Barrow Fittings - Page 125 - Overclock.net - An Overclocking Community
Barrow Fittings
post #1241 of 1250 (permalink) Old 02-06-2019, 08:41 PM
VolatilXplosion
VolatilXplosion's Avatar
Quote: Originally Posted by broodro0ster View Post
Quote: Originally Posted by VolatilXplosion View Post
Oh ok, i was thinking about ordering this 4 pack https://www.amazon.com/Barrow-Female...degree+fitting
I have these and there are no issues with them 🙂
They are brass and not aluminium.
Ok cool thanks. At 28.99 for a 4 pack i am def gonna get a set of these i like the look of them also the fact that the rotary part is stiff seems like it has a tight seal which is a good sign i presume.
VolatilXplosion is offline
post #1242 of 1250 (permalink) Old 02-06-2019, 09:00 PM
Not New to Overclock.net
iSpark Level 1
iSpark's Avatar
Those fittings are $5.95 at Performance PCs, plus you also get a 5.5% discount if you use the OCN code, and it helps a small/ish retailer in the process. I think the discount code still works, can anyone confirm?
http://www.performance-pcs.com/barro...ing-black.html
iSpark is offline
post #1243 of 1250 (permalink) Old 02-07-2019, 06:27 AM
OneFunGenesis Level 1
OneFunGenesis's Avatar
and $5.99 at ModMyMods: https://modmymods.com/barrow-g1-4-90...wt90-v2-5.html
I will talk to them and see if there is a discount code for OCN
OneFunGenesis is offline
post #1244 of 1250 (permalink) Old 02-08-2019, 09:52 AM
OCN55 will get you 5.5% off at modmymods too. Just called an confirmed
post #1245 of 1250 (permalink) Old 02-08-2019, 01:03 PM
mumford Level 1
mumford's Avatar
Are there any differences in the chrome color and plating quality between Byski and Barrow fittings?
mumford is offline
post #1246 of 1250 (permalink) Old 02-08-2019, 01:07 PM
not that I know of. In fact, I would venture to say they are the same company (like Kia and Hyundai)
post #1247 of 1250 (permalink) Old 02-08-2019, 07:19 PM
mumford Level 1
mumford's Avatar
Thanks. The reason that I asked is because I find these little guys interesting and are only available from kia(Byski) and not Hyundai(Barrow). Just one fitting instead of a fitting plus an extension.
http://www.bykski.com/page158?_l=en&...t_category=225
I think I am just going to ali-express a mix order of Kia and Hyundai fittings and see.
mumford is offline
post #1248 of 1250 (permalink) Old 02-09-2019, 05:57 AM
jura11 is an unknown quantity at this point jura11 is an unknown quantity at this point
jura11's Avatar
Hi there
I have used on few builds Bykski fittings and they're OK, not seen any issues with them
Have used their pumps and pump tops and other parts like waterways etc and no issues
Hope this helps
Thanks, Jura
jura11 is offline
post #1249 of 1250 (permalink) Old 02-11-2019, 01:42 AM
SHNS0 Level 1
SHNS0's Avatar
No they're separate companies and actually go on hard competition within the Chinese market. They're always copying each other's good ideas
"Quality means doing it right when no one is looking." - Henry Ford
Main PC
(11 items)
i5 8600k
Asrock Z370 Fatal1ty ITX
EVGA GTX 980 Ti Kingpin
Corsair Dominator Platinum DDR4 16GB
Samsung 860 Evo 250GB
Samsung 960 Evo 250GB
Corsair SF600
Custom Watercooling
Phanteks Shift X
Operating System
Windows 10 Pro
Alienware AW3418DW 120hz 34" 3440x1440 IPS
SHNS0 is offline
post #1250 of 1250 (permalink) Old 02-11-2019, 06:38 AM
Ah interesting. The look identical to one another haha.
