[Build Log] "Silent Tree": A closed loop fitting bracket for Graphic Cards - Page 3 - Overclock.net - An Overclocking Community
post #21 of 40 (permalink) Old 05-30-2014, 03:20 PM - Thread Starter
What's a computer?
Rainmaker91's Avatar
Rep: 97 (Unique: 73)
I guess this is what everyone was waiting for, the bracket is finished!
Some progress pictures:
After painting it
with the masking tape removed
I mounted some power connectors for the leds and Fans with zip ties and holes in the bracket. Unfortunately hiding the cables proved to be a challenge, and the best alternative was standard electrical tape
And here it is with all the fans and the block mounted
Now I only need to set it all up in my PC so I will be uploading some pics of that when I get everything set up in my computer. I will be adding some leds and I will be changing the thermal paste on my CPU since I got some Phobya Nanogrease Extreme now and that trumphs Asetek stock tim.
Rainmaker91 is offline
post #22 of 40 (permalink) Old 05-30-2014, 06:09 PM
closestnum20's Avatar
Rep: 1 (Unique: 1)
thumb.gif lovin it!
closestnum20 is offline
post #23 of 40 (permalink) Old 05-30-2014, 06:45 PM - Thread Starter
What's a computer?
Got it installed in my PC now, but it seems one of the LEDs is gone so I will have to get some replacements in time. For now though I would say this is a success. I changed out my two Corsair SP120L fans with 4 Eloop b12-3 fans running at 1100 RPM constantly and core doesn't go over 41*C on stock voltage and clock. That is extreme since I could get 60-70*C before so something must have changed. As for the new heatsinks on the VRM's they seem to have dropped from ca 70*c to 50*c, and especially VRM2 seems to have a positive effect from the 40mm fan that is blowing over it and on to the custom heatsink.
I would never have dreamed that I could get these temps without a full custom loop so I'm thrilled at the moment.
Here is a picture of the thing installed in my case:
A fair warning though, for anyone who want to do this to their card. It is very heavy so you will need a backplate and you might even need to create a support bracket to hold your card up.
I just wanted to add my first 10 minute burn in test to show the temps:
quite impressive huh?
post #24 of 40 (permalink) Old 05-30-2014, 07:39 PM
Rep: 1 (Unique: 1)
yah nice temps
post #25 of 40 (permalink) Old 05-30-2014, 10:11 PM
0493mike's Avatar
Rep: 21 (Unique: 18)
Wow that is one nice bracket. Did it hurt your grades, I hope not. But it is very impressive, well done. You sure did a lot of work on it in a fairly short time. I know its fun but I'm too lazy to do it that fast. Really looks professional built.
cosmos s
0493mike is offline
post #26 of 40 (permalink) Old 05-31-2014, 07:08 AM - Thread Starter
What's a computer?
Don't think it did, but I won't know for sure until I get them June 20th. As for the speed I did it, I just have this thing where if I start something I like doing then I will devote all my time to it until it's finished. It also didn't hurt that I was missing my gaming GPU and had to run of the Intel HD4000 that is included in my 3570k tongue.gif
post #27 of 40 (permalink) Old 06-01-2014, 02:43 PM
*cough* Stock *cough*
Nukemaster's Avatar
Rep: 129 (Unique: 101)
So not know how I missed these new images, but it looks great.
Lots of little details.
Gaming
(15 items)
Media Center
(17 items)
2600K @ 4.4
Maximus IV Gene-z
Asus Dual 1070 OC with Artic Mono Plus
G.SKILL F3-1866C9D-16GXM Ripjaws X 16GB
M4 256
MX 300
Optical Drive
Liteon Slot load
Corsair 850HX
H80i
Silverstone FT03
Operating System
Windows 7 HP 64 bit
BenQ XL2420Z
Keyboard
Logitech G810 Orion
Mouse
Logitech G502
Audio
X-fi Titanium Fatality
i5 750
h55n usb3
msi gtx 650 ti
Corsair XMS3 CMX8GX3M2A1600C9
WDC Red 3tb
M4 128
WDC scorpio Blue 2.5
Optical Drive
Sony AD-7690H-01
FSP SFX 300 watt
Geminii S
SG05
Operating System
Windows 7 HP 64 bit
SyncMaster 245t
Keyboard
Logitech Wave
Mouse
Logitech G9
Audio
Sound Blaster Omni
Other
HD PVR
Nukemaster is offline
post #28 of 40 (permalink) Old 06-01-2014, 03:31 PM
INCREDIBLEHULK's Avatar
Rep: 113 (Unique: 85)
INCREDIBLEHULK is offline
post #29 of 40 (permalink) Old 06-01-2014, 04:22 PM
Not New to Overclock.net
Ramzinho's Avatar
Rep: 893 (Unique: 611)
i wonder what you used to cut that acrylic.. this looks so cool and the potential of toying with this and doing awesome looking brackets is really really awesome.. thanks for the idea.. and i think this might be a wonderful OCN sig mod through the time.
Oh yeah, I'm Back.
Hot Flame (WIP)
(8 items)
AMD R7 3700X
Gigabyte X570 Aorus Pro Wifi
AMD 5700 XT
Crucial P1
Seasonic Focus G
Phanteks Enthoo Evolv X
Operating System
Windows 10 Pro
Acer XR342CKP
Ramzinho is offline
post #30 of 40 (permalink) Old 06-01-2014, 04:41 PM - Thread Starter
What's a computer?
Originally Posted by INCREDIBLEHULK View Post
I'm not entirely sure if it was acrylic since it behaved very strangely, so for anyone doing this it would be better to get proper acrylic (maybe even colored transparent for a cool look). As for what I used to cut it was a hacksaw, holesaw, drill, a file and a dremmel (only found one for the last part and it really speed up things. The best way to get a perfect cut though is with a heated string (probably best with steel as it holds the heat well) as that makes an entirely clear cut.
If you want to do this then I do have a few pointers as to what materials to use and so on so just send me a PM if you want help.
