My first water cooling build - i7-5820k Corsair 350D - Overclock.net - An Overclocking Community
post #1 of 23 (permalink) Old 10-11-2015, 03:27 AM - Thread Starter
Ronski's Avatar
Rep: 1
I'm in the process of building my first proper water cooled PC and I'm using a Corsair 350D case.
These are the parts I have so far.
  • Corsair 350D
  • ASRock Fatal1ty X99M Killer 3.1
  • Intel i7-5820k
  • Swiftech MCP655 Laing D5 Vario
  • 2 x Phanteks PH-F140SP
  • Various fittings for 13mm Acrylic pipe
  • Coolermaster V850 PSU
I actually purchased the pump back in July 2009 but never got around to installing proper water cooling (still running a Corsair H50), so hopefully it's still OK.
To be honest the system won't be pushed hard, it occasionally transcode's videos and I occasionally game, I could get by with a lot lower spec PC but that wouldn't be fun would it? My current PC has served me very well for the past five years, and I expect this one to serve me well for just as long, with the odd improvements along the way.
I have a pair of GTX680's which will be transferred into this build, but they won't be water cooled, my main purpose of water cooling is to cool the CPU quietly whilst over clocking it, hopefully to around 4.5GHz
For the CPU block I'm considering a EK Supremacy EVO Clean CSQ, would this be a good choice?
The radiator needs to be a 280mm version with a maximum thickness of 30mm to fit in the top of the case. I've seen recommended the Alphacool NexXxoS ST30 Full Copper 280mm, but there's also rads by Black Ice Hardware Labs which are well recommended, amongst others. So what would be a good choice, I want something that will last and cool the CPU well and quietly?
For the reservoir I'm thinking of using a PrimoChill 240mm AGB CTR Phase II with Laing D5 mount.
So what's peoples opinions/thoughts on the CPU block, rad and res?
Edit:
Additional parts purchased since this post.
  • 32GB Kingston HyperX DDR4 2666
  • Hardware Labs Black Ice Nemesis Radiator GTS 280 U flow
  • PrimoChill 240mm AGB CTR Phase II with Laing D5 mount.
  • EK Supremacy EVO Clean CSQ
Ronski is offline
post #2 of 23 (permalink) Old 10-11-2015, 03:55 AM
ghabhaducha's Avatar
Rep: 44
Great choice on parts...yet another fellow X99 matx user smile.gif I love my ASRock X99M Extreme4, so I don't doubt that you will have a great time with your Fatal1ty X99M Killer 3.1. Regarding radiators, I've had great experience with Alphacool radiators, so I would recommend those from personal experience. I've used an older HWLabs Black Ice 120mm radiator, and it was just fine too. Either way, I would make sure that I clean out the radiators before use.
Also any reason you don't want to get some GTX 680 blocks? I'm sure you can find them second hand for fairly cheap. With an additional 240mm radiator in the front, and possibly a 120mm radiator in the back, you can get enough surface area to cool that 5820k + 2x GTX 680s.
I'm able to cool a i7-5960x @4.5 1.264V + 2x 290x @1075/1375 with a 200mm radiator (45mm thick) + alphacool 120mm radiator (60mm thick) in sig rig. (CPU temps are 65-70C @4.5 and GPU temps are 55-60C with heavy gaming. Ambient was 28C).
edit~ Sorry, I forgot to mention two things. The CPU block is a great choice. I've used an older EK Supremacy, and it was a great block. I've only heard good things about the EVO. Additionally, I would check out the following barrow fittings for your tubing; they are pretty much the same quality as Bitspower fittings, but wayyy cheaper.
The Q6600 Club
4GHz Overclock Club
OCN Headphones Club
CrossOver 27Q LED/LED-P & 27M LED Monitor Club
X58 Xeon Club
[Official] AMD R9 290X Owners Club
SilverStone TJ08-E Case Owners Club
Kid Dynomite
(43 items)
Black Dynamite
(39 items)
Intel Core i7-5960x J513B135 @4.5GHz (1.264V)
ASRock Fatal1ty X99M Killer/3.1
Nvidia GTX 1080 FE
Nvidia GTX 1080 FE
Corsair Vengeance LPX 64GB (4x16GB) DDR4 DRAM 2666MHz
Samsung 950 PRO M.2 512GB (MZ-V5P512BW)
Samsung 850 Pro 1TB x2 RAID0
WD Caviar Purple 6TB x2
Seagate 2TB ST32000542AS
Seagate ST4000LM016 4TB 2.5" x2 (FP58)
Crucial M500 960GB x2 (MacOS + Ubuntu)
Optical Drive
Sony BD-5850H w/Silverstone FP58
Cooler Master V1000
PrimoChill PrimoFlex Advanced LRT Tubing 1/2"ID x 3/4"OD - Onyx Black
Silverstone AP181 180mm Fan
Scythe GentleTyphoon D1225C12B5AP-15
2x Swiftech MCP35X
Koolance 380i
2x EK-FC1080 GTX Nickel+Acetal
Phobya Xtreme 200mm Radiator Rev 2
Alphacool NexXxoS UT60 Full Copper 120mm
8x Barrow 1/2"ID x 3/4"OD Compression Fittings
2x Barrow 3/8"ID x 1/2"OD Compression Fittings
3x Barrow 40mm g1/4 Extenders
1x Barrow 30mm g1/4 Extender
1x Barrow 20mm g1/4 Extender
5x Barrow 90-degree g1/4 Single Rotary
Koolance RP-401X2 Rev 1.1
PrimoChill PrimoFlex Advanced LRT Tubing 3/8"ID x 1/2"OD - Bloodshed Red
Silverstone TJ08B-E
Operating System
Windows 10 Pro x64 Build 1709
2x Crossover 324K w/Workrite Monitor Mounts
TCL P605 55" 4K
Keyboard
Corsair K95
Mouse
Razer Deathadder 2013
Mouse
Corsair Gaming MM300
Audio
Grace Design m9xx DAC/Amplifier
Audio
Audeze LCD-X
Audio
Fostex TH-X00 Ebony
Audio
Sennheiser HD 6XX Massdrop Limited Edition
Audio
Fostex T-X0
Audio
Klipsch R-15PM + Klipsch R-112SW
Other
Intel Dual Band Wireless-AC 7260
Core i7-4790k @4.8GHz (1.291V) De-Lidded
Gigabyte GA-Z87X-OC Force
AMD R9 290x 1075/1375
Crucial Ballistix Tactical 32GB @1600MHz 8-8-8 (1.5V)
Samsung 840 Pro 512GB
Samsung M8 1TB 2.5" x4
Samsung F4EG 2TB x3
Seagate SV35 2TB x2
Seagate Barracuda LP 2TB x2
WD Caviar Green 2TB x1
Optical Drive
Seasonic X-1250XM2
Koolance 380i
2x Swiftech MCP655B D5 Pumps
XSPC M20 to G1/4" Fillport
1x Bitspower 90-degree Single Rotary
1x Bitspower 20mm g1/4 extender
2x Bitspower 10mm g1/4 extenders
2x Bitspower D-Plug Sets (BP-MBWP-C07)
2x Bitspower 3/8"ID x 1/2"OD Compression Fittings
1x Bitspower 1/2"ID x 3/4"OD Single Rotary Compression Fittings
4x Bitspower 1/2"ID x 3/4"OD 45-degree Dual Rotary Compression Fittings
3x Bitspower 1/2"ID x 3/4"OD 90-degree Triple Rotary Compression Fittings
1x Bitspower 45-degree Single Rotary
Koolance VID-AR290X Rev 1.0
EK-FB GA Z87X-OC Force
PrimoChill PrimoFlex Advanced LRT Tubing 3/8"ID x 1/2"OD - Clear
Magicool Extreme Triple 180mm x 35mm Slim Radiator
Koolance RP-452X2 Rev2.0
Silverstone FT02 (Modified)
Operating System
Windows 7 Professional x64
Dell Ultrasharp 2408WFP
Keyboard
Corsair K90
Mouse
Razer Naga 2012
Mouse
Sony Playstation 3 Mouse Pad
Audio
ASUS Xonar Essence STX
Audio
Logitech Z-5500 Digital
Other
IBM M1115 (LSI 9211-8i IT mode)
ghabhaducha is offline
post #3 of 23 (permalink) Old 10-11-2015, 04:22 AM - Thread Starter
Ronski's Avatar
Rep: 1
Thanks for the feed back, I currently have an Antec P180 case and wanted something smaller with water cooling ability.
Due to the wife and kids I wear 5.1 headphones when I game, so any noise from the GPU's doesn't worry me, and during normal use they are pretty much silent.
I may also upgrade the cards soon whilst they still have a reasonable resale value, so may go for a couple of GTX 970 Strix or even a 980 Strix. The Strix is also a very quiet card, so I think water cooling the GPU's as well isn't necessary for my needs.
Thanks for the pointers on the fittings, I purchased these fittings off ebay recently but no doubt might need some more.
www.ebay.co.uk/itm/131613942918
www.ebay.co.uk/itm/141786371045
Ronski is offline
post #4 of 23 (permalink) Old 11-16-2015, 11:59 AM - Thread Starter
Ronski's Avatar
Rep: 1
I'm very disappointed with the Alphacool NexXxoS ST30 Full Copper 280mm radiator. Basically the sides of the radiator curve inwards by a combined 3mm, this makes it impossible to get the centre fan/case mounting screws in. The dimension across the screw holes is 122mm where it should be 125mm.
My supplier (Scan Computers) has exchanged the radiator and the second one is exactly the same mad.gif
Ronski is offline
post #5 of 23 (permalink) Old 11-16-2015, 12:23 PM
Ironsmack's Avatar
Rep: 50
I'd get the HWL GTS rads instead. Its a really great rad compared to the Alphacool ST series.
Gaming Rig:- (2) Swiffy MCP35x, (2) Aphacool UT60 480 rad, (1) 360 HWL GTX, (1) 240 HWL GTS, Heatkiller IV, 5930k @ 4.4 GHz, Asus X99 Deluxe II, (2) NVidia 1080 w/ HK IV blocks, 240 GB Intel 530, 500 GB Samsung EVO 850, (4) 3 TB & (1) 5 TB Toshiba HD, EVGA 1300 PSU, Win 10 Pro
HTPC Rig:-G3258 @ 4.3Ghz, Asrock Z97 Pro 4, D5 vario w/ EK top, 480 XSPC RX, 240 HWL GTX, Asus 290 w/ XSPC WB 1000/1300, Kingston 240 GB SSD, 2TB WD Green, 5TB Toshiba HD, 2TB Samsung F4, 6TB & 8TB HGST, Enthoo Primo, Corsair HX620 PS, Win 10 Pro
Ironsmack is offline
post #6 of 23 (permalink) Old 11-20-2015, 12:07 PM - Thread Starter
Ronski's Avatar
Rep: 1
Just come on here to update the thread and seen you're post @Ironsmack, funnily enough earlier today I ordered a Hardware Labs Black Ice Nemesis Radiator GTS 280 U flow, not the cross flow version.
I'm very disappointed with Alphacool's handling of this problem, their quality control is clearly completely lacking, and when I asked if I ordered directly from them could they check the mounting hole dimensions they said no! So there you go terrible quality rads, and when it does go wrong they are not willing to help. I had to send photos to Scan Computers last night, and the second rad was so bad that the screws on the end tank were only 122.4mm apart so I tried to fit a fan and I could only get two screws in!
I've attached a picture which show's the dimensions across the centre fans screws, I've zeroed the gauge on the diameter of one of the screws so this give the true centre to centre dimension which should be 125mm and actually comes out out 122mm! Scan are paying for the return and going to refund in full thumb.gif, so luckily I won't lose out financially but I have wasted a lot of time over this.
Ronski is offline
post #7 of 23 (permalink) Old 11-24-2015, 02:05 PM - Thread Starter
Ronski's Avatar
Rep: 1
My HW Labs Black Ice rad arrived today, very nicely made and the screw holes all line up, only slight problem is it doesn't yet fit in the case. For some reason only known to Corsair they didn't provide a cut out in one side of the CD rom bay for radiators. I had to fold down a metal tab to get the Alphacool rad to fit, but the Black Ice is wider so I'll need to get the Dremel out.
Ronski is offline
post #8 of 23 (permalink) Old 12-05-2015, 02:02 PM - Thread Starter
Ronski's Avatar
Rep: 1
Just thought I'd post some progress updates, it's slow going as I don't get a lot of spare time.
I've modified the case and the rad now fits.
I had to cut a small section out of the case, I can't really understand why it isn't built this way, it is after all designed to take this size rad.
And with the motherboard and fans fitted - this is all temporary at the moment.
And the res is mounted, I had to cut the tube down to get it to fit, I did this with a circular bench saw. The valve at the top will be for filling the loop, the one at the bottom for draining it.
And for my very first go at bending acrylic, to my amazement it actually fits - this pipe is a trial run, the first bend I got too hot, the rest went OK. It's going to be fiddly doing up the compression fitting, but I'm sure I'll manage it.
Ronski is offline
post #9 of 23 (permalink) Old 12-05-2015, 02:17 PM
DMatthewStewart's Avatar
Rep: 37
Nice bend. Looks professional. Rep added. BTW, you may not be crazy about those Phanteks fans. Or you may love them. One of the best PWM fans that Ive owned for radiators were the Noiseblocker e-Loop's. Just an FYI. Also, I still have 4 left over. If you need them give me a PM. I may not respond immediately. Main rig is being torn down as Im going from my FX 8350 to my x99 5930k.
DMatthewStewart is offline
post #10 of 23 (permalink) Old 12-06-2015, 03:23 AM - Thread Starter
Ronski's Avatar
Rep: 1
Thanks for the rep and offer on the fans, but they are too thick to use on the rad, so I could only use them on the case and as I'm in the UK it's probably not worth it. I really do need to power up the Phanteks to see how noisy they are before I complete my build as it will be a pain to change them afterwards
Ronski is offline
