How to correctly leak test your loop......101? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 445 (permalink) Old 01-06-2015, 03:12 AM
Linux Lobbyist
BadDad62's Avatar
Rep: 80 (Unique: 66)
AWESOME work 'B NEGATIVE'
+ Rep +
BadDad62 is offline
post #12 of 445 (permalink) Old 01-06-2015, 06:24 AM
nosequeponer's Avatar
Rep: 1 (Unique: 1)
qick question about it,
this system shows if you have or don´t have a leak, but to actually find it, how do you do it?? go and look for air losses in the fittings one by one??
nosequeponer is offline
post #13 of 445 (permalink) Old 01-06-2015, 06:31 AM
VSG
Call me VSG
VSG's Avatar
Rep: 795 (Unique: 445)
As pointed out, use liquid soap. There are specific products made for this, like Snoop, which aerate and foam up easily at points of gas leak.
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><b>Reviews</b><span>: </span><a href="https://www.overclock.net/t/1638379/ocn-labs-acer-xr382cqk-bmijqphuzx-38-freesync-monitor/0_50">Acer XR382CQK Monitor</a><span> | </span><a href="https://www.overclock.net/t/1632881/ocn-labs-netgear-nighthawk-s8000-gaming-streaming-switch/0_50">Neatgear Nighthawk S8000 Switch</a><span> | </span><a href="https://www.overclock.net/t/1509787/my-review-of-the-ek-supremacy-evo">EK Supremacy Evo</a><span> | </span><a href="https://www.overclock.net/t/1510189/my-review-of-the-corsair-graphite-380t/0_50">Corsair Graphite 380T</a><span> | </span><a href="https://www.overclock.net/t/1516369/my-review-of-the-swiftech-mcp50x-pump/0_50">Swiftech MCP50X</a><span> </span><a href="https://www.overclock.net/t/1520512/the-quad-rad-roundup/0_50">Quad Rad Roundup</a><span> | </span><a href="https://www.overclock.net/t/1526779/user-review-of-the-swiftech-h220-x/0_50">Swiftech H220-X</a><span> | </span><a href="https://www.overclock.net/t/1530984/user-review-of-the-phanteks-ph-tc14pe/0_50">Phanteks PH-TC14PE<br></a><span> </span><a href="https://www.overclock.net/t/1551158/sponsored-review-of-the-ek-fc-asus-x99-rve-monoblock/0_50">EK Asus x99 R5E Monoblock</a><span> | </span><a href="https://www.overclock.net/products/tesoro-gram-spectrum/reviews/7424">Tesoro Gram Spectrum Keyboard</a><span> | </span><a href="https://www.overclock.net/products/cherry-mx-6-0-keyboard/reviews/7436">Cherry MX 6.0 Keyboard</a><span> |</span><a href="https://www.overclock.net/t/1604461/user-review-of-the-gigabyte-x99-phoenix-sli-motherboard/0_50">Gigabyte x99-Phoenix SLI motherboard</a><span> | </span><a href="https://www.overclock.net/t/1613371/sponsored-corsair-k70-rgb-rapidfire-keyboard-review/0_50">Corsair K70 RGB RAPIDFIRE Keyboard</a><span> | </span><a href="https://www.overclock.net/t/1531984/user-review-of-the-hwlabs-black-ice-sr2/0_50">Black Ice SR2 360</a><br></div></div></div>
VSG is offline
post #14 of 445 (permalink) Old 01-06-2015, 08:14 AM
Mayhem's Avatar
Rep: 277 (Unique: 197)
same method we use to test the rads out.
Mayhem is offline
post #15 of 445 (permalink) Old 01-06-2015, 09:26 AM
Cavey00's Avatar
Rep: 63 (Unique: 53)
Originally Posted by Unicr0nhunter View Post
Or you could do this:
$10.36 - Gas Test Gauge (gauge + Schrader valve): http://www.homedepot.com/p/DANCO-0-15-psi-1-10-Increment-Gas-Test-Gauge-94352/100180536
$0.98 - Adapter for above to 1/2" ID tube: http://www.homedepot.com/p/Watts-3-4-in-x-1-2-in-Plastic-Barb-x-MPT-Adapter-A589/202257613
$0.79 per ft - 1/2" ID 3/4" OD tube: http://www.sidewindercomputers.com/dupvctu1idx3.html
$1.99 - G1/4in. to 1/2in. ID Hose Barb Fitting: http://www.sidewindercomputers.com/xsg1to1bafic.html
$0.41 x 2 : Stainless Steel hose clamps for 5/8" OD tube: http://www.sidewindercomputers.com/hoclbrmi379i.html
$14.94 with a 1' tube from barb fitting to gauge assy.*
* plus shipping of course.
Also, if/when comparing you might want to be careful with McMaster Carr's shipping. I've ordered from them several times myself and shipping was fast but not cheap and I didn't get a choice of shipping options or cost beforehand.
Late edit:
And if you need one:
$5.99 : bicycle pump incl free shipping: http://www.ebay.com/itm/381058545966
Man, they are getting you for over $10 for that gauge at your HomeDepot? Mine was $7 locally, and in stock. Plus I work in an auto dealership and had all the brass fittings laying around to uh, "borrow". Couldn't beat spending less than $10 on the whole setup, using some stuff I had at home as well from a previous WC setup.
Oh btw don't get over excited when you seal up all the leaks and forget to take your air test setup off your rig before filling it with coolant. I don't know if water will ruin an air pressure gauge or not, but I filled mine. It still seems to work but I guess time will tell.
Cavey00 is offline
post #16 of 445 (permalink) Old 01-06-2015, 09:55 AM - Thread Starter
Hardware Rep
B NEGATIVE's Avatar
Rep: 789 (Unique: 492)
Its an industry standard method...from HVAC to domestic plumbing.
AquaC test their blocks like this also.
B NEGATIVE is offline
post #17 of 445 (permalink) Old 01-06-2015, 12:34 PM
Unicr0nhunter's Avatar
Rep: 523 (Unique: 351)
First thing I do is just go through the loop and recheck tightness of all the fittings and look for any uneven o-ring stickout. Sometimes an o-ring will not tighten up evenly around a fitting and cause a leak and when that happens you can often see that bit of the o-ring trying to squish out one side of a fitting. A tiny dab of silicone o-ring grease on every o-ring prior to installation will usually prevent that and help seal & protect o-rings.
If I didn't see anything that way then at around 10 psi you can often hear the faint hiss of all but the slowest of leaks in a quiet room. I've used a piece of tubing holding one end to my ear and the other to each potential source of a leak and found one that way. In my case it was actually a leak between the gauge and the NPT to BSPP adapter I was using, so wasn't even part of my loop where my leak was. lol. I just had to reapply some teflon tape and tighten it down more.
And lastly, as VSG mentions, if none of that found the source of a leakdown then I guess I'd pump it up to 10 psi again and start going around each fitting with a q-tip dipped in a gas leak detection soap. It's not ever come to that yet for me, but I did grab a bottle of this stuff off of Amazon ...
mega bubble leak detector
Unicr0nhunter is offline
post #18 of 445 (permalink) Old 01-06-2015, 01:21 PM
lol. In addition to my job I have a small farm. I don't live anywhere near a town or city. I'm lucky I have a Home Depot near me on my way to work. It's pretty much the only thing out here besides a tiny grocery store, if you could call it that, and a gas station and just about everything else is almost an hours drive away. Nearest restaurant, even fast food, nearest movies, nearest mall, heck, nearest MalWart, all more than a 45 min drive, and computer components or anything like that I have to have shipped as it's a 2.5 hr drive to even just the closest Best Buy. Where I live two day shipping takes 4 days and your smart phone is useless for anything but a call or a text, and even then your lucky to get one bar signal if you go stand outside. The fact I can get that shipped for free for $10 to the Home Depot I drive right by several times a week is awesome especially compared to what Amazon or McMaster Carr or anywhere else I could find online was wanting for a similar combo shipped to me.
edit: and sorry for the double post.
post #19 of 445 (permalink) Old 01-06-2015, 02:39 PM
hobojodude's Avatar
Rep: 2 (Unique: 2)
Makes sense. The reason im a big fan of Mcmastercarr is because their warehouse center is relatively close to my residence and will call is a breeze. I agree that their shipping charges can be finicky at times, but they are fast.
Edit:
I just picked up my parts
hobojodude is offline
post #20 of 445 (permalink) Old 01-07-2015, 04:33 PM
easynator's Avatar
Rep: 24 (Unique: 22)
easynator is offline
