GPU brackets for mounting Antec 620/920 and Corsair h50/70/110 - Page 3 - Overclock.net - An Overclocking Community
post #21 of 39 (permalink) Old 03-26-2014, 06:52 AM
2jzohno's Avatar
Rep: 0
Have you considered mocking up one for Coolit designed pumps? H60, H80i, H100i etc
2jzohno is offline
post #22 of 39 (permalink) Old 03-26-2014, 07:14 AM
richie_2010's Avatar
Rep: 175 (Unique: 150)
3mm holes are perfectly fine, however use m2 2mm thick screws as some older cards use smaller screw holes for the heat sinks.
the only way i know for the square pumps is the old dwood square but i think that was even more limited due to size and it being sat on the card.
i decided to do a universal approach for both style pumps with my 2 point bracket which works really well and gives alot of flexibility to the user. because i cant cut mine myself i had a large batch made and i would say do the same.
if you need any help/any questions send me a pm
richie_2010 is offline
post #23 of 39 (permalink) Old 03-26-2014, 07:18 AM
pc-illiterate's Avatar
Rep: 359 (Unique: 284)
most pcb are drilled for 4mm and/or 8-32 bolts i believe. it would depend on that size and what size nut/bolt/washer combo you supply. minimum screw/nut/washer size is going to be 3mm. and using my rads as an example, 3mm threads are weak. good 8-32 should work for bolts because i think thats what swiftech supplies with their uni blocks.
you really should slot the 53(.2) holes to allow for actual 54mm mounting. you dont want someone complaining because they used your bracket and chipped, possibly cracking their pcb while tightening your bracket down. a 7950/70 would be expensive to replace.
pc-illiterate is offline
post #24 of 39 (permalink) Old 03-26-2014, 08:12 AM - Thread Starter
Shazberries's Avatar
Rep: 0
Sorry, I do not think I will be doing a bracket for square mounts, and If I do, it will definitely be after I figure out the brackets with circular mounts. I do plan to do brackets with and without fan mounts however. smile.gif
Oh, and my reasoning for not wanting to do the square bracket is simple, it seems more difficult and most coolers are circular, sorry!
Ok, so 3mm holes are fine as long as I get 2mm thick screws... And could you help me with my holes around the bracket circle itself? I figured the way I did it would give the most flexibility, however if you say you have a better way, by all means, let me know! I am very open to suggestions...
I don't know if I'm understanding this correctly... Are you saying that 3mm would be too small and I should make my holes 4mm? And I am still experimenting with the holes around the cooler part of the bracket... I have friends with AMD cards and potentially the ability to use a 3D printer at my school. So I will update when I have more news.
As for now, I have the first prototype done and hopefully I can 3D print it just to see how it looks and feels on my PCB!
IMPORTANT: One quick thing, I cannot talk about the selling or you guys buying these because I am not an artisan and I have been contacted by a mod and told so. So if you do post something about buying my design, it will be deleted by a mod. frown.gif
Thanks for all the help so far!
Shazberries is offline
post #25 of 39 (permalink) Old 03-26-2014, 08:20 AM
pc ill is meaning the holes on the pcb are set for 4mm diameter or slightly bigger.
keep your holes as 3mm but use thinner screws because if you paint em it will make the internal diam smaller.
you have the correct dimensions in the pic you liked buddy for the pcb spacings.
post #26 of 39 (permalink) Old 03-26-2014, 09:13 AM - Thread Starter
Rep: 0
How will I be able to fit a screw through a 3mm hole and then screw it into a 4mm hole? I will be washers or a backplate I assume?
post #27 of 39 (permalink) Old 03-26-2014, 09:17 AM
The thread on the screw be 2mm but the heads bigger. Pass the screw through the back of the pcb put the thread through the hole on your bracket n tighten with a nut. Use washers on the card to prevent shorts
post #28 of 39 (permalink) Old 03-26-2014, 09:52 AM
Gereti's Avatar
Rep: 16 (Unique: 10)
Gereti is offline
post #29 of 39 (permalink) Old 03-26-2014, 11:13 AM - Thread Starter
Rep: 0
UPDATE:
Yay! I am able to use the 3D printer, however I had to split the bracket in half because the printer is very small... It also might be wonky because it's very thin. Let's just hope for the best! If this works, I will have a good design done very soon, since I won't have to get the prototypes made from metal.
post #30 of 39 (permalink) Old 03-26-2014, 11:41 AM
a 2mm screw will be too small. a 2mm washer would be too small and flimsy being made from nylon to hold itself out of a 4mm hole. the bracket holes will need to be the same size as the holes in the pcb. i am a mechanic, a machinist and a metal worker. i also know exactly what i did and saw when putting on my universal gpu blocks. i am just trying to save you a headache and time and possibly money.
good luck.
