Summer water block round-up 2014 - Overclock.net - An Overclocking Community
post #1 of 121 (permalink) Old 08-02-2014, 02:16 PM - Thread Starter
Moonmanovich's Avatar
Rep: 41 (Unique: 37)
Moonmanovich is offline
post #2 of 121 (permalink) Old 08-02-2014, 02:16 PM - Thread Starter
post #3 of 121 (permalink) Old 08-02-2014, 04:37 PM
VSG
Call me VSG
VSG's Avatar
Rep: 795 (Unique: 445)
Thanks for the tests, good info. +1
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><b>Reviews</b><span>: </span><a href="https://www.overclock.net/t/1638379/ocn-labs-acer-xr382cqk-bmijqphuzx-38-freesync-monitor/0_50">Acer XR382CQK Monitor</a><span> | </span><a href="https://www.overclock.net/t/1632881/ocn-labs-netgear-nighthawk-s8000-gaming-streaming-switch/0_50">Neatgear Nighthawk S8000 Switch</a><span> | </span><a href="https://www.overclock.net/t/1509787/my-review-of-the-ek-supremacy-evo">EK Supremacy Evo</a><span> | </span><a href="https://www.overclock.net/t/1510189/my-review-of-the-corsair-graphite-380t/0_50">Corsair Graphite 380T</a><span> | </span><a href="https://www.overclock.net/t/1516369/my-review-of-the-swiftech-mcp50x-pump/0_50">Swiftech MCP50X</a><span> </span><a href="https://www.overclock.net/t/1520512/the-quad-rad-roundup/0_50">Quad Rad Roundup</a><span> | </span><a href="https://www.overclock.net/t/1526779/user-review-of-the-swiftech-h220-x/0_50">Swiftech H220-X</a><span> | </span><a href="https://www.overclock.net/t/1530984/user-review-of-the-phanteks-ph-tc14pe/0_50">Phanteks PH-TC14PE<br></a><span> </span><a href="https://www.overclock.net/t/1551158/sponsored-review-of-the-ek-fc-asus-x99-rve-monoblock/0_50">EK Asus x99 R5E Monoblock</a><span> | </span><a href="https://www.overclock.net/products/tesoro-gram-spectrum/reviews/7424">Tesoro Gram Spectrum Keyboard</a><span> | </span><a href="https://www.overclock.net/products/cherry-mx-6-0-keyboard/reviews/7436">Cherry MX 6.0 Keyboard</a><span> |</span><a href="https://www.overclock.net/t/1604461/user-review-of-the-gigabyte-x99-phoenix-sli-motherboard/0_50">Gigabyte x99-Phoenix SLI motherboard</a><span> | </span><a href="https://www.overclock.net/t/1613371/sponsored-corsair-k70-rgb-rapidfire-keyboard-review/0_50">Corsair K70 RGB RAPIDFIRE Keyboard</a><span> | </span><a href="https://www.overclock.net/t/1531984/user-review-of-the-hwlabs-black-ice-sr2/0_50">Black Ice SR2 360</a><br></div></div></div>
VSG is offline
post #4 of 121 (permalink) Old 08-03-2014, 12:11 AM
hiarc's Avatar
Rep: 54 (Unique: 47)
Did you test the 380i in a 90 degree orientation? That usually nets another 1-2c in cooling.
hiarc is offline
post #5 of 121 (permalink) Old 08-03-2014, 12:47 AM - Thread Starter
post #6 of 121 (permalink) Old 08-03-2014, 03:09 PM - Thread Starter
post #7 of 121 (permalink) Old 08-03-2014, 04:00 PM
Retired Staff
derickwm's Avatar
Rep: 379 (Unique: 291)
derickwm is offline
post #8 of 121 (permalink) Old 08-04-2014, 10:48 AM
stren's Avatar
Rep: 258 (Unique: 208)
Originally Posted by Moonmanovich View Post
-Each water block is tested in the optimal mounting position (either as designed or rotated 90° CCW). You can find detailed orientation piece on XS Forums.
-Results for Phobya UC-2 LT are way better than in my first roundup (on XS). First water block was defective, had a little bow in it's base so I ordered a new one.
-Haswell results for Koolance CPU-380I are worse than in my first roundup. I retested it 8 times and results were confirmed. I believe that this (new) 4770K has a different IHS, more concave. Will try to borrow another 4770K from a friend or just buy a 4790K and try my luck, need gems biggrin.gif
-The best jet for EK Supremacy are J2 (1mm) for Haswell and J1 (0,8mm) for Ivy Bridge-E.
I'll have to try the jetplate 2 - my 4770K showed rotated CPU-380 clearly better than the supremacy (I only tried the last JP). But I am about to do a retest so it's good timing to try that.
Trouble-Maker
I write water cooling and case reviews but you'll have to use google because I can't link them here thumb.gif
stren is offline
post #9 of 121 (permalink) Old 08-04-2014, 11:02 AM
VSG
Call me VSG
VSG's Avatar
Speaking of rotated orientation, you guys really need to take pictures of what you mean. I opened up the 380i and checked the jetplate orientation and this seemed most logical to me based on that and the 4770k die orientation:
Excuse that ridiculous angle but you get the point.
VSG is offline
post #10 of 121 (permalink) Old 08-04-2014, 11:38 AM
stren's Avatar
Yeah that's what I call "rotated" and that worked best for me on z87 and x79.
Trouble-Maker
stren is offline
