EK Thermosphere + EVGA GTX 980 Ti SC+ (4995) - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 10-20-2015, 08:26 PM - Thread Starter
I TeK things...
bluedevil's Avatar
Looking to go custom watercooling soon. Really wanting to use a universal GPU block for further compatibility with ofher GPUs I will be testing in the future. My question is, will the EK Thermosphere work with my EVGA GTX 980 Ti SC+ ACX 2.0+ (4995) GPU without the removal of the internal heatplate?
http://www.evga.com/Products/Product.aspx?pn=06G-P4-4995-KR
bluedevil is offline
post #2 of 8 (permalink) Old 10-21-2015, 02:25 PM
Awaiting the REP Rebuild
gftgy's Avatar
Rep: 41 (Unique: 36)
I don't know about the removal of the internal heatplate, but EK has a compatability list to determine what parts will work with a specific video card.
gftgy is offline
post #3 of 8 (permalink) Old 10-21-2015, 03:29 PM - Thread Starter
I TeK things...
bluedevil's Avatar
post #4 of 8 (permalink) Old 10-22-2015, 05:07 AM
RnRollie's Avatar
Rep: 160 (Unique: 125)
well.. it says:
Cools GPU only! To be used with factory installed Mounting Plate G80.
so.. i guess it might. If you wanna know for sure... EK has representatives here .. try the EK club smile.gif
Otherwise.. there must be a FAQ somewhere https://shop.ekwb.com/ek-thermosphere
Reality is futile, you will be assimilated by (your) perception.
Golden Rule(s) for Fans: CHEAP + SILENT = NO PERFORMANCE ▼ CHEAP + PERFORMANCE = NOT SILENT ▼ SILENT + PERFORMANCE = NOT CHEAP
+Most SILENT Case Fans are not well suited for CPU-HS-Towers or Radiators
+Most SILENT Case Fans are not well suited for cases, especially if they have filters. (added by doyll on 23/04/2014)
RnRollie is offline
post #5 of 8 (permalink) Old 10-22-2015, 05:14 AM
carlhil2's Avatar
Location: West Medford, Ma [or, you can just say Boston]
Rep: 147 (Unique: 90)
You can use the EK-VGA Supremacy and keep backplate/midplate...I have one on a 980Ti Classified...
Black Mamba
8Ball
(31 items)
My NUC5i7RYH HTPC
(5 items)
7960x
ASUS ROG RAMPAGE VI APEX
nVIDIA GTX Titan XP
Gskill TridentZ 3200 cas 14 4x8 GB
WD
Mushkin Chronos DX 120gb
Mushkin Chronos DX 60GB
Samsung 840 Pro 256GB
Intel 750 Series 400GB
intel 730 480GB
Intel Optane 900p
Optical Drive
Samsung DVDWBD SH-B083L
Seasonic SS-1250XM X-Series ATX PC Power Supply
XSPC RayStorm w/Alphacool NexXxoS Monsta 420mm/140mm rad XSPC Titan block/Dual bay D4 pump
Corsair 900D
Operating System
Windows 10 Pro
Sammy U28D590D Monitor
Keyboard
Logitech G710
Mouse
Logitech G502
Audio
AKG Q's
Audio
Aune S16 Hifi DIY 32bit / 384khz Dsd128 Fifo Full Isolation USB DAC/HA-200 High Performance, Single Ended, Class-A Headphone Amplifier
Audio
Sennheiser HD 600
Audio
JVC HA-SZ2000
Audio
Pioneer Pro DJ DDJ-SB2 DJ Controller
Audio
MPD18
Audio
xDuoo XD-05
Audio
Jotunheim
Audio
SoundMAGIC HP200
Audio
SoundMAGIC HP150
Other
CyberPower CP1500PFCLCD PFC Sinewave UPS 1500VA 900W
Other
Logitech G13
Intel Core i7-5557U
Kingston HyperX Impact Black 16GB Kit (2x8GB) 1866MHz
Operating System
Windows 10 Pro/Remix OS w/Nova Launcher Dual Boot
GeChic 1502i 15.6" 1080p IPS Portable Touchscreen Monitor
carlhil2 is offline
post #6 of 8 (permalink) Old 10-26-2015, 06:37 AM
gary66's Avatar
Rep: 0
How is it working for you? I'm thinking of doing this over a full block. I mean its about 70$ more for the full block. I also have a SC+2 with the midplate/backplate. Do you have a picture of your setup?
gary66 is offline
post #7 of 8 (permalink) Old 11-26-2015, 02:52 PM
adiktec's Avatar
Rep: 0
I would like see thermospehere with both plates, but I consider that we have modding the G80 bracket because the screws that fix inner plate obstruct the g80. should be to size thikness of inner plate and verify that the G80 fix over the inner plate.
adiktec is offline
post #8 of 8 (permalink) Old 02-13-2020, 09:11 PM
Rep: 0
Guessing you weren't able to make it work. I'm in this situation now and realizing I'll need to remove the plates to get it to work
Greywolf411 is offline
