PETG Tubing VS Acrylic Tubing Pros + Cons - Page 39 - Overclock.net - An Overclocking Community
post #381 of 391 (permalink) Old 12-03-2018, 01:26 AM
Hardware Rep
B NEGATIVE's Avatar
Rep: 789 (Unique: 492)
Quote: Originally Posted by mrkubanftw View Post
Quote: Originally Posted by Unicr0nhunter
Yeah but there have been reports (one at themodzoo iirc. EDIT: link) of PETG tube melting in the event of a momentary pump failure, something nylon tube nor acrylic is prone to do before a system powers down for a thermal event. Seems PETG has a lower melting point that could lead to a bad situation becoming something catastrophic.
I also would like to know more how PETG holds up over the long term seeing as it is not listed as being UV resistant like Acrylic. What effects, if any, will sunlight or UV case lighting have on it?
BTW, here's a vid B Negative posted in the acrylic pipebending 101 thread that probably belongs here just as well ...
Now ordinarily i would NEVER resurrect a thread from the dead, but this particular thread is a #1 google search for PETG VS ACRYLIC. If that's the case, it hurts me to see this thread so full of incorrect information. I melted a processor due to incorrect information presented in such fashion.
I'll start with this comment.
PETG does not have a lower melting point than ACRYLIC. In fact acrylic's melting point is roughly HALF of PETGS. You could stick PETG in the oven with a tombstone pizza and it should survive. Acrylic, however, has a melting point of about 160C, still not a temp you should be anywhere near as your cpu thermals itself into a shutdown.
Whatever video you cite, it seems much more likely they were using acrylic not petg.
Also i see all this talk about strength of the tubes. Come on. I mean really come on. You can throw out any engineering terms you want to describe these tubes, but miss the point entirely. As an engineer i'll tell you right now it wont come down to rigidity, tensile, torsional, nor elasticity, but a combination of all of these. Look for what you need the tube to do and ask yourself that question. It would be foolish to say acrylic isn't strong, its the same base as polycarbonate (the bulletproof stuff). PETG is known for its manufacturability.
And permeability? Come on. Everything is permeable by definition. Other than a nice gentleman explained how PETG is used largely in the bottling industry (should have been good enough information) The permeability issue... simply is not an issue. Consider it like a PVC as far as permeability goes. Its not too indifferent. PVC by the way are those schedule 40 pipes in your house rated to 600psi water pressure. PVC is also that stuff we used before hard pipes were a 'thing'. But to hell with my rambling, here's some of that awesome thing we call DATA: http://www.pod-sabic-ip.com/KBAM/Ref...il/10620_4.pdf
Personally... my case weighs like 80lbs. While it shouldn't REALLY be a LAN case, it looks bad ass, so i still lug it around to LANs. And like mentioned above, heavy cases twist, especially with an uneven load. Think your rig might be heavy? Look up the coreX9. It takes up my entire back-seat ffs. For myself, i would want something that's not prone to hairline cracking (i'm not saying acrylic DOES but it certainly can a lot easier than PETG). Also would want something that's pretty okay with some unintentional flex, for if intentional flex was our build goal, we wouldn't be having this discussion.
It comes down to this:
What do you want in a tube? Your answer could correctly land you at either PETG or ACRYLIC. There's no wrong answer.
Incorrect, Bottles are made of PET, not PETG for obvious reasons..... PETG is used for DRY materials,not wet.
Also PETG in a standard loop with no flow problems still collapses, I have spent the last few days designing a special part to stop this happening.... its such a problem that we were looking to stop selling it.
You literally have no idea what you are talking about, the deflection temp for PETG is lower than acrylic and thats the temp that matters. It does not have any material properties that we need.
Perhaps the pictures of PETG collapsed tube will convince you...tho I doubt it.....
B NEGATIVE is offline
post #382 of 391 (permalink) Old 12-03-2018, 01:45 AM
Just whatever flex tubing Food grade like stuff. Pretty Tolerant to quite a bit of stuff. That's something a little softer looks like or less or more wall, gets softer warps it etc.
Jspinks020 is offline
post #383 of 391 (permalink) Old 04-08-2019, 06:57 PM
82nd AD Vet
jsutter71's Avatar
Rep: 50 (Unique: 39)
Just got this monsoon bending kit. Beautiful and very high quality. All metal. I just started appreciating the value of these bending kits. For years I just eye balled it and wasted tons of money on tubing. FYI. I've been using PETG for the last 4 years now and unless your system is running at very high temps and your using cheap tubing then you shouldn't worry. I tried acrylic and it's a PITA to work with. It takes forever to soften while bending and it cracks way to easy. I have all the proper tools for both PETG and acrylic. My system is still the same as my signature and unless I'm running a stress test to remove bubbles never had issues with overheating. During one particular stress test for over heating the gaskets on my Reservoir began leaking way before the PETG did.
jsutter71 is offline
post #384 of 391 (permalink) Old 04-09-2019, 01:23 PM
NewUser16's Avatar
Rep: 56 (Unique: 37)
I never understood why people wouldn't go acrylic right from Get-go, you still have to bend PETG, so it takes faster to heat it up, is that the reason you willing to trade for some of the cons of PETG!
On the other hand..acrylic lasts forever, I have never ever cracked any of my tubes, even dropped it few times, acrylic doesn't absorb any liquid and has clearer look, you do it once and your done.
Long story short...Acrylic will always, always be better than PETG in every way you look.
Btw. I'm using Bitspower 16 OD 500mm clear acrylic, its superior product
NewUser16 is offline
post #385 of 391 (permalink) Old 04-10-2019, 02:01 AM
Leonko's Avatar
Rep: 3 (Unique: 3)
And one more important thing, PETG tubes costs 2times more then acrylic
but when im looking at it right now,... acrylic has thicker wall ? 16/12, PETG - 16/14
Leonko is offline
post #386 of 391 (permalink) Old 04-13-2019, 02:44 AM
Moderately Ancient
Andrew LB's Avatar
Rep: 26 (Unique: 21)
I spent a lot of time reading threads like this prior to building my first hard tubing loop and I ended up going with Bitspower Crystal Link 14mm Acrylic tubing. There were too many things about PETG that kept me from considering it such as its low deformation temp, incompatibility with glycol based coolants like XT-1 Nuke, and the clarity or lack thereof.
Intel i7-10700K @ 5.2 - Asus Prime z490-A - EVGA GTX 1080 - 32gb Corsair DDR4 3600mhz - Creative X-Fi Titanium HD - Adata 1tb M.2 - Samsung 512gb 860 Evo + 512gb 850 Evo - Phanteks Enthoo Pro M - Watercool DualDDC Top - 2x DDC1-T PWM 10w Pumps - XSPC Raystorm V3 CPU block - AquaComputer Pascal block - Barrow Tube Res - XSPC ex360 Rad w/3x Fractal Venturi 120mm fans - XSPC ex280 Rad w/2x 140mm Phanteks 140mm fans - Aquaero 5LT + Flow Meter - 14mm Barrow Fittings - Crystal-Link Acrylic Tubing
Andrew LB is offline
post #387 of 391 (permalink) Old 04-20-2019, 08:31 PM
82nd AD Vet
jsutter71's Avatar
My hard tube bending station. Finally decided to put some thought into the process and stop wasting tubing.
post #388 of 391 (permalink) Old 02-20-2020, 10:13 PM
Mooncheese's Avatar
Rep: 20 (Unique: 16)
Sorry to necro this thread, I'm somewhat new to water cooling and have discovered to my dismay that the soft EK Duraclear tubing I used with my first loop 2 years ago has become discolored due to moving the PC to a bright sunny room in new apartment. I wasn't aware that sunlight, particularly direct sunlight could do this to the tubing. Anyhow, now I'm thinking of going hard tubing to avoid this and am seeing in quite a few places that Acrylic doesn't have this problem, but PETG, while not as bad as soft tubing, does suffer from discoloration with UV exposure (direct and presumably indirect, i.e refracting from walls, ceiling and carpet etc.)
I don't want to have to change out the tubing again 2 years hence so therefore I am considering acrylic over PETG, even with all of it's disadvantages.
I hear 12/16 is more durable that 10/12 and is a good choice for someone intent on going this route.
I'm surprised to not see this shortcoming of PETG mentioned much in this thread. Discoloration sucks, if acrylic doesn't do that I'm going that route.
I wont be swinging a hammer in my PC nor will I be moving it Ace Ventura style (putting it in a box and throwing it down stairs). The only way I can see the acrylic breaking is while say maybe needing to repaste the CPU or change the GPU. I can't even see how an entire PC chassis shifting in a box, even rather abruptly, would cause this kind of breakage.
The only real downside I see to it is that you would be forced to use a hacksaw to cut it but even then, it seems to chamfer way better and easier.
Here's how my Duraclear soft-tubing looks after 5-6 months of intermittent (sunny one day, overcast the next) sunlight, about 1 hour of DIRECT sunlight a day (between 3-4 pm the sun will angle where it was directly casting onto PC).
From what I gather PETG will do the same thing in nearly the same amount of time. Actually, the discoloration has been ongoing, I only just seemed to notice it after flushing the system for GPU upgrade.
8700k @ 5.1 GHz - 0 AVX @ 1.386v Dynamic Offset w/ EK Monoblock + Delid | Gigabyte Z370 Aorus Gaming 7 | EVGA 2080 Ti XC2 Ultra @ 2070 Mhz core, 8025 MHz memory @ 1.019v w/ 375W FTW3 vbios + Phanteks Glacier Block | EK CE 420 + EK XE 360 | 2x16GB G-Skill Trident Z Royal 3600 MHz 17-20-20-38 | 2 TB Sabrent Rocket | Corsair RM1000x | Thermaltake View 71 | Alienware AW3418DW + Asus ROG Swift PG278Q (for 3D Vision) on Amazon Basics Arms | Win10 Pro 1809
Mooncheese is offline
post #389 of 391 (permalink) Old 02-21-2020, 11:10 AM
NewUser16's Avatar
Acrylic all the way.
1. Doesn't absorb liquid
2. It has absolutely no limitation on what liquid is used
3. Once bend to your liking, unless you change your component layout, It will last years.
4. Much more clear, then PETG
I have bend acrylic for my STH10 about 8 years ago, still to date looks like has been done yesterday and I have removed and put it together # of times upon upgrading my hardware, can you say the same about PETG?
I personally think, If you going through the effort of heating up and bending one , must well do it once and use the one that will last much longer without all the PETG hard rubber soaking your liquid in.
Site note... If you chose to go with acrylic, from my personal experience Bitspower's acrylic is very solid and durable product
post #390 of 391 (permalink) Old 02-21-2020, 01:54 PM
82nd AD Vet
jsutter71's Avatar
You know I totally respect your opinion but, you know theirs always gonna be a but I recently had the same conversation with a friend who was new to hard tubing and was dead set on acrylic. Like you I have also used both and after weighing the pros and cons made petg my choice in tubing. It’s like ford vs chevy. People tend to have strong opinions towards their choice. Even so, while I Personally don’t think I fall into the strong opinion category per se, I wouldn’t suggest acrylic to anyone who hasn’t mastered their bending skills. Unless they were only using straight tubing with angled adapters. Just my 2 cents.
Pics of my last build which ran 3 years with petg and never had any issues.
