My air-cooled (and overclocked) Aorus RX 580 4GB is very noisy when gaming, so I have ordered NexXxoS GPX AMD RX 580 M04 :-)
I know this hybrid block is very restrictive so I am wondering how to install the GPX for best (near silent) operation.
Currently my loop consist of these components:
Danger Den MC-TDX (cooling my I5 2500K -
[email protected])
Black Ice Pro III 360mm RAD (with 6xArctic F12 PWM fans)
XSPC LAING D5 RESERVOIR TOP V3 (including ALPHACOOL VPP655
[email protected] RPM)
2x10mm ID 90º Push-In fittings
4x10mm ID straight Push-In fittings
About 1.5meters (or 5 feet) 10,3mm OD/7,5mm ID soft tube
The old radiator manages to cool my cpu passive at low loads, when priming my CPU core temperatures peak @ 62ºC.
I really don't want to increase my pumps RPM, because its practically silent @2650rpm.
So should I install the GPX parallel with my CPU block, to limit the restriction?
Or maybe remove the jet plate insert even though it will increase my GPU temp about 10ºC?
Or will my D5 pump handle CPU and GPU blocks in serial, maybe if I replace the 2x90º fittings with 2x45º fittings?
If I go for serial and remove the insert should I place the GPX before the MC-TDX CPU block?
I know I could test all the above options and stick with what works best, but draining my loop several times is time consuming, so I hope someone with more knowledge than me would be able to advise me.
