How to correctly leak test your loop......101? - Page 44 - Overclock.net - An Overclocking Community
post #431 of 437 (permalink) Old 05-28-2018, 08:07 AM
KnyghtFall's Avatar
Rep: 0
Quote: Originally Posted by xxpenguinxx View Post
Thanks so much!
KnyghtFall is offline
post #432 of 437 (permalink) Old 10-13-2018, 06:11 PM
Rep: 0
This is fricken awesome!
Thank you!!
For the folks having trouble finding parts:
NPT: National Pipe Taper
NPT threads are also sometimes referred to as
MIP (Male Iron Pipe)
FIP (Female Iron Pipe)
IPT (Iron Pipe Thread)
FPT (Female Pipe Thread)
MPT (Male Pipe Thread)
BSPP = G
source: http://pipeandhose.com/
Get a 15 PSI - 20 PSI gauge. $~7USD
1/4" Tee fitting ~ 7 USD
1/4" shrader valve
you can get all these at home depot, lowes or amazon
encore2097 is offline
post #433 of 437 (permalink) Old 10-13-2018, 06:24 PM
In lurking mode
iamjanco's Avatar
Rep: 80 (Unique: 52)
Glad you like it It's definitely a handy thread.
iamjanco is online now
post #434 of 437 (permalink) Old 01-20-2019, 01:41 AM
Rep: 0
update to this -- rather than pumping air in -- I'm sucking air out with a vacuum. Like how some performance cars require the radiator to be filled under vacuum to minimize air in the loop - I'm doing the same thing.
And if a loop can't hold vacuum, then you know there's a leak! You can use a venturi vacuum + air compressor or vacuum pump!
post #435 of 437 (permalink) Old 01-21-2019, 03:20 AM
Goooober's Avatar
Rep: 0
Hi,
I was wondering if any UK people have done this and could link me to the items they purchased? I've never done a custom loop before so i'm pretty nervous about leak testing and this seems like nice safe way to do it but i'm not sure what things i actually need besides the pressure gauge itself (fittings, adapters and whatnot). I'll be doing a soft tube build with compression fittings should that matter at all.
Thanks
Goooober is offline
post #436 of 437 (permalink) Old 01-23-2019, 11:04 AM
Goooober's Avatar
Rep: 0
Goooober is offline
post #437 of 437 (permalink) Old 03-07-2019, 01:36 PM
Abaidor's Avatar
Rep: 2 (Unique: 2)
I had a gauge so Ι got a Tee Fitting only. For a valve I cut one out from a bikes inner tube and used epoxy to glue it on one of the Tee Fitting's sides.
Works like a charm...
X299 - i9 7940X
(24 items)
i9-7940X
Asus Rampage VI Extreme
Asus Strix GTX 1080Ti OC
64GB Trident Z RGB
Samsung M.2 960Pro 512GB
WD Gold 10TB
WD Red 4TB
WD RED 4TB
WD Green 2TB
WD Green 2TB
WD Green 2TB
Corsair AX1500i
MO-RA 420 Pro
EK RVIE Monoblock
Phanteks Asus Strix 1080Ti GPU Block
EK-XTOP Revo Dual D5 PWM
Bitspower Fittings
Heatkiller 200mm Reservoir
9X Corsair ML140 Pro Fans
Coolermaster Cosmos 2
Operating System
Windows 10 Pro
BenQ SW320 32" 4K
Mouse
Logitech MX Master 2S
Mouse
Abaidor is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
annul
