[Build Log] 'DownUnder' SMA8 Build - Déjà vu - Page 23 - Overclock.net - An Overclocking Community
post #221 of 267 (permalink) Old 04-26-2016, 08:53 AM
1911Savage's Avatar
Rep: 12 (Unique: 10)
Looks fantastic!
Question: I notice you don't have a rear exhaust fan. Was there not enough room behind the vertical tube or did you just not want one?
1911Savage is offline
post #222 of 267 (permalink) Old 04-26-2016, 04:48 PM - Thread Starter
Costas's Avatar
Rep: 143 (Unique: 105)
Originally Posted by 1911Savage View Post
Looks fantastic!
I simply left that space open with no fan. A fan would fit, however IMO I think it would look out of place.
The system simply does not require a fan there as all the major heat producing components are liquid cooled - specifically the VRM section which can generate a reasonable amount of heat on the motherboard when overclocking.
The case is reasonably leaky as far as airflow is concerned and there is ample turbulent airflow over the motherboard and out through all the vents at the rear of the case as well as all the other gaps and openings. This is more than enough to keep other ancillary components well cooled while maintaining some positive air pressure inside the main section of the case (to help keep dust out).
Costas is offline
post #223 of 267 (permalink) Old 04-27-2016, 09:29 PM - Thread Starter
Costas's Avatar
OK - Some figures to ponder:
Total length of acrylic tubing runs in build - 2424mm - 16mm OD acrylic used throughout build
System coolant capacity - 4500mL [Coolant utilised - Tectaloy 60 Plus - Auto based glycol coolant]
Total number of Bitspower fittings utilised - 180
Flow figures for system:
Max Flow with 2x D5's @ 100% is just a tad over 1.4 GPM (Actual achieved is 1.43 GPM) - Yes, even with the relatively large amount of 90 degree fittings and other snake & elbow fittings this build utilises, it still manages to achieve an optimal flow rate.
To tell you the truth - it did surprise me a little in that we all read (scary rumours..rolleyes.gif) of 90 degree fittings being somewhat restrictive on the forums and to avoid them like the plague - yet not many actually measure this effect.
This build goes some way in solidifying Martin's original (Martins Liquid Lab) findings on testing the impact of 90 degree fittings where he generally found only minimal impact on flow rates.
Off the top of my head, here are some of the (what I would consider) best features of this build:
* Aesthetics - Primarily a personal chopice of course but I specifically stuck to accurate vertical and horizontal tubing runs while utilising the less commonly seen larger sized 16mm acrylic tube. Combined with the 'larger' elbow style (Bitspower L-Block) fittings it results in a strong 'industrial' style/look which is primarily what I was aiming for.
* One design feature that is not immediately obvious (but caused some head scratching with regards to eventual cable routing, overall GPU length etc) is that I offset both reservoirs as far left as possible which results in the RHS reservoir still being fully visible through the window with side door closed.
* Case holds 3x 560 radiators all set to intake fresh cool filtered air - no radiators using pre-heated airflow as an intake. To me this was an important design criteria as many builds have rads which intake using preheated air from another rad affecting the rad's overall cooling efficiency.
* Single loop design - Total 3x 560 radiator cooling capacity shared across all water cooled components.
* Acrylic tubing run out from GPUs is not run directly straight down through the midplate - This allows maximum flexibility for easy tubing re-arrangement of different video cards (specifically differing coolant port positioning on blocks).
No need to re-drill or reposition pass-throughs through the midplate.
The midplate is the most difficult panel to remove (requires total case disassembly) so I decided early on that the tubing run out from the second GPU would not be through the midplate but simply be offset and passed through the rear motherboard panel. I extended the very front horizontal lower tubing run (section connected to long vertical tube) so that it would simply match the lower GPU tubing run to maintain some form of symmetry.
* After modification (Bitspower Aquapipe addition), the Photon reservoirs IMO are now one of the best in class as far as bleeding and overall performance is concerned.
The fact that the inlet tube is on the bottom forcing air bubbles upwards working in conjunction with the internal deflection plate works extremely well in isolating incoming air bubbles from the outlet. Also due to their parallel configuration not only is overall restriction reduced, but the whole air bleeding process is now extremely short.
Now that the build is coming to a close I will capture some cooling performance stats and post them up at a later stage. However - so far, while overclocking and stress testing etc it has been awesome to have all that cooling reserve/capacity that the 3x 560 rads provide - while at the same time keeping the fans barely rotating @ 550rpm....thumb.gif
Costas is offline
post #224 of 267 (permalink) Old 04-28-2016, 03:21 AM
Gamer
kgtuning's Avatar
Rep: 106 (Unique: 64)
Hmm very interesting indeed. 180 fittings!? Good lord man.your flow rates makes me think i really need to put gpus in parallel. I get 1 gpm currently. We have extremely similar loops so i would expect closer numbers. Or.. my koolance flow meter isnt accurate and maybe contributing too much restriction.
mITX
(0 items)
kgtuning is offline
post #225 of 267 (permalink) Old 04-28-2016, 09:35 AM
Methodical's Avatar
Rep: 19 (Unique: 18)
Originally Posted by Costas View Post
I thought it looks average - especially since I had to overexpose the rotameter to get the reservoirs looking somewhat ok...tongue.gif
Cannot seem to get the right colour with my DSLR or my phone. I suspect as the coolant is UV reactive it is playing games with the camera's sensor ability to get a decent reproduction.
It looks 100x better when looking at the PC.
When I get the UV light strips installed - I'll endeavour to spend some time setting up a decent shot or two of the complete layout all lit up - Might be a challenge to get the colours looking right as far as the camera is concerned...!
Try using a white balance card to get accurate colors and manual exposure, if you are using auto mode.
"Remember, never be afraid to try something new, amateurs built the Ark, professionals built the Titanic"
4.7ghz
Firestrike
Build in Progress
Methodical is offline
post #226 of 267 (permalink) Old 04-28-2016, 02:03 PM
WaterCooler & Overclocker
Barefooter's Avatar
Rep: 115 (Unique: 97)
That is quite the fittings list!
Barefooter is offline
post #227 of 267 (permalink) Old 04-28-2016, 05:34 PM - Thread Starter
Costas's Avatar
Yeh, I do have a grey card for exposure setting etc however the the green given off by the UV reactive coolant is not reproduced correctly by my DSLR's sensor. Tried all sorts of white balancing tricks etc as well but to no avail...smile.gif
Yeh, you wouldn't dream that there are that many fittings in the build - but sure enough I kept an accurate updated spreadsheet as I was installing each fitting - 180 is where its at...! ...and that did not include 6 or so Alphacool stop fittings I used on a couple of the spare rad ports which are not all that visible....smile.gif
Costas is offline
post #228 of 267 (permalink) Old 05-02-2016, 05:38 AM
Gamer
kgtuning's Avatar
And EK features your build on Facebook... congrats bud.
mITX
(0 items)
kgtuning is offline
post #229 of 267 (permalink) Old 05-02-2016, 06:51 AM - Thread Starter
Costas's Avatar
Costas is offline
post #230 of 267 (permalink) Old 05-02-2016, 07:32 AM
Gamer
kgtuning's Avatar
Lol yes must be "half decent". You are way too humble.
mITX
(0 items)
kgtuning is offline
