Using Aquaero remote to turn on PC - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 12-04-2015, 04:18 AM - Thread Starter
pknut's Avatar
Rep: 1 (Unique: 1)
Hi guys, need some help please! Is there any way to turn on my pc using the Aquaero remote controller? I have the Aquaero 6 pro version
pknut is offline
post #2 of 4 (permalink) Old 12-04-2015, 07:12 AM
Aqua Computer Staff
Shoggy's Avatar
Rep: 126 (Unique: 96)
The option to turn the PC on or off via the remote must be configured directly on the device: go to the main menu -> Infrared -> Switch PC on/off via infrared -> configuration -> swichting function enabled -> back -> Learn infrared signal -> press the red power button in the upper left corner of the remote (the only button which can be used with this remote; or use a different remote) -> back (the arrow next to the navigation keys on the right side) -> Action to switch on the PC -> USB keyboard: power key (or wakeup key) -> go back and repeat the same for the action to turn off the PC with the power key or sleep key as action.
The turn off function might depend on your power management settings in Windows.
To turn the PC you have to configure the BIOS so that the keypress of a keyboard is able to start the PC. If that is not possible or does not work correctly you could also use the relay and connect the power button of your PC in parallel. This will do the job for sure (will require other actions in the infrared menu).
Got a question or having trouble with your Aqua Computer product?
Contact us via PM or E-Mail.
Shoggy is offline
post #3 of 4 (permalink) Old 12-04-2015, 08:59 AM - Thread Starter
pknut's Avatar
Rep: 1 (Unique: 1)
Thanks for your super speedy reply Shoggy, will give that a go...
pknut is offline
post #4 of 4 (permalink) Old 03-06-2019, 12:08 PM
Mighty ***der
socialite2dot0's Avatar
Rep: 1 (Unique: 1)
Hey @Shoggy and anyone else who is knowledgeable on the subject! First, sorry for reviving such an old thread, but didn't see the point clogging up the forum just to ask a question that has already been partially answered! On to my question... is it possible for you to point me to more detailed instructions of using the relay method for turning on the PC with the remote? I have the three pin relay connector. Would I simply need to wire the second and third pins of the relay to the corresponding wires coming from the "C" and "NO" wires of my power switch? I'm assuming that's what you mean by wiring it in parallel... Once that is done what settings would I need to configure in Aquasuite? Thanks in advance for your help, it's greatly appreciated!
socialite2dot0 is offline
