS Master
MSI GTX 1070 Armor OC
G.Skill DDR4 F4-3600C16-GTZNC 16-18-19-32-48-1T
Samsung M.2 970 PRO 1TB
EVGA SuperNova 1300 G2
beQuiet Dark Rock Pro 4
Corsair 750D Airflow
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
Logitech G502 Lightspeed
ManniX-ITA is online now
post #13937 of 14078 (permalink) Old 05-25-2020, 08:58 AM
WiLd FyeR's Avatar
Rep: 24 (Unique: 21)
I usually have my MSI afterburner up to monitor things and noticed that Aquasuite is using about 25-30% of CPU. What could be causing this issue?
WiLd FyeR is offline
post #13938 of 14078 (permalink) Old 05-25-2020, 09:46 AM
Old crazy guy
ManniX-ITA's Avatar
I had a similar issue; hogging down a single core 100%.
It was the version update check.
But I reported it and the latest few versions it didn't show up again.
Are you running the latest?
Pandorum
(12 items)
Ryzen 3800x
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
post #13939 of 14078 (permalink) Old 05-25-2020, 10:41 AM
WiLd FyeR's Avatar
I restarted my PC and that solved the CPU usage. The version I have is 2017 so that could be part of the issue.
post #13940 of 14078 (permalink) Old 05-25-2020, 11:10 AM
Old crazy guy
ManniX-ITA's Avatar
Yep fixed for me too till did happen again.
Unfortunately I didn't find a switch to disable the Update check; only to disable Insider versions notification.
Pandorum
(12 items)
Ryzen 3800x
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
