PETG Tubing VS Acrylic Tubing Pros + Cons - Page 37 - Overclock.net - An Overclocking Community
post #361 of 387 (permalink) Old 05-27-2016, 06:05 AM
AT-Eduard's Avatar
Rep: 13 (Unique: 8)
Well, you can also fligh to the moon... everything is possible.... but normal people are not able to bent glass wink.gifbiggrin.gif
I think, if you like to bent glass, the best way is to ask a glass blower. But i have no idea how they bent glas smile.gif Dont think that they put someting inside the tube.... but i do not know.
AT-Eduard is offline
post #362 of 387 (permalink) Old 05-27-2016, 06:14 AM
Ypsylon's Avatar
Rep: 29 (Unique: 23)
Yeah. Everything is possible. Within reason even bending glass. Unfortunately flying to the Moon is too much for my wallet. biggrin.gif
Ypsylon is offline
post #363 of 387 (permalink) Old 05-29-2016, 01:10 AM
Devil in baggy pants
jsutter71's Avatar
Rep: 49 (Unique: 38)
Hello...I'm using EK exclusive compression fittings with PETG tubing. I've tried EK, Thermaltake, and Bitspower tubing and found that Bitspower makes the best by far. As far as clean cuts are concerned, You don't need to spend a fortune. I use this device with perfect results every time. It also allows you to make very precise cuts for corrections.
http://www.amazon.com/Ridgid-40617-4-Inch-8-Inch-Quarters/dp/B001P307PO?ie=UTF8&keywords=tube%20cutter&qid=1464508472&ref_=sr_1_3&sr=8-3
Here is my build log.
https://www.overclock.net/t/1595092/my-new-sth10-build/0_80
And some pics.
Here's some pics
Asus X99-E WS USB 3.1, Intel Core i7-6950x @ 4.4GHz
Dual Titan XP SLI, 64 GB G.SKILL TridentZ Series DDR4 3200 CL 14
Samsung 1 TB 960 pro & 1 Samsung 500GB 960 evo
jsutter71 is offline
post #364 of 387 (permalink) Old 07-23-2016, 01:42 PM
Rep: 1 (Unique: 1)
This tool from xspc cuts well PETG? Does it produce a clean cut with no need for sanding?
jvidia is offline
post #365 of 387 (permalink) Old 07-25-2016, 05:28 AM
Ypsylon's Avatar
If they sell it then for sure it works. Unlike PMMA, PETG is composite plastic, so it's like cutting plastic too. Sanding in general is not necessary with PETG. Slight adjustment of external edge for easier slide is advisable, but it will work without it.
Can't confirm quality of cuts as I don't own this one, but in general all cutters for composite tubes work exactly the same.
Ypsylon is offline
post #366 of 387 (permalink) Old 07-25-2016, 07:23 AM
Rep: 1 (Unique: 1)
Wont it squash the tube a little?
This tool isn't better: https://goo.gl/images/ESBbrj
Jayz2cents uses one of this kind.
Anyone uses this kind of cutter to cut petg?
jvidia is offline
post #367 of 387 (permalink) Old 07-25-2016, 10:44 AM
Lordevan83's Avatar
Rep: 6 (Unique: 5)
This has made working with acrylic tubing much faster
http://www.harborfreight.com/2-in-mini-bench-top-cut-off-saw-62136.html
Lordevan83 is offline
post #368 of 387 (permalink) Old 07-25-2016, 10:59 AM
Perennial Noob
jvillaveces's Avatar
Rep: 20 (Unique: 13)
That's a neat little tool, but it won't cut 16 mm or 5/8" tubing
Esmeralda
(25 items)
Eldorado
(23 items)
Overkill HTPC
(18 items)
Intel Core i7-6850K
RAMPAGE V EDITION 10
NVIDIA TITAN X (Pascal)
Corsair Dominator Platinum Special Edition Blackout
Samsung 960 Pro M.2
Samsung 850 Pro
Samsung 850 Pro
Samsung 850 Pro
Samsung 850 Pro
Seasonic SS-1200XP3 PLATINUM
EK-FC GeForce GTX FE Copper/Plexi Water Block (For GeForce 1060/1070/1080/1080Ti/TitanX Pascal and Titan Xp) -Nickel/Plexi Change
EK-FB ASUS R5-E10 Monoblock RGB Edition
Aquacomputer D5 Pump Mechanics USB with Aquabus (x2)
EKWB EK-XTOP Revo D5, Plexi (x2)
Watercool Heatkiller Tube 150
Black Ice SR2 420 radiator
Alphacool X-flow Nexxxos 420 radiator
Noctua SSO2 Bearing Fan NF-A14 iPPC-2000 PWM (x6)
Aquacomputer Aquaero 6 Pro
HexGear R80 Black
Operating System
Windows 10 Pro 64 bit
Asus ROG Swift 24
Keyboard
Razer Blackwidow Ultimate (Green)
Mouse
Corsair Sabre RGB 10,000 DPI
i7 4790k
Asus Z97-Deluxe
EVGA GeForce GTX980 Ti SC ACX2.0
Corsair Dominator Platinum 2133 MHz
Samsung 850 Pro
Optical Drive
Asus DRW-24B1ST
Corsair AX 1200i
EK Supremacy EVO nickel-plexi
Monsoon Free Center compression fittings (gold)
PrimoChill PrimoFlex Advanced LRT crystal clear
EK-FC Titan X - Nickel (x2)
Alphacool 140mm
Aquaero 6 Pro
Alphacool Nexxxos XT45 280 mm
Black Ice GTS 280 x 60
aquacomputer d5 pump mechanics with usb and aquabus interface (x2)
Bitspower Dual D5 Mod Top - POM Version
Bitspower D5 / MCP655 Pump Mod Top S Model - Acetal
Bitspower Water Tank Z-Multi 150 Inline Reservoir (true brass version)
Corsair 760T
Operating System
Windows 10 Pro x64
Keyboard
Razer Ultimate
core i5 6500
Asus Maximus VIII Gene
EVGA GeForce GTX 980 Ti 6GB SC+ GAMING ACX 2.0+
Corsair Vengeance LPX 16GB (4 x 4GB) DDR4 DRAM 2133MHz C13
Samsung 950 PRO -Series 256GB PCIe NVMe - M.2 Internal SSD 2-Inch MZ-V5P256BW
Optical Drive
Pioneer Electronics Internal Blu-Ray Writer (BDR-2209)
Seasonic 1050 Watt Gold
EK Coolstream SE 240
EK Coolstream SE120
Swiftech MCP655 PWM
EK-XRES 100 Revo D5 Pump Top/Reservoir - Acetal
EK-FB ASUS M8G Monoblock - Nickel
EK-FC Titan X/GTX980 Ti Waterblock - Nickel
Monsoon Free Center Hardline Compression Fittings, 1/2" x 5/8"
Monsoon PETG Hardline Tube 1/2 x 5/8
EK-Vardar F4-120 (2200rpm) High Performance Liquid Cooling Fan
Steiger Dynamics LEET Chassis
Operating System
Windows 10 Home
jvillaveces is offline
post #369 of 387 (permalink) Old 12-12-2016, 10:33 AM
mrkubanftw's Avatar
Rep: 0
Originally Posted by Unicr0nhunter View Post
Yeah but there have been reports (one at themodzoo iirc. EDIT: link) of PETG tube melting in the event of a momentary pump failure, something nylon tube nor acrylic is prone to do before a system powers down for a thermal event. Seems PETG has a lower melting point that could lead to a bad situation becoming something catastrophic.
I also would like to know more how PETG holds up over the long term seeing as it is not listed as being UV resistant like Acrylic. What effects, if any, will sunlight or UV case lighting have on it?
BTW, here's a vid B Negative posted in the acrylic pipebending 101 thread that probably belongs here just as well ...
Now ordinarily i would NEVER resurrect a thread from the dead, but this particular thread is a #1 google search for PETG VS ACRYLIC. If that's the case, it hurts me to see this thread so full of incorrect information. I melted a processor due to incorrect information presented in such fashion.
I'll start with this comment.
PETG does not have a lower melting point than ACRYLIC. In fact acrylic's melting point is roughly HALF of PETGS. You could stick PETG in the oven with a tombstone pizza and it should survive. Acrylic, however, has a melting point of about 160C, still not a temp you should be anywhere near as your cpu thermals itself into a shutdown.
Whatever video you cite, it seems much more likely they were using acrylic not petg.
Also i see all this talk about strength of the tubes. Come on. I mean really come on. You can throw out any engineering terms you want to describe these tubes, but miss the point entirely. As an engineer i'll tell you right now it wont come down to rigidity, tensile, torsional, nor elasticity, but a combination of all of these. Look for what you need the tube to do and ask yourself that question. It would be foolish to say acrylic isn't strong, its the same base as polycarbonate (the bulletproof stuff). PETG is known for its manufacturability.
And permeability? Come on. Everything is permeable by definition. Other than a nice gentleman explained how PETG is used largely in the bottling industry (should have been good enough information) The permeability issue... simply is not an issue. Consider it like a PVC as far as permeability goes. Its not too indifferent. PVC by the way are those schedule 40 pipes in your house rated to 600psi water pressure. PVC is also that stuff we used before hard pipes were a 'thing'. But to hell with my rambling, here's some of that awesome thing we call DATA: http://www.pod-sabic-ip.com/KBAM/Reflection/Assets/Thumbnail/10620_4.pdf
Personally... my case weighs like 80lbs. While it shouldn't REALLY be a LAN case, it looks bad ass, so i still lug it around to LANs. And like mentioned above, heavy cases twist, especially with an uneven load. Think your rig might be heavy? Look up the coreX9. It takes up my entire back-seat ffs. For myself, i would want something that's not prone to hairline cracking (i'm not saying acrylic DOES but it certainly can a lot easier than PETG). Also would want something that's pretty okay with some unintentional flex, for if intentional flex was our build goal, we wouldn't be having this discussion.
It comes down to this:
What do you want in a tube? Your answer could correctly land you at either PETG or ACRYLIC. There's no wrong answer.
mrkubanftw is offline
post #370 of 387 (permalink) Old 12-12-2016, 06:45 PM
lukerobi's Avatar
Rep: 3 (Unique: 2)
I'm doing my first petg loop right now and I wish I had just bought rubber hose. This crap is a pain to work with. Lots of trial and error... and I can never really tell if it is seated well in the fitting or not. Using bitspower 14mm.
Heat gun, cut, match up, cut, still doesn't fit, heat gun again, kind of fits.. force that **** to fit.
Maybe I'm doing it wrong? Videos are like the draw some circles then draw the rest of the ******* owl cartoon
lukerobi is offline
