[Build Log] "There Will Be Blood" - my actual first attempt at watercooling.. - Page 2 - Overclock.net - An Overclocking Community
post #11 of 29 (permalink) Old 09-15-2014, 09:06 PM
Sgt. Wolf S. Bora
Wolfsbora's Avatar
Rep: 139 (Unique: 102)
Originally Posted by Blackops_2 View Post
Freaking love this case. Got some more done today. Waiting on thermal pads to put the GPU block on and start leak testing. Will have to order the phanteks pump mount or drill some holes to keep the pump back there. Warning: Spoiler! (Click to show)
First of all, subbed! Second, after seeing the pic of that case all wide open I am falling deeply in love with it too... Keep up the great work, man!! I'lll be following.
Wolfsbora is offline
post #12 of 29 (permalink) Old 09-15-2014, 10:00 PM - Thread Starter
Optics Fiend
Blackops_2's Avatar
Rep: 81 (Unique: 66)
The case is epic. I mean for 99$ it's impossible to beat. The Luxe is basically it's all metal brother for 150$. It is just well thought out, the fact that you can pretty much take the entire chassis apart with screws instead of rivets is brilliant.
I'm running into routing problems as of now, heat sinks getting in the way certain angles not necessarily lining up..etc. Though i might just end up bending some tubing. Was trying to go with a lot of straight runs.
Green Envy
(12 items)
Purple Haze
(12 items)
i7-3770k @ 4.5ghz
Gigabyte G1.Sniper 3
EVGA 780 Classified
EVGA 780 Classified
16GB GSkill Ripjaws DDR3 2133
WD Raptor
Seasonic 850w M12II
Cooler Master Glacer 240L
Phantek Enthoo Pro
Operating System
Windows 7 64-Bit Home premium
Asus VG248QE
Keyboard
Logitech G15
Ryzen R5 1600x
Fatal1ty AB350 Gaming-ITX
Diamond 7970
G Skill DDR4 3200
Western Digital Black
Samsung 850 Evo
Corsair SF600
Black Ice Nemesis L-Series 240 Stealth
EK-FC7970 CSQ
Mayhems X1 UV Purple
Fractal Design Define S Nano
Blackops_2 is offline
post #13 of 29 (permalink) Old 09-16-2014, 05:59 AM - Thread Starter
Optics Fiend
Blackops_2's Avatar
Well had to reconfigure. And am going to need more angle fittings. This is one reason that i like acrylic yes harder than regular tubing but there isn't much bending can't accomplish and that bending doesn't put strain on the parts.
Some dimensions i didn't account for but i'm basically just not going to have as many straight runs as i wanted. We're going to have some waves lol.
Pics of the changes made.
Making modifications to the drain valve as well. Putting together more angle fittings to order.
Green Envy
(12 items)
Purple Haze
(12 items)
i7-3770k @ 4.5ghz
EVGA 780 Classified
EVGA 780 Classified
WD Raptor
Seasonic 850w M12II
Phantek Enthoo Pro
Operating System
Asus VG248QE
Keyboard
Logitech G15
Ryzen R5 1600x
Diamond 7970
G Skill DDR4 3200
Samsung 850 Evo
Corsair SF600
EK-FC7970 CSQ
post #14 of 29 (permalink) Old 09-16-2014, 09:31 AM - Thread Starter
Optics Fiend
Blackops_2's Avatar
Jerry rigged HDD...check lol
Green Envy
(12 items)
Purple Haze
(12 items)
i7-3770k @ 4.5ghz
EVGA 780 Classified
EVGA 780 Classified
WD Raptor
Seasonic 850w M12II
Phantek Enthoo Pro
Operating System
Asus VG248QE
Keyboard
Logitech G15
Ryzen R5 1600x
Diamond 7970
G Skill DDR4 3200
Samsung 850 Evo
Corsair SF600
EK-FC7970 CSQ
post #15 of 29 (permalink) Old 10-25-2014, 03:24 PM - Thread Starter
Optics Fiend
Blackops_2's Avatar
Well i just brought home my 780 classy i got from dragon sine i'm waiting on thermal pads for the 7970 yet again. Figured i'll keep it in there. Got it tubed up started leak testing then realized that i had the pump inlet and outlet backwards. So that required disassembly. Then got it back together sort of in a hurry. Hell i've not been taking my time which i know i should be but haven't slept in 26 hours and just want to get it going.
Got it running and had leaks in three different places i've sorted two of them out. The Bitspower mounting clamps suck dick as the reservoir slides down in it, less i'm just not strong enough to clamp it to the level it needs to be at. The reservoir was putting pressure on the fittings leading to the pump and some of the fittings were leaking. That and the bottom lid of the reservoir seemed to be leaking, due to the same because the mounts aren't holding the damn thing.
The top fitting going from the CPU block back to the reservoir is leaking, which i'm going to check the tubing on it to be 100% sure it's the fitting and not my tubing job.
Overall i would say it's a little bit of a rough start but a learning experience. Tubing was more curvy than i had wished.
Green Envy
(12 items)
Purple Haze
(12 items)
i7-3770k @ 4.5ghz
EVGA 780 Classified
EVGA 780 Classified
WD Raptor
Seasonic 850w M12II
Phantek Enthoo Pro
Operating System
Asus VG248QE
Keyboard
Logitech G15
Ryzen R5 1600x
Diamond 7970
G Skill DDR4 3200
Samsung 850 Evo
Corsair SF600
EK-FC7970 CSQ
post #16 of 29 (permalink) Old 10-26-2014, 05:40 AM - Thread Starter
Optics Fiend
Blackops_2's Avatar
I put a rubberband around the res and used it as a rubber insert to stop it from sliding. Changed the fitting out this morning too no leaks so far going to keep watching it. I cut some of the tubing that was going from the CPU to res. The Tubing was too long putting stress on the fitting... my fault. Got some bubbles in the loop but that's expected. I'll bleed it properly once i've gone 24 hours without leaks, i guess. The splatter is probably from the way i filled it.
10612596_10203038996157585_7332949254625198675_n.jpg?oh=bcd7952b6f8515105dc942464bf13254&oe=54DF4D56
Though i've felt somewhat pushed because i have all this WC stuff and am wanting to get back into shooting competition i must say i love the way it looks. I might go regular tubing on my main rig come December or january. Splitting up the 780s and putting one in my backup keeps me from having to mod my 800D so heavily also.
Was up 30hrs from 3pm friday till 9pm yesterday. Wore myself out working on that thing, but it seems to be going lol. A little nervous about shaking it to bleed it if it does pass leak testing.
Green Envy
(12 items)
Purple Haze
(12 items)
i7-3770k @ 4.5ghz
EVGA 780 Classified
EVGA 780 Classified
WD Raptor
Seasonic 850w M12II
Phantek Enthoo Pro
Operating System
Asus VG248QE
Keyboard
Logitech G15
Ryzen R5 1600x
Diamond 7970
G Skill DDR4 3200
Samsung 850 Evo
Corsair SF600
EK-FC7970 CSQ
post #17 of 29 (permalink) Old 10-27-2014, 05:21 AM - Thread Starter
Optics Fiend
Blackops_2's Avatar
24 hours passsed, time to wire it up!
Green Envy
(12 items)
Purple Haze
(12 items)
i7-3770k @ 4.5ghz
EVGA 780 Classified
EVGA 780 Classified
WD Raptor
Seasonic 850w M12II
Phantek Enthoo Pro
Operating System
Asus VG248QE
Keyboard
Logitech G15
Ryzen R5 1600x
Diamond 7970
G Skill DDR4 3200
Samsung 850 Evo
Corsair SF600
EK-FC7970 CSQ
post #18 of 29 (permalink) Old 10-27-2014, 07:07 AM
Sgt. Wolf S. Bora
Wolfsbora's Avatar
Looking good, man! Good luck!
post #19 of 29 (permalink) Old 10-27-2014, 08:08 AM - Thread Starter
Optics Fiend
Blackops_2's Avatar
Right when i cut it off this morning i had a leak on one of the stop caps at the bottom of the res. Tightened it and while wiring it up kept the looping going with the other psu turning it on and off for a couple of hours. No leaks, it wouldn't harm anything if it does leak since it will hit the pump top but going to watch it closely all night and probably jump the PSU off again and run it all night.
I don't think i realized that i would want an cathode. Lol With the tinted window of the Enthoo you can't see crap. I just have the side panel off at the moment. HDD is louder than the system lol
Green Envy
(12 items)
Purple Haze
(12 items)
i7-3770k @ 4.5ghz
EVGA 780 Classified
EVGA 780 Classified
WD Raptor
Seasonic 850w M12II
Phantek Enthoo Pro
Operating System
Asus VG248QE
Keyboard
Logitech G15
Ryzen R5 1600x
Diamond 7970
G Skill DDR4 3200
Samsung 850 Evo
Corsair SF600
EK-FC7970 CSQ
post #20 of 29 (permalink) Old 10-27-2014, 09:37 AM - Thread Starter
Optics Fiend
Blackops_2's Avatar
Green Envy
(12 items)
Purple Haze
(12 items)
i7-3770k @ 4.5ghz
EVGA 780 Classified
EVGA 780 Classified
WD Raptor
Seasonic 850w M12II
Phantek Enthoo Pro
Operating System
Asus VG248QE
Keyboard
Logitech G15
Ryzen R5 1600x
Diamond 7970
G Skill DDR4 3200
Samsung 850 Evo
Corsair SF600
EK-FC7970 CSQ
