Mounting pressure for CPU block - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 03-13-2016, 01:31 PM - Thread Starter
Custom Loop Snob
Poisoner's Avatar
Rep: 111 (Unique: 96)
Anyone else here have the Aquacomputer Cuplex Kryos? I have the block on there pretty good, but I've noticed my CPU delta temps are higher than what I feel they should be. CPU is an i7 5930k at 4.7ghz at 1.325v. While running realbench for a long duration my temperatures get into the mid 70s on the cores and package, with a peak right at 80c. I'm wondering if I need to tweak my mounting pressure or adjust fans and radiator air flow.
Poisoner is offline
post #2 of 3 (permalink) Old 03-13-2016, 02:11 PM
Holst's Avatar
Rep: 8 (Unique: 8)
If your temperature is ok initially then increases over time then your water is heating up.
More airflow over your rad will help.
If you get high temps as soon as you open realbench then you may be able to improve your mount.
Holst is offline
post #3 of 3 (permalink) Old 03-13-2016, 02:21 PM - Thread Starter
Custom Loop Snob
Poisoner's Avatar
I'll add more fans and maybe a fan for the socket then. Thanks
Poisoner is offline
