Where to buy water cooling fill bottle? - Overclock.net - An Overclocking Community
post #1 of 34 (permalink) Old 01-26-2016, 07:33 AM - Thread Starter
kevindd992002's Avatar
Rep: 85 (Unique: 67)
Are these available in any hardware store? I live in the Philippines so it'd harder for me to buy these online.
kevindd992002 is offline
post #2 of 34 (permalink) Old 01-26-2016, 08:29 AM
Overclock Failed...
billbartuska's Avatar
Rep: 1249 (Unique: 969)
Google image scientific squeeze bottle or scientific wash bottle
https://www.overclock.net/images/smil...lame-small.gif5 GHz Overclock Club https://www.overclock.net/images/smil...lame-small.gifMisinformation is available from a variety of other sources. Misinformation is just like real information but wrong
....and enough power to shoot the speaker cones through the walls.
billbartuska is offline
post #3 of 34 (permalink) Old 01-27-2016, 05:36 AM
Jakusonfire's Avatar
Rep: 552 (Unique: 388)
Washer / Filler bottles are good but I like to use a large syringe combined with a length of silicon tube that is normally easy to find at pet shops for a couple bucks a meter as its used for air lines in aquariums. 100ml+ syringes are easy to find for a few bucks.
The tubing is just the right size to slip perfectly on the syringe and stay there. The tubing allows perfect control of where fluid goes on the way in ... and even better allows fluid to be removed from precise places in the loop.
Its not the fastest way but zero spillage and very handy.
Jakusonfire is offline
post #4 of 34 (permalink) Old 01-27-2016, 05:45 AM
eltebe's Avatar
Rep: 1 (Unique: 1)
Buy just big bad syringe. I got one that is around 300ml
Eventually add tube to the end if needed(taken out from used soap dispenser or similar) glue it for safety though
eltebe is offline
post #5 of 34 (permalink) Old 01-27-2016, 05:49 AM
ლ(╹ε╹ლ)
Turkey Baster with a tube glued on the end.
Duality92 is offline
post #6 of 34 (permalink) Old 01-27-2016, 06:21 AM
xxdarkreap3rxx's Avatar
Rep: 176 (Unique: 129)
Originally Posted by Jakusonfire View Post
Washer / Filler bottles are good but I like to use a large syringe combined with a length of silicon tube that is normally easy to find at pet shops as its used for air lines in aquariums.
They make barbs that attach to luer lock syringes: http://www.ebay.com/itm/6-Female-Luer-to-1-4-Hose-Barb-KYNAR-Twist-Connects-Ozone-UV-Biomed-Spa-/261881169975?hash=item3cf9558837:g:vXAAAOSwEeFVTSHy Bit pricey but just got to make sure to buy luer lock syringes and not luer slip.
"and the new graphics card on HBO memory chip has recommendations PSU least 700 watts" - Causality1978
"I intend to live forever, or die trying." - Blameless
"If one more person speculates in this room we're all going to need a shower." - Ganf
xxdarkreap3rxx is offline
post #7 of 34 (permalink) Old 01-27-2016, 07:19 AM
No glue or special mount is needed. The silicon tube stays on quite firmly.
post #8 of 34 (permalink) Old 01-27-2016, 07:27 AM
Ahh yes. I forgot you're just putting the tube into the reservoir and all the air escapes out the top so there's basically no pressure difference.
post #9 of 34 (permalink) Old 01-27-2016, 01:27 PM - Thread Starter
What do you mean no pressure difference? I thought as long as the fill port is opened there would be pressure difference?
post #10 of 34 (permalink) Old 01-27-2016, 02:21 PM
RX7-2nr's Avatar
Rep: 175 (Unique: 159)
The pressure is equalized when the port is open. As you fill the res the displaced air good out the top.
How to unlock AMD Official Overclock mode in Catalyst
Easy Automatic Shutdown for Overheating CPU (water pump failure)
XSPC Photon 270 mounting plate for the Corsair 750D
AMD
(6 items)
Ryzen 1800x
ASUS ROG Crosshair 6 Hero
MSI Airboost Vega 64 8gb
G. Skill Trident Z 3200
Samsung 960 EVO 500 GB M.2
Samsung 860 EVO 1 TB
Intel Xeon X5650 @ 4.6
ASUS P6T
Powercolor PCS+ 290x
12gb Corsair Dominator
1tb WD Black
250gb Samsung 840 SSD
Cooler Master V850
XSPC Raystorm, EK 290X SE, EX240, EX360
XSPC Photon 270, Alphacool D5 Acetal HF Top
Corsair 750D
Operating System
8.1
Keyboard
Ducky Zero
Mouse
Mionix Naos 7000
RX7-2nr is offline
