OCN Aquaero Owners Club - Page 1395 - Overclock.net - An Overclocking Community
post #13941 of 14063 (permalink) Old 05-25-2020, 04:17 PM
Tech Enthusiast
oreonutz's Avatar
Rep: 99 (Unique: 65)
Quote: Originally Posted by WiLd FyeR View Post
I usually have my MSI afterburner up to monitor things and noticed that Aquasuite is using about 25-30% of CPU. What could be causing this issue?
This seems to happen every now and again. It will pin a single core to 100 Percent Usage, seemingly randomly. I believe it may have something to do with the update checks. But all you have to do is go into Task Manager (Ctrl+Shift+Escape), go to details, locate "AquaComputerService.exe", and force close it. It usually automatically reopens on its own and is then back to normal, but in 1 Case I had to actually go into Services and start AquaComputer Service myself. This way you don't have to restart, this is much quicker and easier. Hopefully they deal with this bug in an update soon. (I have not upgraded to see if its fixed, but I also have not seen it on the change log.)
If you are not on the newest Version, I have noticed that this seems to happen about once every other week. I have since completely blocked its ability to update in the firewall, but not sure if that has helped with this problem or not yet, as it hasn't been 2 weeks since I made that change. It's only been a little over a week, but so far so good. If I get through a month, and the problem hasn't returned, then I would be willing to say this could be a fix.
Also just to note, this has happened to me in x4, x11, x12, and x14 (Which is the last Update I have installed).
-MattTheTech
Offical Ryzen 9 3900x Owner!
Offical Ryzen 9 3950x Owner!
DodekaZen3000
(34 items)
Ryzen 9 3950x
ASUS Crosshair VII Hero
EVGA 1080ti FTW3 Hybrid
G.SKILL Flare X Series 32GB (4 x 8GB) 3200Mhz (PC4 25600) - F4-3200C14D-16GFX (x2 Kits)
Samsung 970 Pro 512GB
Samsung 970 Evo 1TB
Samsung 850/860 Evo (x3 Raid 0 Game Drive)
WD Black 4TB (x2 Raid 0 Storage Drive)
860 Evo
Optical Drive
LG Blu-Ray Burner (Model BH16NS40)
Optical Drive
5.25" to One 3.5" and One 2.25" Bay (Model Syba SY-MRA55006)
Corsair RM1000i
EKWB Phoenix 360mm Modular Cooler
280mm Alphacool UT60
280mm EKWB Coolstream CE
Optimus Foundation AM4 CPU Block
x2 Corsair Pump/Res Combo
EKWB Acrylic 1080ti FTW Block
Aquaero 6xt
Old Jonesbo Case
Operating System
Windows 10 Enterprise
Samsung NU8000 55Inch TV (Its a 4k TV But I run in it 1440p 120hz)
LG 1080p 34 Inch Diplay
Keyboard
Corsair k70 RGB Lux Mk2
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Custom Built 7.1 Surround System
Audio
HT-Omega eClaro 7.1 Sound Card
Audio
Focusrite Scarlett 18i20
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
10 ML120 + 6 ML140 Corsair Maglev Fans
Other
Phanteks Halo aRGB LUX x5
oreonutz is offline
post #13942 of 14063 (permalink) Old 05-25-2020, 06:30 PM
WiLd FyeR's Avatar
Rep: 24 (Unique: 21)
Thank you experience REP+. This was my first time noticing this issue since I've had it for 5 years now.
WiLd FyeR is offline
post #13943 of 14063 (permalink) Old 05-25-2020, 06:38 PM
Tech Enthusiast
oreonutz's Avatar
Quote: Originally Posted by ManniX-ITA View Post
I had a similar issue; hogging down a single core 100%.
It was the version update check.
But I reported it and the latest few versions it didn't show up again.
Are you running the latest?
Looks like you have noticed this being tied to the update check as well. How often have you noticed this happen in your system?
NP Glad to help!
-MattTheTech
DodekaZen3000
(34 items)
Ryzen 9 3950x
Samsung 970 Evo 1TB
860 Evo
Optical Drive
Optical Drive
Corsair RM1000i
Aquaero 6xt
Old Jonesbo Case
Operating System
Keyboard
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Audio
Audio
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
Other
oreonutz is offline
post #13944 of 14063 (permalink) Old 05-27-2020, 01:47 PM
Rep: 1 (Unique: 1)
So I have a fan curve setup for all my fans and I'm happy with it. My pump is on fan connection one on my 6LT. Now I'm understanding that I shouldn't have the pump on a curve, it should just have a set speed. Yet when I don't have a curve setup it's required to run at 100% per the screenshot. So what am I missing here?
I think I figured it out by using a preset value option in the output.
RoivonPC is offline
post #13945 of 14063 (permalink) Old 05-27-2020, 04:50 PM
InfoSeeker's Avatar
Rep: 45 (Unique: 37)
You can also use a preset controller with the pump(s) port(s) assigned to the controller.
InfoSeeker is offline
post #13946 of 14063 (permalink) Old 05-27-2020, 05:52 PM
Rep: 1 (Unique: 1)
Yup! I edited the post, I found that.
RoivonPC is offline
post #13947 of 14063 (permalink) Old 05-27-2020, 09:45 PM
Old crazy guy
ManniX-ITA's Avatar
Rep: 21 (Unique: 14)
NP Glad to help!
I had the issue with version X.14.
Since the upgrade to X.15 and the subsequent releases all the upgrades went smooth, no CPU hogging.
Pandorum
(12 items)
Ryzen 3800x
GigaByte X570 AORUS Master
MSI GTX 1070 Armor OC
G.Skill DDR4 F4-3600C16-GTZNC 16-18-19-32-48-1T
Samsung M.2 970 PRO 1TB
EVGA SuperNova 1300 G2
beQuiet Dark Rock Pro 4
Corsair 750D Airflow
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
Logitech G502 Lightspeed
ManniX-ITA is offline
post #13948 of 14063 (permalink) Old 05-28-2020, 08:54 AM
Old crazy guy
ManniX-ITA's Avatar
Just installed the X.20 and again no CPU hogging issues at update check.
Pandorum
(12 items)
Ryzen 3800x
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
post #13949 of 14063 (permalink) Old 05-28-2020, 09:08 AM
Vermin Supreme 2020
skupples's Avatar
Rep: 733 (Unique: 385)
maybe its a secret incentive to update
Add me on Steam, same name
skupples is offline
post #13950 of 14063 (permalink) Old 05-28-2020, 11:04 AM
Tech Enthusiast
oreonutz's Avatar
Good To Know, guess I will update.
-MattTheTech
DodekaZen3000
(34 items)
Ryzen 9 3950x
Samsung 970 Evo 1TB
860 Evo
Optical Drive
Optical Drive
Corsair RM1000i
Aquaero 6xt
Old Jonesbo Case
Operating System
Keyboard
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Audio
Audio
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
Other
oreonutz is offline
