Why you should probably not buy a CLC cooler - Overclock.net - An Overclocking Community
post #1 of 593 (permalink) Old 02-07-2016, 07:23 PM - Thread Starter
Meeeeeeeow!
CrazyElf's Avatar
Rep: 428 (Unique: 299)
Why is this thread even needed?
One of my pet peeves in recent years has been the rise of Close Loop Coolers. They have been misleadingly advertised as easy to set up, yet providing performance like water cooling, which most enthusiasts associate as being superior to air cooling.
Custom loops can indeed, when built well, be quite a bit better than air cooling. However, the majority of AIOs, as I will discuss below, are not really an upgrade to air cooling at all. In particular,
I got this inspiration from Shilka, who has done a good job of writing "why you should not buy" certain models of power supplies known to be terrible. I feel like someone needed to write a thread like this.
I suppose I should distinguish between AIO and CLC
  • Closed loop cooler: Pre-filled loop that cannot be opened up or filled by the user.
  • All in one: Typically a custom loop that has been prefilled, but can be refilled and upgraded by the end user. Ships with custom loop parts as well.
I firmly believe that where CPU cooling is concerned, most CLC users would be better off with a dual tower air cooler.
Do air coolers have any drawbacks?
Before I begin, do air coolers have drawbacks? Sure they do. Let's explore.
  • About the only damage that a dual tower in that regard is that it does put a bit more pressure on the motherboard (they can weigh more than 1.5 kg with fans attached). However, the risk of damage to the motherboard is miniscule compared to the risk of a poor quality CLC leaking, which anecdotally at least, seems to happen much more frequently. If you are concerned, you can add support brackets and I would recommend removing a heatsink before moving (same with a water cooling AIO too, as moving it around may increase the risk of leaks).
  • Large dual towers can block the first PCI-E slot. There have been some solutions on the market in an attempt to address this, such as the D15S. For motherboards that have their first PCIe slot a an x1, this is a non-issue.
  • You may also have to make sure that your case has sufficient clearance for the biggest coolers.
  • Tall RAM heatsinks can be blocked (not as big an issue these days as DDR3 and DDR4 do not run hot enough to justify those heatspreaders).
There have been complaints of LGA 1151 CPUs being damaged by poorly built air coolers due to their thinner substrates (only 5 layer PCBs versus 8), but most well built heatsinks will prevent you from applying excessive pressure onto the CPU that exceeds Intel's spec anyways.
A D15S - note the asymmetrical design intended to prevent PCIe slots from being obstructed and the fins on the bottom being cut, which allows for taller RAM.
Those are the main drawbacks to air cooling.
Why not a CLC then?
So if air cooling has its drawbacks, a CLC seem like a great alternative?
  1. Cost
  2. There are more parts to fail
  3. They lose their liquid inside to evaporation over time
  4. The performance to the noise ratio for most CLCs is actually not as good as the top dual tower air coolers
  5. If they leak, the damage can be widespread - also to the rest of your computer parts
Price
As a general rule, the dual 240 CLCs are more expensive than a high end air cooler.
Currently, the top end coolers can be had for well under $100 USD. My current cooler, the Cryorig R1 Ultimate, can be had for $80 USD when it goes on sale. Prices will vary nation by nation, but in general, a 240 CLC will cost more than a dual tower CPU cooler.
The bottom line though is that there is an opportunity cost to be had there. Whenever you spend money on one part, it has to be taken out elsewhere.
More Parts to fail
Very simply put, in an air tower, about the only thing that could fail is one of the fans. Typically many dual tower CPU coolers have a pair of fans, which somewhat mitigates this.
However, on a CLC, you have all of the parts in a water cooled system that can fail, only often lower quality.
  1. Fans (like in an air cooled tower)
  2. Pump
  3. Galvanic corrosion over time on the parts
  4. Leaks are a concern too (will describe in a separate section below)
Fans need no further explanation. That said, ideally you'll want 2-ball or FDB bearing fans to last as long as possible.
The pump is a problem because CLCs typically do not ship with good quality pumps. Generally in a custom loop, pumps like the Liang D5 are known for their reliability and have enough pressure to sustain a pretty decent sized loop. The majority of CLCs do not have good quality pumps and this is a point of failure.
Galvanic corrosion is also an issue because most CLCs ship with aluminum radiators (rather than copper). You get a mixing of aluminum, with other metals - most notably copper, nickel, and brass (technically an alloy, not a metal). That over time creates galvanic corrosion and can be an issue. CLC vendors usually know this and add ethylene glycol or some other anticorrosive to slow this process down (but it is physically not possible of course to stop it).
This image is from a custom loop, but I expect that a CLC will do worse, because most custom loop builders will not be mixing aluminum with copper/brass/nickel, and they will be changing their water annually.
They only last for a few years as liquid is lost to evaporation
A typical CLC, being non-refillable is only going to last for a few years. The reason is because tubing is permeable. Custom loops suffer from this flaw too and have to be "topped up" every now and then as well. Water levels drop in the reservoir.
Again, most CLC vendors know this. A good CLC will use Tygon Norprene or something similar to mitigate this. Norprene (which is used in the automotive industry for brake and fuel lines) has a much lower Water Vapour Transmission Rate (WVTR) and as a result will not require topping up nearly as often. This will mitigate, but not eliminate the problem.
Combine that with galvanic corrosion and you get something that will not last more than a couple of years. Eventually too little water will be in the system and the pump will run dry, choking on air.
Like in any water cooling system, there is the risk of leaks. However, just like how the pumps are not well built, there is the risk of leaks. You aren't getting top quality fittings, and unless Tygon Norprene or something of similar quality is used, you are probably not getting good quality tubing either.
When a CLC leaks, it is not just the CLC that is in danger; it is like any other water cooled system leaking. It can short circuit your CPU, motherboard, GPU, RAM, or perhaps power supply.
Depending on the manufacturer, they may compensate you for damages::
http://forums.bit-tech.net/showthread.php?t=233533
Now it is true that the user above should have recognized the warning signs and taken the CLC out, but the fact remains that the CLC damaged his components and he did not receive compensation.
If you must buy a CLC, make sure that you buy from a company that has been known to honor the costs of the rest of the PC. Amongst the companies I've seen making CLCs, Corsair seems to be one of the few that does, so if you are not convinced by this thread, you may want to consider a Corsair part.
The performance of most CLCs is actually not as good as it seems
If you look on the Internet, you'll find a lot of reviews and typically, you'll find the the 240 or 280 CLCs outperforming the towers by a couple of degrees. The problem is that they are doing so on the basis of faster fans. The most important metric is actually performance to noise ratio. There, the top air coolers have been surprisingly competitive.
See here:
http://www.tweaktown.com/reviews/6313/noctua-nh-d15-cpu-cooler-review/index.html
What this image is telling me is that the D15 is performing almost as well as the top CLCs, but is a lot quieter. Were you to put 2500 rpm fans on the D15, it would outperform every CLC shown here.
I should mention that there have been a few decent high end CLCs: The Corsair H110i GTX seems pretty decent (Click to show)
http://www.tweaktown.com/reviews/7320/corsair-hydro-h110i-gtx-high-performance-liquid-cpu-cooler-review/index5.html
However, I still recommend getting an open loop AIO cooler. Keep in mind the H110i GTX is one of the most expensive CLCs out there.
The thing you have to consider though is, given that most CLCs do not perform well against competing dual towers, have the increased risks of failure, the danger of leaks associated with a custom loop (only on lower quality parts), is it really worth it?
Are there any exceptions?
The kits made by Swiftech and EK are pretty good. These are AIO kits. These do offer a better performance to noise ratio than any competing solutions from dual tower air coolers and for that reason I have no hesitation in recommending them.
The Swiftech H320 x2
These AIO kits, although they cost more, mitigate the majority of the flaws that CLCs have:
  • They can be refilled so loss of liquid is not as big an issue.
  • They have high quality pumps (actually pumps that belong in a custom loop), which means that they are expandable and that risk of pump failure is much lower.
  • They actually perform quite well compared to air cooling dual towers (actually even better from a performance to noise standpoint)
The only drawback would be that they can still leak, which is the risk of any custom loop.
Conclusions
The point I want to make is that a CLC is not worth it. Not given the massive drawbacks they have over a dual tower. Basically, your options should be the following.
From cheapest to most costly:
  1. Cheap budget air cooler
  2. Higher end dual tower CPU air cooler
  3. Expandable AIO (ex: Swiftech and EK make these)
  4. Full scale custom loop
CrazyElf is offline
post #2 of 593 (permalink) Old 02-07-2016, 07:32 PM
RPG Gamer
Sp33d Junki3's Avatar
Rep: 273 (Unique: 216)
Good post. I tried many different CLC and all has been a nightmare.
I am talking about going far back well before Corsair teamed up with Asetek.
You have Coolit and Asetek selling their own kits to the public. No matter what I did, not once could I have temps/noise equal to the air coolers I had.
Then came along Swiftech with the H220. That kicked the crap out on my Noctua NH-U12P SE2. Was just as quite, yet gave me 5-8c cooler overall from idle to load.
CLC are a joke and continue to be one. Many will say yes mine works fine and has for a while.
More bad stories from CLC vs how many from air coolers???
Intel 3770k @ 4.2Ghz
Asus Z77 Sabertooth
EVGA GTX1060 6GB
Crucial Ballistix Tactical 16GB BLT2K8G3D1608ET3LX0
Crucial M4 256GB
Crucial MX100 512GB
Corsair F115 120GB
HGST 5K1000 1TB
WD Green 2TB
Corsair AX760
Cryorig C1 + XT140
NZXT S340 White
Operating System
Win10 Home
BenQ GW2765
ASUS VE278Q
Keyboard
CM Storm Trigger Brown Switch
Mouse
Logitech G500
Mousepad
HAVIT HV-MP830
Audio
Audiotrak Prodigy Cube DAC
Audio
Edifier S330D 2.1 Speaker
Audio
Superlux 668B Headphone
Audio
Plantronics RIG500
Other
Noctua NT-H1 (CPU/GPU)
Other
3x 140mm Noctua NF-P14s Redux 1200rpm PWM
Other
1x 120mm Noctua NF-S12B Redux 1200rpm PWM
Other
NZXT 2m Sleeved White LED
Sp33d Junki3 is offline
post #3 of 593 (permalink) Old 02-07-2016, 07:33 PM
To The Game
Chargeit's Avatar
Rep: 292 (Unique: 198)
Bought Define R5 case and Noctua D15.
Suffered from overheating GPU and CPU due to poor case airflow.
Tested out various fan setups and nothing helped.
Said screw it and removed the Nocuta D15, putting my H100i back in as a front intake.
GPU and CPU temps back to normal.
Moral of the story, ClC are more versatile and therefor work better with a larger range of setups. Air coolers are overrated.
Chargeit is online now
post #4 of 593 (permalink) Old 02-07-2016, 07:41 PM
Random Eventer
Skye12977's Avatar
Rep: 85 (Unique: 75)
Although not for the points you listed, I do agree closed loops are a waste of money for the most part, but like most things YMMV.
The name brand AIOs are more aesthetically pleasing and can be fit into smaller cases that can't house coolers like the 212 even.
My HeatWare
Main Computer
(7 items)
i7-8700
Asus Prime Z370-A
Asus GTX 1080 Strix
Corsair Vengeance LPX 16GB DDR4 DRAM 3000MHz C15
Crucial MX300 525GB SSD
Corsair AX760
Scythe Fuma Rev. B (SCFM-1100)
Skye12977 is offline
post #5 of 593 (permalink) Old 02-07-2016, 07:47 PM
Rep: 577 (Unique: 411)
Some builds don't have the space for a tower cooler, and some CLCs are cheaper, simpler, and take less space than custom loops and even most of the expandable AIO types.
But yes, in general a lot of people are ignorant (unfortunately, sometimes willfully) about relative CLC performance and characteristics.
It's also possible that more people mess up the mounting of air coolers.
mikeaj is offline
post #6 of 593 (permalink) Old 02-07-2016, 09:00 PM
RPG Gamer
How is that even possible. R5 do not have poor airflow. Something was wrong in your setup.
Had D14 in R5 on a 4790k OC to 4.4GHz with temps below 55c under stress.
Asus Z77 Sabertooth
EVGA GTX1060 6GB
Crucial M4 256GB
Crucial MX100 512GB
Corsair F115 120GB
HGST 5K1000 1TB
WD Green 2TB
Corsair AX760
Cryorig C1 + XT140
NZXT S340 White
Operating System
Win10 Home
BenQ GW2765
ASUS VE278Q
Keyboard
Mouse
Logitech G500
Mousepad
HAVIT HV-MP830
Audio
Audio
Audio
Audio
Plantronics RIG500
Other
Other
Other
Other
post #7 of 593 (permalink) Old 02-07-2016, 09:10 PM
Old to Overclock.net
mark_thaddeus's Avatar
Rep: 249 (Unique: 209)
I also have to add that application and type of weather also make a big difference.
I come from a tropical country and I had a Noctua NH-D14 in my FT-03 (not the mini and yes it fit with no issues) and I would hit in the low 70s with my Noctua specially during the summer months here (temps would go over 100*C outside).
I switched over to an AIO (a lowly H55 with a push pull setup with fans on low - 1000 rpms) and it has only ever hit low to mid 60s at full load during summer months.
Though I do agree that generally unless you get the expandable CLCs your better off using air coolers! For SFF builds though, that's a different story altogether!
Yin & Yang
(15 items)
i7-4790k
Asus Z97I-Plus
EVGA FTW3 1080Ti (Hybrid Kit)
Kingston Hyper X Fury 16 GB 1866Mhz
Crucial MX500 1TB
Seasonic P660X
ID Cooling Frostflow+ 240
NZXT H400i
Operating System
Windows 7 Pro SP1
Asus PB278Q
Keyboard
Ducky One 2 TKL
Mouse
Logitech G102 Prodigy
Mouse
Razer Sphex
Audio
Fiio E17 / E9K
Audio
Fidelio X2
mark_thaddeus is offline
post #8 of 593 (permalink) Old 02-07-2016, 09:25 PM
Retired Staff
Robilar's Avatar
Rep: 675 (Unique: 477)
As noted above by another poster, ambient temps are a big factor for air coolers. If you have a relatively cool room all year round, its not a factor but water cooling pulls ahead in hot rooms.
Home PC
Intel G3440
Asus B85M-E/CSM
EVGA GTX 950
Patriot Viper 3 - 2x8GB 1600hz
Samsung EVO 850 - 500GB + 4TB x2 / 3TB x 2 - WD
Optical Drive
LG CH12LS28 Bluray
Corsair CX430 V2
Scythe Big Shuriken 2 w/Corsair SP120 Fan
NMEDIAPC HTPC 6000B w/ Pro LCD Module
Operating System
Windows 10 64 Bit
Samsung 75" TV....
Keyboard
GooBang Doo MX3
Mouse
GooBang Doo MX3
Robilar is offline
post #9 of 593 (permalink) Old 02-07-2016, 09:28 PM
Custom Loop Snob
Poisoner's Avatar
Rep: 111 (Unique: 96)
Meh. CLC are good for a variety of reasons, including ease of installation. I don't understand why you big air guys have such a chip on your shoulders over nothing.
Edit: I see you put this in air cooling, which misses your target audience. Come post this is water cooling if you want a real discussion.
Poisoner is offline
post #10 of 593 (permalink) Old 02-07-2016, 09:33 PM
To The Game
Chargeit's Avatar
A 980 ti pumps out a lot of heat when running high res uncapped. The system was chocking on the heat out put. I used the stock fans that came with the case, adding a 2nd front intake since it only came with one.
I setup my old H100i as a front intake. I put two top, and one rear exhaust and it works well again. The CPU stays cool from taking in fresh air from the front, and the 3 fans set up as exhaust removes the heat of the GPU well.
