GPU brackets for mounting Antec 620/920 and Corsair h50/70/110 - Page 4 - Overclock.net - An Overclocking Community
post #31 of 39 (permalink) Old 03-26-2014, 12:52 PM - Thread Starter
Shazberries's Avatar
Rep: 0
Originally Posted by pc-illiterate View Post
a 2mm screw will be too small. a 2mm washer would be too small and flimsy being made from nylon to hold itself out of a 4mm hole. the bracket holes will need to be the same size as the holes in the pcb. i am a mechanic, a machinist and a metal worker. i also know exactly what i did and saw when putting on my universal gpu blocks. i am just trying to save you a headache and time and possibly money.
good luck.
I really do appreciate your advice... What size holes on the bracket and what size(diameter) screws would you recommend? Do you think I should do 3mm holes with 3mm screws? or 4mm holes with 4mm screws to fir the pcb?
Shazberries is offline
post #32 of 39 (permalink) Old 03-26-2014, 02:38 PM
pc-illiterate's Avatar
Rep: 359 (Unique: 284)
i take back what i said about screw sizes. just to be sure i dug out my install instructions for the uni block. swiftech instructions say they use a 2-56 screw to fasten the block to the pcb. i imagine this leads to a 3mm hole through the pcb and mount.
please discard anything else ive said about sizes. all i can say for sure is once you remove your heatsink from your graphics card, you can see what size screw fits through that hole.
sorry for my lack of research and memory retention before commenting. at least i was smart enough to double check before commenting anymore...
actually i would pull a heatsink from a graphics card and just measure bolt clearance before doing any printing.
pc-illiterate is offline
post #33 of 39 (permalink) Old 03-26-2014, 03:17 PM - Thread Starter
Rep: 0
Ok, well I should have a 3D model printed by Friday and I will be able to see for sure then... I might end up doing the slotted hole too, but I will see... I have some friends with AMD cards who can test this for me...
post #34 of 39 (permalink) Old 03-26-2014, 04:46 PM - Thread Starter
Rep: 0
What size 2-56 screws? Is 2-56 the head size or the thread?
post #35 of 39 (permalink) Old 03-28-2014, 12:55 AM - Thread Starter
Rep: 0
UPDATE:
Should get to see the 3D printed model tomorrow and also visit a metal shop soon!
post #36 of 39 (permalink) Old 03-28-2014, 10:14 AM - Thread Starter
Rep: 0
Torvi and I have been talking and he suggested that instead of just using a fan on the other side of the bracket, that I use both a low profile heatsink + low profile fan... Wouldn't this require people to take the fins off their vrm? and cause cooling issues with that? Or am I completely wrong? I would love to get as much cooling as possible, so if you guy think it's better, Ill do it.
post #37 of 39 (permalink) Old 03-28-2014, 10:38 AM
if their is already a heatsink on the vrm and/or the vram, there is no reason to remove it. if the overclock someone wants to run requires more vrm cooling than the factory heatsink plus a fan supplies, that someone needs to invest in custom water cooling.
post #38 of 39 (permalink) Old 03-28-2014, 10:58 AM - Thread Starter
Rep: 0
Yeah, those were my thoughts as well. There's no point in getting rid of the already present vrm cooling fins... A fan and water cooling bracket should be just fine.
post #39 of 39 (permalink) Old 04-10-2014, 08:43 PM
On The Red Team
Roboyto's Avatar
Rep: 255 (Unique: 164)
Any updates?! :)
My buddy just bought a 280X and is itching to get a watercooler on it
Vega Has Ryzen
(15 items)
Ryzen 1700
Gigabyte B450 Aorus mATX
AMD Radeon VII
8GB Patriot Viper 4 3200Mhz
256GB NVMe WD Black
WD Black 6TB
Corsair RM1000x
Mostly XSPC
Corsair Obsidian 350D
Operating System
WinX Enterprise LTSC
LG 34" UW 2560 x 1080
(2) LG 23" 1920 x 1080
Keyboard
Corsair Strafe RGB - Cherry MX Silent
Mouse
Corsair Scimitar RGB
Audio
Logitech Z623
Roboyto is offline
