OCN Aquaero Owners Club - Page 211 - Overclock.net - An Overclocking Community
post #2101 of 13105 (permalink) Old 09-27-2014, 03:47 AM
Aqua Computer Staff
Shoggy's Avatar
Rep: 126 (Unique: 96)
It reads the water temperature and it MUST be listed in the sensor tab if you have also connected the sensor with an aquabus cable to the aquaero.
Got a question or having trouble with your Aqua Computer product?
Contact us via PM or E-Mail.
Shoggy is offline
post #2102 of 13105 (permalink) Old 09-27-2014, 05:14 AM
Captaincaveman's Avatar
Rep: 5 (Unique: 5)
Sorry, should have mentioned that I have it connected to the motherboard via usb cable.
Is there a way to get it working when it's connected via usb?
Captaincaveman is offline
post #2103 of 13105 (permalink) Old 09-27-2014, 05:35 AM
Missing friends
Mega Man's Avatar
Rep: 700 (Unique: 431)
news update, i have a new AQ6XT otw for my s3 build, although it is not a new mod i am going to separate the PCB from the display as there is not enough room behind the rad ports,
Rigbuilder and how to put it in your sig post-flame-small.gifpost-flame-small.gifpost-flame-small.gifpost-flame-small.gifpost-flame-small.gifpost-flame-small.gif budget components = budget resultsPearls before swine! (Click to show)
Also rma wise, regardless of what vendor used it's always like getting a tooth pulled imo.
I facepalmed when trying to explain cpu and gpu overclocking to him after he got his 4930k. It was like teaching trigonometry to a rock.
That's like wrapping your car around a pole then asking for warranty service.
Dont be hard on yourself, we all break stuff sooner or later.
I don't appreciate your judgment here. I am just stating facts. That's all I'm doing. If you are taking offense to it or something, then that's not my problem, so don't put it on me. Ok?...Good god man. You would know that if you would actually carefully read...
Mega Man is offline
post #2104 of 13105 (permalink) Old 09-27-2014, 06:59 AM
Aqua Computer Staff
Shoggy's Avatar
No, this requires an aquabus connection.
Shoggy is offline
post #2105 of 13105 (permalink) Old 09-27-2014, 07:19 AM
Rep: 5 (Unique: 5)
Thanks for the help!
Is there a way to select which monitor AquaSuite is using when showing a page on the desktop?
post #2106 of 13105 (permalink) Old 09-27-2014, 07:24 AM
Aqua Computer Staff
Shoggy's Avatar
The aquasuite takes the entire available space for the desktop mode so you only have to move your stuff more to the right for example. Watch out for the scroll bar wink.gif
Shoggy is offline
post #2107 of 13105 (permalink) Old 09-27-2014, 12:56 PM
yesdoitmorelike's Avatar
Rep: 0
is 4 the maximum number of virtual sensors? i have 4 and cant see any way to create another. tx.
yesdoitmorelike is offline
post #2108 of 13105 (permalink) Old 09-27-2014, 12:57 PM
Aqua Computer Staff
Shoggy's Avatar
It is the maximum.
Shoggy is offline
post #2109 of 13105 (permalink) Old 09-27-2014, 01:21 PM
Linux Lobbyist
massimo40mq's Avatar
Rep: 0
Originally Posted by Shoggy View Post
It is the maximum.
Hi all I have a problem I think with one of the 3 I have a Poweradjust aquareo 6 XT can not seem to connect them in parallel with each other to see them in aquasuite, I see only one and when I try to connect the other I do not see anything .. Among the top I think the problem is that windows does not recognize the usb, I always mistake with one of them and I think it's a failure. Can someone please make me an outline of how these components are to be connected?
2 Poweradjust 3 connected to Aquareo 6 xt via Aquabus and alternative usb .. Thanks to all.
massimo40mq is offline
post #2110 of 13105 (permalink) Old 09-27-2014, 01:33 PM
Aqua Computer Staff
Shoggy's Avatar
You have to assign different aquabus ID numbers to the poweradjust controllers. That can be done in the system tab of the poweradjust when it is connected via USB.
It does not matter how you connect the poweradjust to the aquabus as long as it is connected in some way. It is a real bus system.
Shoggy is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
SuprPwrUsr
