Barrow Fittings - Page 3 - Overclock.net - An Overclocking Community
Barrow Fittings
post #21 of 1334 (permalink) Old 06-16-2014, 01:39 AM
Fahrenheit85's Avatar
Rep: 2 (Unique: 2)
Originally Posted by RX7-2nr View Post
Aliexpress
Reading the Aliexpress descriptions is tough lol. I think this the standard 2 o ring 12mm fitting http://www.aliexpress.com/item/Barrow-Black-G1-4-female-thread-straight-docking-seat-tube-Extend-7-5mm-computer-water-cooling/1846558316.html
Fahrenheit85 is offline
post #22 of 1334 (permalink) Old 06-16-2014, 01:44 AM
Unicr0nhunter's Avatar
Rep: 523 (Unique: 351)
Unicr0nhunter is offline
post #23 of 1334 (permalink) Old 06-16-2014, 01:53 AM
Jakusonfire is offline
post #24 of 1334 (permalink) Old 06-16-2014, 02:16 AM
Rep: 2 (Unique: 2)
Yeah saw on the Ebay store its for 14mm tubing. Might go that way since its cheap. Do they make 90 and 45 degree adapters for them?
post #25 of 1334 (permalink) Old 06-16-2014, 06:39 PM - Thread Starter
davidh93's Avatar
Rep: 13 (Unique: 13)
They definitely have adapters for them. You might have to look on aliexpress as the there is a bigger selection and sometimes it's cheaper than eBay. The seller I used was http://www.aliexpress.com/store/431286. It took about two weeks to get here which isn't too bad. My lutro0 customs order has taken over 3 weeks and still hasn't arrived. The only problem with the Barrow acrylic tubing is I don't know where to find a 14mm silicon insert to do the bending. If someone knows where I can get one that would be great
davidh93 is offline
post #26 of 1334 (permalink) Old 06-16-2014, 06:56 PM
defiler2k's Avatar
Rep: 45 (Unique: 39)
Do you know the ID of the tube? I use oring stock for mine
Depending on the ID of your tube you can perhaps this
http://www.mcmaster.com/#9679k31/=sfv591
Its the largest size in metric. For example for 1/2 inch primochil tubing I use the 9mm stock.
defiler2k is offline
post #27 of 1334 (permalink) Old 06-16-2014, 10:59 PM
Barrow's acrylic tube to go with their 14mm OD multilinks is 10mm ID X 14mm OD.
http://www.ebay.com/itm/Top-Quality-Water-Liquid-Cooling-Acrylic-Tube-15-3-4-Long-10mm-ID-X-14mm-OD-USA-/191116735481
Might could use the same 9mm Buna N O-ring cord defiler2k is using (I'm using that as well with 1/2" ID primochill tubing as suggested by IT Diva in the 'Acrylic pipebending 101' thread) but I suspect you might be better off using a 3/8" (9.5mm) silicone one. I'd suggest buying a 3' section of both to see which works best for you.
Or, that's a lot thicker-walled acrylic tube than usual. If you're going to be doing an entire loop with it where you would need a bending cord, not just links for GPUs, then you really might want to consider using more traditional acrylic tubing and fittings.
post #28 of 1334 (permalink) Old 06-17-2014, 09:13 AM - Thread Starter
davidh93's Avatar
Yea I was planning to do my entire loop, so I might use different tube and fittings then. I was going to get some monsoon hardlines since I already have the fittings. But every place I've looked is out of the conversion kits
davidh93 is offline
post #29 of 1334 (permalink) Old 06-17-2014, 11:31 AM
defiler2k's Avatar
You can use the tube, just try to get an insert that is 1mm smaller than your tube ID if your tube is 10mm ID then the insert that Unicr0nhunter has listed would be your best bet. The challenge with such thick walled tube is that if you need tight bends, it will be difficult to prevent damage to the wall. Do you have a mandrel for bending? .
post #30 of 1334 (permalink) Old 06-17-2014, 04:35 PM - Thread Starter
davidh93's Avatar
I don't have a mandrel, but I was planning on getting the 5/8 inch monsoon kit because 14mm is just slightly smaller. If that doesn't work I guess I could make my own mandrel
davidh93 is offline
