Do all pumps add heat to the loop? - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 03-13-2016, 01:40 PM - Thread Starter
Linux Lobbyist
tabs's Avatar
Rep: 0
hi
Sorry if this is a dumb question but I have heard that the D5 pump adds heat to the loop and that needs to be considered for heat dissipation of the loop itself. Is that the case for other pumps? I know some DDC pumps have heatsinks, would that take care of the heat produced by the pump without having to account for it in the loop? What about Jingway and Iwaki pumps?
thanks
tabs is offline
post #2 of 5 (permalink) Old 03-13-2016, 01:53 PM
Custom Loop Snob
Poisoner's Avatar
Rep: 111 (Unique: 96)
The pump adds an insignificant amount of heat, no matter what pump you get. I wouldn't worry about it.
Poisoner is offline
post #3 of 5 (permalink) Old 03-13-2016, 01:56 PM
Been here for a while
danilon62's Avatar
Rep: 29 (Unique: 22)
I'd expect the liquid coming thru the pump itself to carry most of that heat on to the radiator as it would do with any other component via conduction.
[Intel] Core i7 6700k
[Gigabyte] Z170X-UD3
[Gigabyte] R9 280x
[Corsair] Vengeance LPX
[Samsung] 840 EVO
[Crucial] MX100
[Western Digital] Caviar Black 1TB
Optical Drive
[ASUS] DRW-24F1ST
[Corsair] HX750
[Antec] Khüler H2O 620
[Artic Cooling] MX-4
[Corsair] SP 120
[Corsair] AF 120
[Corsair] AF 140
[Bitefenix] Recon 5.25 Fan Controller
[Corsair] 200R
Operating System
[M$] Windows 10 Pro
[BenQ] XL2411Z 144Hz
Keyboard
[Corsair] K70 Cherry MX Red
Mouse
[Corsair] M65
Mouse
[Corsair] MM200
Audio
[Tritton] AX 720 Plus
Audio
[Creative] Inspire T3150 2.1
Other
[Saitek] Pro Flight X-55 Rhino H.O.T.A.S.
[AMD] FX 8320
[Gigabyte] 990FXA-UD5
[EVGA] GTX 960 SSC
[Corsair] Vegeance 3x4GB
[Samsung] 840 EVO
[Western Digital] Caviar Blue 1TB
Optical Drive
[ASUS] DRW-24F1ST
[Corsair] CX500M
[Cooler Master] Hyper 212 EVO
[NOX] Coolbay VX
Operating System
[M$] Windows 10 Home
[AMD] FX 8120
[Gigabyte] GA-970A-D3 (RIP)
[Gigabyte] GTX 650
[Corsair] Vegeance DDR3
danilon62 is offline
post #4 of 5 (permalink) Old 03-13-2016, 01:59 PM
Holst's Avatar
Rep: 8 (Unique: 8)
All pumps will add heat to the loop.
The vast majority of which will be added to the loop.
Even pumps with heatsinks will add most of there wattage to the loop.
In most cases the additional pump wattage won't affect temperatures, unless you are running a very low power system, or loads of pumps.
Holst is offline
post #5 of 5 (permalink) Old 03-13-2016, 02:27 PM
Professional Proletariat
magnek's Avatar
Rep: 478 (Unique: 192)
D5 Vario at 100% load only adds 24W to the loop, which is insignificant amount.
- 4930K @ 4.5 GHz | Asus X79-Deluxe
- MSi 980 Ti Gaming @ 1500/8000
- 4x4 GB Dominator Platinum 2400 MHz
- 2x 850 Pro 2TB
- Seasonic PRIME Titanium 850W
- Phanteks Enthoo Primo
- Custom watercooling (420+360+240)
- XB270HU 27" 1440p 144Hz IPS
magnek is offline
