OCN Aquaero Owners Club - Page 214 - Overclock.net - An Overclocking Community
post #2131 of 13066 (permalink) Old 09-29-2014, 02:48 AM
Linux Lobbyist
massimo40mq's Avatar
Rep: 0
Originally Posted by Shoggy View Post
If you use two poweradjust with the aquaero you have to make sure that they use different aquabus ID numbers. This value can be only changed when the controller is connected via USB. It should be enough the change the ID of the correctly working controller since the faulty one should still use its default ID number. I have no idea why one controller does not work via USB - maybe it is damaged.
There are currently no plans to offer an aquaero 6 LT.
As the big sticker on his box says: "Sonderanfertigung" means it is a custom-made product and not a regular one. An no, not anyone can order it like that. It was just made this way because of his mod.
No, it has no effect on the fans or a pump. The aquaero 6 has nothing but advantage over all its predecessor.
We are not aware of any problems here. Do you also use Open Hardware Monitor at the same time? Maybe you should install the aquasuite again and select a to perform a new installation so the config and database files will be reset. You can also do the manually by deleting the folder C:\ProgramData\aquasuite-data.
I'm trying to change the id number Aquabus via the controller 6 aquareo but I can not find in the menu 'aq6. Could you indicate in which section menu can I find? Thanks.
massimo40mq is offline
post #2132 of 13066 (permalink) Old 09-29-2014, 03:03 AM
Aqua Computer Staff
Shoggy's Avatar
Rep: 126 (Unique: 96)
You have to change this setting in the poweradjust menu; not in the aquaero menu:
This menu is only visible when the poweradjust is connected via USB and has power from the power supply unit.
Got a question or having trouble with your Aqua Computer product?
Contact us via PM or E-Mail.
Shoggy is offline
post #2133 of 13066 (permalink) Old 09-29-2014, 03:15 AM
Linux Lobbyist
Rep: 0
That's why I thought it was not smile.gif. Thanks anyway but already know how to usb does not recognize it and then I'll need a signature for this pa3 .. Thank you very much for your help, Have a nice day.
post #2134 of 13066 (permalink) Old 10-01-2014, 04:10 PM
Captaincaveman's Avatar
Rep: 5 (Unique: 5)
I cannot seem to be able to setup a curve controller for my dual mcp-655 pumps.
Pumps get their power from molex and are connected to fan header number 4 of the AQ6 with a splitter (4 pin all the way). I have RPM reading on that fan header.
In aquasuite I got to Fans, select Fan 4, click advanced setting and select PWM controlled.
Then I go to controllers, click the big plus sign at the top to add another one and select curve as its type.
I select one of the sensors as data source for the controller and fan 4 as output.
If minimum power (in fans) for fan 4 is set to anything below 100, the pumps stop completely.
Any tips?
Captaincaveman is offline
post #2135 of 13066 (permalink) Old 10-01-2014, 04:31 PM
VSG
Call me VSG
VSG's Avatar
Rep: 795 (Unique: 445)
Isn't the MCP655 just a D5 Vario? It is controlled via the knob on the back, not by changing PWM signal.
Does anyone know if it is possible to mute the AQ6 touch screen, especially the Up and Down buttons?
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><b>Reviews</b><span>: </span><a href="https://www.overclock.net/t/1638379/ocn-labs-acer-xr382cqk-bmijqphuzx-38-freesync-monitor/0_50">Acer XR382CQK Monitor</a><span> | </span><a href="https://www.overclock.net/t/1632881/ocn-labs-netgear-nighthawk-s8000-gaming-streaming-switch/0_50">Neatgear Nighthawk S8000 Switch</a><span> | </span><a href="https://www.overclock.net/t/1509787/my-review-of-the-ek-supremacy-evo">EK Supremacy Evo</a><span> | </span><a href="https://www.overclock.net/t/1510189/my-review-of-the-corsair-graphite-380t/0_50">Corsair Graphite 380T</a><span> | </span><a href="https://www.overclock.net/t/1516369/my-review-of-the-swiftech-mcp50x-pump/0_50">Swiftech MCP50X</a><span> </span><a href="https://www.overclock.net/t/1520512/the-quad-rad-roundup/0_50">Quad Rad Roundup</a><span> | </span><a href="https://www.overclock.net/t/1526779/user-review-of-the-swiftech-h220-x/0_50">Swiftech H220-X</a><span> | </span><a href="https://www.overclock.net/t/1530984/user-review-of-the-phanteks-ph-tc14pe/0_50">Phanteks PH-TC14PE<br></a><span> </span><a href="https://www.overclock.net/t/1551158/sponsored-review-of-the-ek-fc-asus-x99-rve-monoblock/0_50">EK Asus x99 R5E Monoblock</a><span> | </span><a href="https://www.overclock.net/products/tesoro-gram-spectrum/reviews/7424">Tesoro Gram Spectrum Keyboard</a><span> | </span><a href="https://www.overclock.net/products/cherry-mx-6-0-keyboard/reviews/7436">Cherry MX 6.0 Keyboard</a><span> |</span><a href="https://www.overclock.net/t/1604461/user-review-of-the-gigabyte-x99-phoenix-sli-motherboard/0_50">Gigabyte x99-Phoenix SLI motherboard</a><span> | </span><a href="https://www.overclock.net/t/1613371/sponsored-corsair-k70-rgb-rapidfire-keyboard-review/0_50">Corsair K70 RGB RAPIDFIRE Keyboard</a><span> | </span><a href="https://www.overclock.net/t/1531984/user-review-of-the-hwlabs-black-ice-sr2/0_50">Black Ice SR2 360</a><br></div></div></div>
VSG is offline
post #2136 of 13066 (permalink) Old 10-01-2014, 05:20 PM
Missing friends
Mega Man's Avatar
Rep: 700 (Unique: 431)
Yes you can but I am not at home to tell you how
Rigbuilder and how to put it in your sig post-flame-small.gifpost-flame-small.gifpost-flame-small.gifpost-flame-small.gifpost-flame-small.gifpost-flame-small.gif budget components = budget resultsPearls before swine! (Click to show)
Also rma wise, regardless of what vendor used it's always like getting a tooth pulled imo.
I facepalmed when trying to explain cpu and gpu overclocking to him after he got his 4930k. It was like teaching trigonometry to a rock.
That's like wrapping your car around a pole then asking for warranty service.
Dont be hard on yourself, we all break stuff sooner or later.
I don't appreciate your judgment here. I am just stating facts. That's all I'm doing. If you are taking offense to it or something, then that's not my problem, so don't put it on me. Ok?...Good god man. You would know that if you would actually carefully read...
Mega Man is offline
post #2137 of 13066 (permalink) Old 10-01-2014, 05:29 PM
VSG
Call me VSG
VSG's Avatar
VSG is offline
post #2138 of 13066 (permalink) Old 10-01-2014, 05:45 PM
Unicr0nhunter's Avatar
Rep: 523 (Unique: 351)
Swiftech definitely sells a PWM version of the MCP655.
https://www.google.com/search?q=Swiftech+MCP655-PWM
Not sure if that's what Captaincaveman has or not, but if it came with a 4-pin fan connector and a 4-pin molex then that's what it sounds like.
Unicr0nhunter is offline
post #2139 of 13066 (permalink) Old 10-01-2014, 05:51 PM
VSG
Call me VSG
VSG's Avatar
Looks to be a FCPU/Swiftech exclusive, but good to know. I was aware of PWM D5s but wasn't aware of the MCP655 variant of it thumb.gif
VSG is offline
post #2140 of 13066 (permalink) Old 10-01-2014, 06:31 PM
Gabrielzm's Avatar
Rep: 399 (Unique: 201)
XSPC, EK, Alphacool all of them offer now the D5 PWM variant:
http://www.performance-pcs.com/catalogsearch/result/?q=d5+pwm
btw I should known about the mute thing since I did that....Let's see if I can recall. Ok, go to user interface, keys, keys tone and then "off". thumb.gif
Gabrielzm is offline
