OCN Aquaero Owners Club - Page 1399 - Overclock.net - An Overclocking Community
post #13981 of 14069 (permalink) Old 06-02-2020, 06:43 PM
helis4life's Avatar
Rep: 24 (Unique: 14)
Quote: Originally Posted by looniam View Post
then why buy a PWM pump?
and funny i don't experience any ping pong effect. certainly not after taking a few days to tighten the fan curve:
Attachment 351320
aside from the 1GPM "standard," i suspect setting pumps speed(s) more of a personal preference. i see no need to run anything at 100% while idling for hours.
I agree, having it running at 100% while you browse overclock.net doesnt seem necessary. I sit 1 meter from the machine, so at 100% I can hear it, at 40% i cant.
I also have never experienced any such ping pong affect. But like you said, personal preference really, no right or wrong way
Name:	Annotation 2020-06-02 213738.png
helis4life is offline
post #13982 of 14069 (permalink) Old 06-02-2020, 11:12 PM
Professional Lurker
valvehead's Avatar
Rep: 130 (Unique: 102)
I also use a curve controller for the pump. I chose a silent speed for the minimum, and the pump only speeds up after the fans are at a high enough level that they mask the increase in pump noise.
I use water-air delta as the controlling temp. Some people use absolute temps, but I prefer consistent noise level for a given load. I could run at lower fan and pump settings in winter, but I'm not limited by temps for stability anyway.
If you're experiencing ping pong with your pump, then either your controller is restricted to too small of a temperature range and/or you need more thermal mass (more water -> larger reservoir if necessary) to slow down the drift.
sig broken. too lazy to fix.
Neurosis
(6 items)
Monochrome
(25 items)
Patchouli
(11 items)
i7 5820K
Gigabyte GA-X99 Gaming G1
Nvidia Titan Xp
Corsair DDR4 32GB
Samsung 950 Pro NVME
Operating System
Windows 10 Pro x64
i7 2600K @4.5GHz
Gigabyte P67A-UD7 B3
Nvidia Titan Xp
2x4GB Super Talent DDR3-1600 CL9
Western Digital Caviar Black WD1001FALS
Optical Drive
LiteON iHBS212
Seasonic X750
EK Supreme HF Copper/Acetal
Alphacool HF D5 acetal pump top
6x Noiseblocker NB-BlackSilentPro PK-PS 140mm PWM Fans
4x Noiseblocker NB-BlackSilentPro PLPS 120mm PWM Fans
Bitspower Water Tank Z-Multi 150
Aquacomputer Flow Rate Sensor "High Flow USB" G1/4
Bitspower black compression fittings
Tygon silver tubing 0.5" ID 0.75" OD
2x Watercool HEATKILLER® GPU-X³ GTX TITAN/780/780Ti "Hole Edition" Ni-Bl
Aquacomputer D5 pump (USB/Aquabus)
EK CoolStream XTC 420
Lian Li PC-A77A Silver
Operating System
Windows 10 Pro x64
Hewlett Packard LP2475W
Keyboard
Ducky Shine II
Mouse
Logitech MX Revolution
Audio
RME Fireface 800
Audio
Dynaudio BM6A
i7 2600K
Gigabyte GA-Z77X-UD5H
EVGA GTX980ti
EVGA GTX980ti
Corsair Vengeance
Western Digital Caviar Black WD1600JD
Western Digital WD20EARS (2), WD20EARX (1), WD20ERFX (2)
Seasonic X760
Thermalright HR-02
Lian Li PC-A77F
Operating System
Ubuntu Server 12.04 LTS x64
valvehead is offline
post #13983 of 14069 (permalink) Old 06-03-2020, 12:40 AM
Awaiting the REP Rebuild
gftgy's Avatar
Rep: 41 (Unique: 36)
Quote: Originally Posted by ManniX-ITA View Post
Sorry I had a look at the picture and had the impression they were both purple
Took out the adapter and indeed one is black,
It doesn't really matter which one you put where, the relay will either close or open wire 1/2 with wire 3.
Just like shortening the power on pins with a screwdriver head.
For correctness put the black one on pin 3 and purple on pin 1.
What about this green wire? Are you absolutely certain? What you've said doesn't seem to align with the threads you linked earlier.
gftgy is offline
post #13984 of 14069 (permalink) Old 06-03-2020, 01:06 AM
Old crazy guy
ManniX-ITA's Avatar
Rep: 22 (Unique: 14)
Of course it doesn't sorry I didn't check properly
Doing too much stuff in parallel...
Obviously it's the green wire as described in the threads.
You have to split the green wire.
Don't connect the purple and black, it's the Standby voltage.
Had to find out months ago how to connect it but then I didn't and meanwhile my memory faded away...
Pandorum
(12 items)
Ryzen 3800x
GigaByte X570 AORUS Master
MSI GTX 1070 Armor OC
G.Skill DDR4 F4-3600C16-GTZNC 16-18-19-32-48-1T
Samsung M.2 970 PRO 1TB
EVGA SuperNova 1300 G2
beQuiet Dark Rock Pro 4
Corsair 750D Airflow
Operating System
Windows 10 Pro
Asus VG248 144MHz
Keyboard
Logitech G15
Mouse
Logitech G502 Lightspeed
ManniX-ITA is offline
post #13985 of 14069 (permalink) Old 06-03-2020, 01:37 AM
Big Radiators!
war4peace's Avatar
Rep: 33 (Unique: 27)
Because it offers a quick and inexpensive way to eliminate vibrations at certain speeds, and you can fine-tune it for absolute silence.
And because most pumps nowadays are PWM
There is no need to run at 100%, as well as there's no need to reduce pump speed to less than that. Certainly not to "increase pump lifespan".
I was referring to people recommending lower pump speeds to "avoid damaging the pump", I have no quarrel with people setting their pump speeds for other reasons. To each their own.
I wonder why would the pump make noise in the first place. I assume it's about how it's installed in the system.
I eliminated noise by oversizing the radiator. Fans at 400 RPM at all times, pumps at 100% (both of them), liquid temperature almost never exceeds 40 degrees Celsius except while very heavy gaming in SLI during very hot summer days, and then fans ramp up to 500-550 RPM to maintain 40 degrees Celsius liquid temperature. Right now ambient temperature is 23.7 degrees Celsius and liquid temperature is 26.8.
Larger reservoir? It has nothing to do with cooling, except maybe introducing some 30-second delay in liquid temperature stabilization (by the way, that delay works both ways). That is, of course, unless you have a 50L reservoir
My Rig Temps in Real Time
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
Gigabyte 1080 Ti Waterforce Extreme Edition 11Gbps
Kingston HyperX 2x 16GB DDR4 3000MHz
SSD Samsung 850 EVO 1TB
SSD ADATA 512 GB
Patriot Hellfire 240 GB M.2 SSD nVME
Super Flower Leadex Gold 750W
Corsair AX860
Custom Loop, EKWB, CPU+GPU, soft tubing
Thermaltake Core X5
Operating System
Windows 10 Professional X64
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
war4peace is offline
post #13986 of 14069 (permalink) Old 06-04-2020, 01:49 PM
professional curmudgeon
looniam's Avatar
Rep: 836 (Unique: 465)
believe what you want but it does increase the life span and more than your underestimated 5%. that is not anything i know from reading posts in FB groups or forums like here. that is what i know from first hand experience as a machinist mate in the navy; operated/maintained/repaired close to every pump imaginable on a ship.
but you are more than welcome to disagree because really - its nothing that will harm anyone/anything anyway - any warranty is suppose to consider 100% speeds so . .
i hope we are cool with disagreeing because now i got a favor to ask:
just got a pair of the noctua 3K leaf blowers and maxing out at 2250rpm. do those require the diane mod to get 3K? i was going for the 2K but these were the same price and can live with it but . .
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
If you need help:
Upload the computer to Dropbox and provide a link to it so others may download it to examine and give advice for repairs.
*this post has been sponsored by Pabst Blue Ribbon.*
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is offline
post #13987 of 14069 (permalink) Old 06-04-2020, 03:32 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 735 (Unique: 387)
my MCP35x2 has been running nearly 24/7 @ 100% for nearly 10 years.
My secret?
either the fan that blows air on it, or my obscenely clean loop + obscenely well maintained coolant.
Add me on Steam, same name
skupples is offline
post #13988 of 14069 (permalink) Old 06-05-2020, 04:52 AM
Big Radiators!
war4peace's Avatar
I've heard the same argument before... someone brought (as argument) a reference to an article discussing pump wear for industrial pumps (something like 30K gallons per minute) and how that affects the impeller, etc. The article was correct. The argument wasn't, because you can't put an equal sign between an elephant and a Chihuahua, because they are both mammals and have four legs. Watercooling pumps operate differently from high volume pumps on a ship, with different wear and tear, etc.
About the fans, have you tried running them without PWM pin? Aka just connected to 12V? If they reach 3K RPM (12V, ground, RPM pin), then it's the PWM implementation stopping them from reaching 3K RPM. If they don't reach that speed, there's something off with the fans themselves.
I run 2K RPM Noctuas on my NAS in the attic, directly connected to PSU throgh a molex, with RPM pin connected to the motherboard for control and they reach 2K RPM.
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
SSD ADATA 512 GB
Corsair AX860
Thermaltake Core X5
Operating System
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
post #13989 of 14069 (permalink) Old 06-05-2020, 06:24 AM
gftgy's Avatar
I picked up 9 of those and all of them cap out at around 2800rpm on their own, but they don't have the surplus torque to maintain those speeds when faced with restrictions like filters and radiators, and a drop to 2250rpm max seems plausible with enough restriction. Have you tested them on their own?
Considering that they run on 12v, their tremendous range (~300-~2800rpm in my batch), and spectacular build quality, I'm pretty happy with them; but I'm curious about this "Diane mod" you mention.
gftgy is offline
post #13990 of 14069 (permalink) Old 06-05-2020, 09:50 AM
Big Radiators!
war4peace's Avatar
It's IT Diva's Mod.
Box of Horrors
(16 items)
Intel Core i7 6800K
Asus X99-A II
SSD ADATA 512 GB
Corsair AX860
Thermaltake Core X5
Operating System
Dell 2407WFP
Keyboard
Logitech G510
Mouse
Logitech G700S
