240mm or 280mm radiator for cooler master storm stryker? xspc kits ax or ex? plz help - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 04-09-2014, 09:02 PM - Thread Starter
Rep: 0
ok i'm ordereing the storm stryker case.. and i was wondering what size radiator i should be for the top and which model of the xspc?
i'm looking at these 3 kits
the 280 kit with D5 pump: http://www.frozencpu.com/products/16551/ex-wat-217/XSPC_Raystorm_EX280_Extreme_Universal_CPU_Water_Cooling_Kit_w_D5_Variant_Pump_Included_and_Free_Dead-Water.html?tl=g30c321s1310
the ex 240 kit with d5 pump: http://www.frozencpu.com/products/16551/ex-wat-217/XSPC_Raystorm_EX280_Extreme_Universal_CPU_Water_Cooling_Kit_w_D5_Variant_Pump_Included_and_Free_Dead-Water.html?tl=g30c321s1310
or the AX 240 kit d5 pump: http://www.frozencpu.com/products/20837/ex-wat-261/XSPC_Raystorm_AX240_Extreme_Universal_CPU_Water_Cooling_Kit_w_D5_Variant_Pump_Included_and_Free_Dead-Water.html?tl=g30c321s1310
i'm not real sure if the ax 240 radiator is too thick to mount up top or not... i noticed it is better than the ex cuz its a little thicker... its 40mm thick and with a 25mm fan that makes it 65mm... i dont know if thats too thick for that case by the time it reaches the mobo or not.. the EX is 35.5mm thick which with a 25mm fan puts it at 60.5mm... i read that there is 60mm of space from top of case to top of mobo.. i dont know if thats exactly true or not... but at the same time im kinda interested in the 280mm radiator EX.. its 36mm thick... but more surface area... i really need to know this cases limitations for mounting at the top inside of case.. i've been googling for days and cant really find my answer so i'm coming here... if there are any better kits i should be looking at let me know...
looks wise if the AX 240 will fit i'm thinking about not getting the kit and buying separate... cuz i'm going to buy either red or orange uv hoses anyway... but this is radiator i really want to match the case
http://www.frozencpu.com/products/21115/ex-rad-638/XSPC_AX240_Dual_120mm_Radiator_w_Aluminum_Enclosure_-_White.html?tl=g30c95s160
please help...
i am getting the asus z87 formula motherboard
My System:
Intel Xeon X5460 @ 4.3z 1.35v
OCZ Vendetta HSF w/AC MX-2 Paste
EVGA 780i MOBO (pencil modded)
EVGA GTX 770
G.Skill PC8000 DDR2 4x2gb 8gb @ 900mhz 5-5-5-15 2.0v
2xWD AALS 500gb Black Edition HD's in Raid=0 1xSAMSUNG Spinpoint F1 HD103UJ 1TB HD for storage
Corsair 750TX PSU
Antec 1200 Case
Windows 7 64 bit
HEATWARE
chrome-187 is offline
post #2 of 4 (permalink) Old 04-10-2014, 07:43 PM - Thread Starter
Rep: 0
anyone? is there a different forum I should go to for this type of question?
My System:
EVGA GTX 770
Corsair 750TX PSU
Antec 1200 Case
Windows 7 64 bit
HEATWARE
post #3 of 4 (permalink) Old 04-10-2014, 09:24 PM
PachAz's Avatar
Rep: 62 (Unique: 44)
First of all the thickness of the rad will depend on your motherboard heatsinks. To be on the safe side, a 30mm thick will work with a set of 25mm fans, but you could get a thicker rad in if your motherboard layout allows that. I would take a 240mm rad because you can use the offset mounts in the top its also cheaper and will allow for easier tube routing because its more narrow than the 280mm one. If you choosing a 30mm one, take the alphacool st30.
The heatsinks on the formula are all over in the top they are also big, I would get a 30mm rad, to be on the save side. I think i have a picture of a 30mm one in my case with fans and you will see how tight it is.
PachAz is offline
post #4 of 4 (permalink) Old 04-10-2014, 09:35 PM
Case ***der
lowfat's Avatar
Rep: 452 (Unique: 305)
lowfat is offline
