GPU brackets for mounting Antec 620/920 and Corsair h50/70/110 - Overclock.net - An Overclocking Community
post #1 of 39 (permalink) Old 03-25-2014, 06:24 PM - Thread Starter
Shazberries's Avatar
Rep: 0
Hey guys!
My name is Andrew and I plan on building myself a bracket, similar to what Dwood did before he dropped off the face of the planet stun.gif
I will be mounting my Corsair H110 to my Nvidia GTX 670, but the bracket will also work with Antec coolers as well.
I was interested in seeing if anyone would be interested in helping me get some measurements.
Basically, my dilemma is the fact that I do not own a ton of graphic cards... I own a GTX 670 and a GTX 560. I could really use help figuring out the distance between the mounting holes around the gpu itself.
Here's what I got so far:
This is a rough sketch, and I plan to do a better job using some CAD software, but around the part where you would connect your water cooler, there's three circles. I found some table online, but it's pretty old and doesn't include a lot of newer models of GPUs.
So if anyone could confirm or deny the measurements and give their specific graphics card,
So far, this is what I have for compatibility (please confirm or deny this, as well as add to it, it would help so much!)
Compatible coolers:
Corsair H50, H55, H70, H75, H90, H105, and H110
Antec Kuhler H2O 620 and 920
Measurements for the holes around the cooler:
53mm x 53mm
55mm x 55mm
58mm x 58mm
51mm x 61mm
These holes ^^ should fit these graphics cards, and if they don't please let me know! (this is the table that I was talking about earlier)
With the 4 sets of holes mentioned earlier, all these cards should fit as well:
Nvidia: GTX 780 Ti, 780, 770, 760, Titan, 680, 670, 660Ti, 660, 580, 570, 560Ti, 560, 560SE
AMD: R9 290X, 290, 280X, 280, 270X, 270 HD7970, 7950, 7870, 7850, 6970, 6950, 6870, 6850, 6790, 6770, 5870, 5850, 5830
P.S. I really hope I'm not posting this in the wrong forum... If I am, please let me know, and I'll move it to wherever it should be! Thanks for reading!
Andrew
Shazberries is offline
post #2 of 39 (permalink) Old 03-25-2014, 06:39 PM
pc-illiterate's Avatar
Rep: 359 (Unique: 284)
nVidia GeForce GTX470, 480, 570, 580
58.4mm
http://www.swiftech.com/GT400-REV2-Mountingkit.aspx
Radeon™ 7900 series (HD7970 and HD7950).
series 54mm mounting hole form factor (as opposed to all other single GPU Radeon series that feature a 53.2mm hole mount),
http://www.swiftech.com/mcw82vgawaterblock.aspx#tab3
Pre-2009 : nVidia GeForce 8 (G80) series
58.4mm
http://www.swiftech.com/MountingkitG80.aspx
Pre-2009 : nVidia GeForce 9 series
Post 2009: nVidia GeForce 200 series
61mm
http://www.swiftech.com/MountingKitGT200.aspx
nVidia GeForce GTX 460 series , GTX 560-TI series
61mm x 51mm
http://www.swiftech.com/MountingKitGTX460.aspx
this also gives a decent bit of info for you
http://www.swiftech.com/mcw82vgawaterblock.aspx#tab4
pc-illiterate is offline
post #3 of 39 (permalink) Old 03-25-2014, 06:43 PM - Thread Starter
Rep: 0
I really appreciate it man! Thanks!
I kind of want to decide on 3 or 4 holes for the bracket. Any more would seem ridiculous... Which ones should I go for? I was thinking 58.4mm, 53.3mm, 61mm, and 51mm x 61mm.
post #4 of 39 (permalink) Old 03-25-2014, 07:06 PM
how are you machining them?
a slotted hole for the amd (53.2mm-54mm) would cover amd recent
but nvidia higher end (470/480/570/580/670/680 series ) would be 58.4
nvidia 460 and 560ti is the odd-ball rectangle 51x61
if youre using a cnc mill, no problem, do them as they are ordered. if not, you will have huge slots for hold downs that will be weak. you would not be able to do full universal.
i wish i had the software and/or know how to plot out the holes in actual size. might be able to do amd slot plus x70/x80 series nvidia on the same mount. special order a 460/560ti mount.
as stated earlier, good luck with your idea.
post #5 of 39 (permalink) Old 03-25-2014, 07:35 PM - Thread Starter
Rep: 0
@PC-Illiterate So you are suggesting that I do not try and add more than one set of holes, and make it per order?
I was kind of hoping to be able to do the slotted hole (53.2mm -54), 58mm and a 51mm x 61mm holes. Do you really think this would be too weak to do?
Would you suggest just doing an AMD bracket and an Nvidia bracket. AMD with the slotted hole and the Nvidia with the 58mm and 51mm x 61mm?
post #6 of 39 (permalink) Old 03-25-2014, 07:36 PM
EpIcSnIpErZ23's Avatar
Rep: 32 (Unique: 27)
I have the NZXT Kraken G10, and i love it. The Corsair H50 im running to cool it lowered my temps a ton. Good Luck with your idea! biggrin.gif
EpIcSnIpErZ23 is offline
post #7 of 39 (permalink) Old 03-25-2014, 07:55 PM
you could probably get away with a slotted amd hole and the nvidia 58mmsquare hole. you would need a heavy washer to keep even pressure im sure. the slot and the hole would probably be close and be weak without a washer. im not a metric mathematician (yes i spelled that without spell correct tongue.gif) though.
the 51mm part of the 51x61 would basically be right on the 53.2mm hole. you would up with a slot that goes up and then 90* to the right. that would definitely be a weak point. MIGHT be ok with a heavy washer there also. it all depends on what it looks like when its done obviously. im still not a metric man...
post #8 of 39 (permalink) Old 03-25-2014, 08:02 PM - Thread Starter
Rep: 0
So you are suggesting 1 hole that is for the 58mm hole and 1 slotted hole that does the 53.2-54mm slot as well as an arm that covers 51x61mm? The holes would end up looking like a "y" then an extra hole? I really like the idea of making it universal because then I don't have to worry about making different models.
post #9 of 39 (permalink) Old 03-25-2014, 08:13 PM - Thread Starter
Rep: 0
QUICK UPDATE:
I am currently trying to take my original sketch and make it in google sketchup. Hopefully having a CAD version will help me understand where I need to go with this. I will post pics once I am done.
post #10 of 39 (permalink) Old 03-25-2014, 08:21 PM
Torvi's Avatar
Rep: 18 (Unique: 16)
gogo smile.gif i wanted to put some good 140 mm watercooler on my gtx for so long, but there is no brackets for it. btw if you know where are rams located it would be nice to know. Also i had an idea on modding my gtx 770 by cutting original heatsink with grinder to make room for waterblock xD
http://files.overclock.net/images/smilies/doh.gifStock Cooler Clubhttp://files.overclock.net/images/smilies/doh.gif i5-4590 prime95 tested max temp 61c after 2 hours of stress test.
Steam Controller Owners club
rig:
i5-2500s
16gb ddr3 ram
gtx1050ti 4gb
240gb micron ssd
Torvi is offline
