Why you should probably not buy a CLC cooler - Page 2 - Overclock.net - An Overclocking Community
post #11 of 592 (permalink) Old 02-07-2016, 09:39 PM
Rep: 577 (Unique: 411)
Originally Posted by Robilar View Post
As noted above by another poster, ambient temps are a big factor for air coolers. If you have a relatively cool room all year round, its not a factor but water cooling pulls ahead in hot rooms.
This doesn't follow as the water isn't being chilled (unless, of course, you're doing just that). If ambient is higher, then everything is higher. That includes air going into an air cooler as well as both air going into a liquid cooler radiator and the liquid itself. The underlying physics aren't changing and going to reverse the performance rankings just like that.
mikeaj is offline
post #12 of 592 (permalink) Old 02-07-2016, 09:44 PM
curmudgeon
miklkit's Avatar
Rep: 304 (Unique: 175)
Correct diagnosis, but questionable solution. If I read your post correctly you added 2 more case fans plus a radiator adding heat inside the case. You did what so many do. You blame the air cooler for poor case air flow instead of fixing the case air flow. What's the cost of case fans VS that clc you bought?
#YouMightThinkItsOk
Junkyard Dog
(18 items)
Blackie
(17 items)
AMD Ryzen 1700
Biostar X370 GT7
Sapphire Nitro+ Radeon Vega 64
G. Skill Ripjaws ddr4 3200 16 GB 4x4
Samsung 850 EVO 500gb SSD
Western Digital 500gb
Samsung 860 evo 1tb ssd
Optical Drive
Memorex Lightscribe dvd
Seasonic 850 watt
Thermalright Silver Arrow IB-E Extreme
Silverstone Redline RL05
Operating System
Win 10 64bit
Pixio 27" 1440P
Keyboard
yes
Mouse
Evoluent vertical mouse
Mouse
yes
Audio
Creative X-FI
Other
Sennheiser headphones HD 599
AMD FX8370 @ 5 ghz
ASUS Sabertooth
Sapphire Fury
G Skill F3-14900CL9Q-16GBXL
Western Digital
Samsung 850 EVO
Optical Drive
Seasonic SS-850KM Active PFC F3
Silverstone Redline RL02b
Operating System
Win X 64 bit
Pixio 27" 1440P
Keyboard
yes
Mouse
Evoluent VM4
Mouse
yes
Audio
Creative Soundblaster Z
Audio
Sennheiser 428 headphones
miklkit is offline
post #13 of 592 (permalink) Old 02-07-2016, 09:45 PM
Carniflex's Avatar
Rep: 237 (Unique: 187)
I'll just add a note that according to specification a CPU socket is rated for up to 350 gram cooler wink.gif
While normally not a problem it can be if one is moving the case around. I have lost a motherboard to a Thermaltake Frio in a semi mobile system few years ago.
Carniflex is offline
post #14 of 592 (permalink) Old 02-07-2016, 09:49 PM
ghostrider85's Avatar
Rep: 329 (Unique: 273)
why you should not buy a big bulky heatsink:
1. it will obstruct everything and will cut your fingers.
2. it prevents you from accessing your ram slots.
3. it will cover your fancy motherboard leds.
4. it may damage your motherboard due to it's weight.
5. you have to remove it when transporting.
6. can't pull fresh air directly from outside, can't exhaust hot air directly to outside.
7. ugly
8. it might come in contact with the gpu pcb and short it, as seen on this pic
why you should buy clc:
PERFECTION!
ghostrider85 is offline
post #15 of 592 (permalink) Old 02-07-2016, 09:50 PM
RPG Gamer
Sp33d Junki3's Avatar
Rep: 273 (Unique: 216)
Originally Posted by Poisoner View Post
Meh. CLC are good for a variety of reasons, including ease of installation. I don't understand why you big air guys have such a chip on your shoulders over nothing.
Edit: I see you put this in air cooling, which misses your target audience. Come post this is water cooling if you want a real discussion.
Sorry to say, no one has chip on shoulder. Just experience cooling.
Originally Posted by Chargeit View Post
A 980 ti pumps out a lot of heat when running high res uncapped. The system was chocking on the heat out put. I used the stock fans that came with the case, adding a 2nd front intake since it only came with one.
I setup my old H100i as a front intake. I put two top, and one rear exhaust and it works well again. The CPU stays cool from taking in fresh air from the front, and the 3 fans set up as exhaust removes the heat of the GPU well.
You added a 2nd 140mm front fan and no top exhaust.
Did you remove both HDD cage from the R5?
As that will block most of the intake.
So you say your GPU temps are lower with the H100i in front 2x120mm, instead of just 2x 140mm fans?
Those numbers do not add up.
You can even put the H100 on top, as you have more than enough clearance.
7. ugly
1. Not always and not true
2. Not all, but some are designed to not block ram
3. That is personal taste if you got LED
4. Never heard that it will do that nor seen it happen.
5. Not hard to do to remove it, and many do move it always.
6. You can with some coolers and cases and you can directly exhaust
7. Not all, there is some good looking coolers.
Intel 3770k @ 4.2Ghz
Asus Z77 Sabertooth
EVGA GTX1060 6GB
Crucial Ballistix Tactical 16GB BLT2K8G3D1608ET3LX0
Crucial M4 256GB
Crucial MX100 512GB
Corsair F115 120GB
HGST 5K1000 1TB
WD Green 2TB
Corsair AX760
Cryorig C1 + XT140
NZXT S340 White
Operating System
Win10 Home
BenQ GW2765
ASUS VE278Q
Keyboard
CM Storm Trigger Brown Switch
Mouse
Logitech G500
Mousepad
HAVIT HV-MP830
Audio
Audiotrak Prodigy Cube DAC
Audio
Edifier S330D 2.1 Speaker
Audio
Superlux 668B Headphone
Audio
Plantronics RIG500
Other
Noctua NT-H1 (CPU/GPU)
Other
3x 140mm Noctua NF-P14s Redux 1200rpm PWM
Other
1x 120mm Noctua NF-S12B Redux 1200rpm PWM
Other
NZXT 2m Sleeved White LED
Sp33d Junki3 is offline
post #16 of 592 (permalink) Old 02-07-2016, 09:52 PM
Custom Loop Snob
Poisoner's Avatar
Rep: 111 (Unique: 96)
So if I made a thread about why you should only build a custom loop that would be received with high praise?
Poisoner is offline
post #17 of 592 (permalink) Old 02-07-2016, 09:55 PM
Eh, Wha?
Zero4549's Avatar
Rep: 716 (Unique: 531)
7. ugly
PERFECTION!
For the amount you spent on those 3 derpy CLCs, you could have built a custom loop that would look better, perform better, last longer, etc.
"Perfection" is probably the last thing I'd call those ugly tubes running haphazardly across your GPUs, or the woefully inefficient cooling and noise levels you are getting from that setup.
I'm not against CLCs, but I do understand that their practical application is much more niche than people seem to think. I've used CLCs in systems where small size, some flexibility in mounting, and lack of required maintenance were the most important factors, and under those conditions they do well. In just about any other scenario however, they are a very poor choice.
Systems: Fukurou | Prodigy | Tempest | ArcaneServers: Minecraft SMP | Logs: Build Log - Arcane | Video Logs: Project Arcane
Quote:Originally Posted by Zen00 https://www.overclock.net/img/forum/go_quote.gifZero, you are a master story teller, I am sleep now. http://files.overclock.net/images/smilies/thumb.gif
Arcane
(33 items)
Sanctum
(9 items)
Fukurou
(14 items)
Core i7 980x
GIGABYTE GA-EX58-UD5
MSI GeForce GTX 1080TI DUKE
MSI GeForce GTX 680 Lightning
Kingston HyperX T1
Samsung 840 EVO
WD Caviar Black FASS
Plextor M5S
WD Velociraptor
WD FALS
Optical Drive
Sony DVD Burner w/ Lightscribe
Optical Drive
LG Bluray + HDDVD
EVGA 1000 P2
Black Ice GTX 360
Black Ice GTX 240
Cooler Master HAF 932
Operating System
Windows 10 Pro (64)
X-Star DP2710
ASUS VK266H Black 25.5" 2ms LCD
Keyboard
X-Armor U9BL (Mech)
Mouse
Razer Deathadder Chroma
Mouse
Cougar Control
Audio
ATH-A900X
Audio
Maudio AV-40
Audio
Polk PSW-10
Audio
Zalman Mic-1 (Clip-on Mic)
Audio
Sound Blaster X7 LE
Other
Logitech G13
Other
Wacom Intuos 3
Other
Modded PS4, PS3, Xbox 360, and Logitech PC Controllers
Other
Thrustmaster T.16000M FCS HOTAS
Other
Rocketfish 720p Webcam
Other
Scythe "3-Foot Switch"
Ryzen 7 1700
MSI B350M Mortar Arctic
RX Vega 64
G.Skill TridentZ
Samsung EVO 960
Consatellation
Corsair HX 1050
Raijintek Aeneas White Window
Operating System
Windows 10 Pro
Core i5-661
GA-H55-USB3
12GB DDR3 1333
WD Caviar Black AALS 640GB
WD Caviar Green EARS 2TB
Vertex Turbo 60GB (SSD)
Optical Drive
Samsung Blu-ray, Samsung DVD Burner
Seasonic X750 Gold
H50 (With push/pull nocturas)
CM690 II
Operating System
Windows 10 Professional 64
LG 47inch LED LCD
Keyboard
Saitek Eclipse Lite-touch Wireless
Audio
Passive bookshelfspeakers + amp.
Zero4549 is offline
post #18 of 592 (permalink) Old 02-07-2016, 09:56 PM
RPG Gamer
I also build custom loops. Just with all the RMA I have done for CLC over the years and issues. Just was wasted time for majority little gains.
Asus Z77 Sabertooth
EVGA GTX1060 6GB
Crucial M4 256GB
Crucial MX100 512GB
Corsair F115 120GB
HGST 5K1000 1TB
WD Green 2TB
Corsair AX760
Cryorig C1 + XT140
NZXT S340 White
Operating System
Win10 Home
BenQ GW2765
ASUS VE278Q
Keyboard
Mouse
Logitech G500
Mousepad
HAVIT HV-MP830
Audio
Audio
Audio
Audio
Plantronics RIG500
Other
Other
Other
Other
post #19 of 592 (permalink) Old 02-07-2016, 09:59 PM
Custom Loop Snob
Poisoner's Avatar
I've had good luck with the CLCs I had in the past. The pump on my H60 went out once, Corsair sent me a brand new one in its place. In fact that H60 took an i5 750 just a few mhz shy of a 2ghz overclock...
Poisoner is offline
post #20 of 592 (permalink) Old 02-07-2016, 10:00 PM
"Perfection" is probably the last thing I'd call that.
and then i have to mess with it every month to keep it maintained? nevermind the initial hassle of building a custom loop.
my 980 ti 1500mhz tops out @ 52C, do i need better cooling? absolutely not.
my 6600k 4.6ghz tops out @ 67C, do i need better cooling? absolutely not.
so, why do i need to waste my time building a custom loop then? absolutely nothing.
